Prius C: faulty fuel gauge
Discussion in 'Prius c Main Forum' started by eggwah123, Jan 30, 2014.
  1. eggwah123
    eggwah123 New Member
    My Prius C got a faulty fuel gauge and suddenly lost power in the middle of the road. Very dangerous situation. Anyone have the same issue?
    Please see this post for details:
    Prius C hybrid system failure | PriusChat
  2. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    I have not had this issue. My only gripe about the fuel gage is that it never shows that it is completely full. This is apparently common on the C.
  3. clgutierrez
    clgutierrez Junior Member
    51
    17
    Mine (one a half year old) always showed full when filled up, however the last two fill ups left one pip not lit. That coincided with using a specific gas station not tried before that seems to pour the gas too quickly.
    Maybe that is the issue you are experiencing?
    Sent ?
    ztanos likes this.
  4. vernon birdman
    330
    141
    Vernon BC Canada
    It doesn't seem to matter what station that I use (or even if in Canada or USA). It showed full for about the first 5 or 10 fill ups and then would only show one line below full since. My c is now nearly 2 years old.
  5. orenji
    orenji Senior Member
    5,884
    3,486
    Maybe you need to top the tank off, try filling it slowly.
  6. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Not seeing how a faulty fuel gauge and loss of power are linked. Unless the faulty gauge led you to believe you had gas in the tank when you really didn't? Seems like they're two separate issues.
  7. ewaboy
    ewaboy Active Member
    693
    205
    Hawaii
    Mine shows top line sometimes - other times it shows one below. Stopped worrying about this - happens at random and the amount of gas going into the tank is pretty much the same.
    I try to go to only one station in the neighborhood - I can't remember the last time I filled up at another station. Then again - I can barely remember my last fill up...:D
  8. Carrollights
    Carrollights Member
    56
    48
    WV
    I find that the fuel gauge will be one bar from full when the weather is colder and when the temp warms up and I fuel up all bars are lit
    ewaboy likes this.
  9. Phil 29 Palms CA
    119
    44
    Twentynine Palms, CA.
    I am retired and drive few miles a month. I purchased my Prius C 2 (moonglow) 7-21-12. I have only 2,472 miles on the odometer. I refuel about once ever 2 months. I time my refueling when the top 6 fuel light bars are OFF and the 4 bottom bars are ON. At this time, I put exactly 5 gallons in the tank. I know using this method my tank never over flows and when I leave the gas station I always have 10 fuel bars ON. I never had a problem not having 10 fuel bars ON after refueling... My average MPG for 2,472 miles is 61.8 MPG. I love my little car!
  10. ewaboy
    693
    205
    Hawaii
    Your technique for consistent fill ups seems sound. Next time I'll try to fill up before the last bar blinks and see if it makes a difference. I usually wait till the last bar but I've had occasion to fill up before that and it may be those times when all ten bars lit up. Thanks. (Just hit 20,000 miles - just short of two years). I retired in October - I'll see if I drive less - maybe I'll check my Fuelly stats.
  11. mahout
    mahout Active Member
    655
    116
    NC
    Depending on the wiring circuits it is possible for no fuel level indiacted can cause the engine to shut down. No gas is a serious concern for the injectors for example.
    As for the fuel gage not showing full after a time the float can be compromised such that it really isn't able to rise with the gas or you really aren't filling the tank. Try at least once to fill the gas til the gas overflows and see if the display reads full.
  12. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I always wait until empty (as verified by my fuelly account) and I have never seen the fuel gauge not show 10 bars when full.
    Fahfoofnik likes this.
  13. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    When my c was new it would normally show all bars when I filled up, but since then the top bar rarely lights.
    That said, on my most recent fill up at a recently renovated petrol station, it at first only lit 9 bars, but by the time I got home it was at 10 and it stayed there for about 50km of driving.
  14. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    I have driven my C4 for about 22k miles and typically fill the tank at 2 bars or just after the display switches to 1 bar. The fuel gauge has always displayed the top bar after filling. I always drop the auto lever in the fuel nozzle to the lowest flow rate when the tank is nearly full. The faster fuel flows into the tank, the quicker the auto shut off will trip. I never attempt to add more fuel after the nozzle shuts off automatically.
