Prius 2011 with 29MPG trouble!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MomaniSM, Aug 14, 2018.
  1. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    Sounds like the air/fuel ratio is off, with too much fuel (rich), which obviously uses more gasoline and lowers gas mileage. Some sensors that affect air/fuel ratio include the MAF, MAP, oxygen sensor (located after the catalytic converter), and air/fuel ratio sensor (wideband oxygen sensor, located on exhaust manifold). You could try cleaning the MAF with MAF cleaner since that's easily accessible and something fairly common to do.
    I don't have the Torque app. But on my car, using a Bluetooth OBD reader and OBD Auto Doctor app, I'd get a freeze frame that included lambda, which is a way of describing air/fuel ratio (less than 1 is rich, more than 1 lean). For example:
    Bank 1 - Sensor 1 (wide range O2S): Equivalence Ratio (lambda): 0.994
    On my car, just before I bought it at 150,000 miles, the previous owner had reported low gas mileage to the dealer. Eventually it popped a check engine light and was fixed after replacing the MAF (maybe a cleaning would have worked too?) and air/fuel ratio sensor. I bought the car just afterwards, the gas mileage was fine.
    I wouldn't throw parts at it. Seems like you'd replace a lot of possibly good parts (your 12V battery?). Take it to a shop for diagnosis. Seems like something that any shop that could do emissions testing could do (though maybe not a thing in Jordan?). Back when emissions testing was required in my state, my old Subaru once needed an oxygen sensor or something like that to pass the test. Or drive it until you get a check engine light and code telling you what's wrong.
    mjoo likes this.
  2. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    That stinks, no schrader valve like on some GM cars. The manual says to disconnect the line and install a tee for the pressure gauge.
    44 to 50 PSI is the standard fuel pressure
    Pixel XL ?
    ITBland and Raytheeagle like this.
  3. Mendel Leisk
    42,296
    Yeah I just took a look through the Repair Manual, came to the same conclusion. It says to disconnect fuel line at the pump, patch in hose with Tee and pressure gauge, as you said. There's also mention of Techstream.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Good to know my memory is not as bad as my wife says it is from time to time :sick:.
    ITBland, Mendel Leisk and mjoo like this.
  5. Mendel Leisk
    42,296
    Does she say the same thing about your hearing? :whistle:
    Raytheeagle likes this.
  6. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Selective :love:.
  7. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Check your brakes, make sure all yours pins are greased up properly. A dragging pad can kill mpg. Check emergency brake operation. Make sure your egr pipe/cooler and intake manifold are clean. Change your spark plugs or at least check them. If someone put cheap plugs in, they could be burnt up by now. A car burning oil will also foul your plugs in a result of bad mpg. Send out your injectors to be cleaned/tested.
    mjoo likes this.
  8. Mendel Leisk
    42,296
    Not as good but worth a try: try an injector cleaner, one you add to the tank at fillup, with PEA (Poly Ether Amine IIRC).
    danlatu likes this.
  9. MomaniSM
    MomaniSM Junior Member
    JO
    Three Touring
    Break pads replaced after checked.
    EGR cleaned to the nick, and MPG raised to 35mpg, its good now but not satisfying, will schedule cleaning fuel injection and report back the impact
  10. Mendel Leisk
    42,296
    Did you try that MAF cleaning?
  11. MomaniSM
    JO
    Three Touring
    yes dear, EGR, MAF and MAP cleaned all togother, also OIL valve and the avg MPG is just at 35MPG, good but not enough :)
  12. audiodave
    audiodave Active Member
    800
    272
    US
    mjoo likes this.
  13. Mendel Leisk
    42,296
    That smell of gas could be a good clue, maybe. It's running rich for some reason. Has anyone mentioned the Oxygen Sensors: there's two of them in the exhaust, one before and one after the catalytic converter. They would likely show a warning light and code if they were out of parameters, but maybe they're just on the edge, not quite failed. I am just guessing though.
    MomaniSM likes this.
  14. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    I had a smelling gas problem in another car, it turned out to be a bad fuel pressure regulator.
    MomaniSM and Mendel Leisk like this.
  15. MomaniSM
    JO
    Three Touring
    Did you check my test log by Tourque, can you tell if it show like you guess?
  16. Mendel Leisk
    42,296
    Maybe other can glean something, I'm pretty clueless. :oops:
    Raytheeagle and MomaniSM like this.
  17. MomaniSM
    JO
    Three Touring
    Hi folks, it is now three month after cleaned the EGR components and oil valve, now i have the mileage dropped back to 30MPG!
    I feel frustrated of my PRIUS as no known issue with the car, status is:
    HV Battery:Very Good
    12V Battery:Brand new
    Engine:Quite and no oil leackage
    Gearbox: work as first day of purchase
    Air Filter: New
    Exhast: Good
    Air/fuel ratio:0.95
    Sparks: 1 years old, how to check
  18. Lightning Racer
    239
    321
    Anchorage, Alaska
    What I forgot to add here might very well be the problem. The EVAP system vacuum switching valve (also called purge valve) was also sticking open sometimes, letting in unmetered air leading to a lean condition. So check that valve. It's the same thing discussed in this thread:
    Engine behaving strangely and popping hoses off intake manifold | Page 2 | PriusChat
    MomaniSM, audiodave and Mendel Leisk like this.
  19. MomaniSM
    JO
    Three Touring
    Thanks a lot for mention that, can i check whether i have this problem using techstream?, or if ECU throw error code or high/low value near to threashold?
  20. Lightning Racer
    239
    321
    Anchorage, Alaska
    @anonymous described testing with a 12V battery in that thread (post #30) to see that it was sticking. I don't have my Prius anymore, so I can’t double check, but I remember the valve being easy to access/in my face when cleaning the EGR circuit. Maybe you just need the airbox off to access it? I never played with it myself - just recalled seeing the fault described in the Toyota service records from before my ownership.
