prius 2016 Navigation Unit
Discussion in 'Gen 4 Prius Audio and Electronics' started by Mehdi Tabesh, Jan 7, 2017.
  1. Mehdi Tabesh
    Mehdi Tabesh New Member
    iran
    Hi
    i recently purchase Toyota Prius 2016 GCC spec in UAE , DUBAI that have Multimedia Navigation that i want to update it
    i check on update setting Model ID is 13TDANME-DA03
    and Audio is 01014E
    is anyone know how i can update it? on internet i see a picture on Menu they have Multilink Icon but on my car i do not have it and also want to know can i have more feature if i update it?\
    regards
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    My 2016 Prius in California has a navigation receiver assembly (also called the “Entune Audio head unit” in the U.S. market) with different Model ID, 13TDANNA-DA11; I assume “NA” and “ME” indicate versions for North America and Middle East.
    The basic procedure for updates could be similar, however: connect a USB flash drive with the updated software to the vehicle’s USB port, go to Setup > General > Software Update > Update, and then select Update Software.
    For U.S. vehicles, there is a Toyota Service Bulletin, T-SB-0103-16, which lists the software versions and bug fixes, but I wouldn’t expect that software to work with your system, since the hardware is probably different, with a tuner for DAB rather than the IBOC (“HD Radio”) and XM satellite radio available here.
    I’m afraid I don’t know where, other than a dealer, you could find updated software for the ME version or information about what fixes or features might be included in the update.
    If you’re looking for MirrorLink, though, have you tried connecting your device to the USB port first? One manual I found for the European navigation system implies that the application only appears after a compatible device is connected.
    Mehdi Tabesh and RCO like this.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
  4. Mehdi Tabesh
    iran
    Thanks so much for good information .
    I have samsung galaxy s7 edge and when i connect with usb cable nothing is show on car dvd unit . Should i do something on phone for multilink icon apears on car dvd?
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    The USB connection is for use to link a music source etcetera into the head unit, but it will not recognise the phone as a phone. To do that, you will have to pair the Bluetooth link between the car and your S7 Edge. Hope that helps you a little more. If you have any music stored on the phone, the car should be able to access it.
  6. Mehdi Tabesh
    iran
    Hi. Yes i already do that .and on source i choice bluetooth audio and it play my phone music.
    I look for a method to screen mirror my phone to car dvd so can have navigation on my car. Becuase there is no DVD MAP for GCC
    Regards
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Hi to you also. Sorry to say there is no simple way to do that and has been much discussion about the problem in another thread. There is an American company that sells a modification kit to do that kind of thing. I'll have a look around and see what I can dig out for you, but I'm not sure it will be available outside USA.
    Hang on anyway, somebody will chip in with something in time. Time zones affect who's on and when.
    Mehdi Tabesh likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sorry Mehdi, but I couldn't find the thread I was looking for. However the two links below may be of some use till the answer you're looking for comes up. If I find it later I'll come back to you, but don't build your hopes up too high, if you know what I mean.
    How to use 'Off Line" Navigation | PriusChat
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Thanks Sooner AI. That's exactly what I was hoping to get for OP. Only wish the manufacturer had a base in UK.
    #10 RCO, Jan 26, 2017
    Mehdi Tabesh and Sooner Al like this.
