Prius Eco 58 MPG vs Prius 54 MPG - What's the difference?
Discussion in 'Gen 4 Prius Fuel Economy' started by cyclopathic, Nov 18, 2015.
  1. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Out of curiosity I just checked Tire Rack and today's price on the 195/65-15 Energy Saver A/S is $113 each, with a $70 rebate on a set of four, so in effect $96 each.
    TR shows several flavors of the Ecopia 422+ but they all sell for around $87 +/- $2, at least today.
    Maybe tire prices fluctuate like the stock market?
  2. galownia
    galownia Previous master neon mechanic
    117
    73
    bwilson4web likes this.
  3. tzx4
    tzx4 Active Member
    164
    148
    I am skeptical about this one. My Two Eco has a rain sensor on the windshield behind the rear view mirror. That is a feature reserved for higher level models. I suspect all the windshields are the same on all models, and Toyota is just mentioning it when talking about the Two Eco for marketing hype purposes.
  4. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    That is not a rain sensor, it's a sensor for the climate control system. See post #27 here:
    What is the plastic thing on windshield? | Page 2 | PriusChat
  5. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Is it worth getting a higher trim model than the base 2 just to get the Lithium Ion battery? Do I get more cargo space?
  6. bisco
    51,939
    the 2 has a spare, so the floor is raised a bit. 2 eco = no spare, lower floor. 3's have a spare, so you have to go to a 4, for more cargo space than a 2, and same as a 2 eco.
  7. Mendel Leisk
    41,459
    Some 2Eco owners are reporting really good mpg numbers. Personally, I wouldn't want to give up the spare and rear wiper. I think the 2 has less or no white interior trim too. I
  8. MikeDee
    1,580
    597
    I thought the Prius 3 had a lithium ion battery?
    A spare is nice, but how many people check the air pressure in it. The tire has to be taken out to do so. I'm on the fence about the real world usefulness of a spare tire. It's not much good if it's flat.
  9. Mendel Leisk
    41,459
  10. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    For an extra $500, the Two Eco gives you Li-Ion and more cargo space. I have added a space saver spare to mine with no compromise of cargo space. I never used the rear wiper anyway on my previous cars so I didn't lose anything noticeable.
  11. vince22
    vince22 Active Member
    205
    249
    califorinia
    $500 more not only lithium ion battery + 3 doors smart key, not worth $ = navigation system.
    #211 vince22, Apr 3, 2016
  12. bisco
    51,939
    the batteries are the same size, it's the spare that makes the cargo space larger or smaller.
  13. MikeDee
    1,580
    597
    I guess what I'm really asking is if the lithium ion battery has a higher capacity than the NiMH battery so that it can store more regeneration energy?
  14. bisco
    51,939
    no, we don't really know the difference. i believe it's lighter. i don't think it produce's more mpg's, but it's hard to be sure.
  15. Tideland Prius
    16,559
    It was designed to save weight, while providing the same output as the NiMH. The picture below states it has a smaller capacity (3.6Ah vs. 6.5Ah). Compared to the Gen 2 and 3, I've noticed the Gen 4 with Li-Ion tends to be more eager to use the battery and it's quicker to top up the battery. I see 2 bars in the Gen 4 more often than in the Gen 3 but yet it doesn't need to idle the engine to charge the battery.
    JohnF, krousdb and bwilson4web like this.
  16. bwilson4web
    16,217
    What is "Hyper-prime nickel"? It is registered as a trade-mark but I can't find any technical descriptions.
    Having disassembled an NiMH battery, the smooth metal surface has struck me as a problem limiting energy density. A nickel powder surface or mesh would significantly increase the surface area and improve density.
    JohnF likes this.
  17. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    My Three model Prius has the same brand and size tires as the Two, and Two Eco that I saw on the dealer lot.
    15" Toyo Nanoenergy A29. Low Rolling Resistance.
    The driver's door placard inflation numbers for my car are: 36 front; 35 rear? Same tire as the Eco model, but the Eco recommends a PSI of about 3 or 4 pounds higher. So I guess there's nothing "special" about the Eco tires. I've increased my inflation pressure, so now I can pretend I'm driving the Eco. :cool:
    (As of the last fuel-up, I averaged an excellent 60.3 mpg.)
    #217 Coast Cruiser, Apr 4, 2016
    Blizzard_Persona likes this.
  18. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Is there an error in that graphic? It says that the new Li battery weighs 324.5kg, which would be over 700lbs!!! Maybe the decimal point moved over? Is there some other place referencing the weight of the new Li battery so we can do a cross-check?
    I think I read somewhere else on this site that there were other differences between Li and NiMH, is my memory correct?:
    (1) Li can be used over a wider range of its SOC (State of Charge) than NiMH, so more of its capacity is usable.
    (2) It can accept higher rates of recharging (and discharging).
    If true, both of these might help explain why a smaller capacity Li battery would do the same job as a NiMH?
    #218 JohnF, Apr 4, 2016
  19. MikeDee
    1,580
    597
    Interesting. I'm not really liking that huge capacity difference though. I'm skeptical that the Li-ion battery would deliver as good a mileage, acceleration, and life as the NiMH battery would.
  20. bisco
    51,939
    it's been fabulous in pip 1 so far. and all the other manufacturers using it.
