prius hv battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wilsid, Apr 3, 2017.
  1. Wilsid
    Wilsid Junior Member
    91
    I have battery out and checked voltage 7.5. car won't start 4 lites on dash come on, am going to clean
    buss bars. can anyone think what else I can do while I have this out?
    when I turned car on today, engine came on for a few seconds and had about 5 or 6 blue
    bars, then shut down and had 1 purple bar.
    THANKS
    #1 Wilsid, Apr 3, 2017
  2. Wilsid
    91
    these bars are really corroded. in the muriatic acid for 2 seconds there clean,then i use
    my wifes green pads I shine them up. I don't think a shop would this, they would sell you
    another battery. I should have done this a yr ago.
    52,692
    how many miles on her? are you going to load test, replace bad cells and rebalance?
  4. Wilsid
    91
  5. Wilsid
    91
    140,000, all the cells have 7.5 volts,how do I load test,or charge it? doesn't seem to be any bad cells.
  6. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You can load test individual modules ( a module has 6 internal cells) using an automotive halogen headlight (use both filaments) and measure the voltage without load and after the load has been applied for 30 seconds. A weak module will exhibit a larger voltage drop than the others. Your other alternative is to put a load on the whole string of 28 modules using the newly designed load box that can be purchase with (or without) a Prius battery charger/maintainer that is available on the Prius Chat store and then look for weak modules.
    JeffD
  7. JC91006
    16,923
    8,634
    You don't think just using the high or low filament would provide enough load?
  8. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A higher load just works better. Our HV batteries can see loads of up to 130 amps (100 amps in older Gen2 Prii) in use.
    JeffD
    JC91006 likes this.
  9. JC91006
    16,923
    8,634
    Is this even enough of a load to identify problematic modules? I see people use this light bulb as a load but as you said, while in the car, the loads are much higher
  10. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Both filaments in parallel will draw a load current that is a large fraction of 6.5 amps - the rating of our 7.2 volt modules (called a 1C load). This has successfully identified weak modules for several Prius owners dealing with HV battery problems.
    JeffD
    JC91006 likes this.
  11. JC91006
    16,923
    8,634
    Good information, thanks professor
  12. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Any additional info on this new load box; looked around the store and only found the charger.
    Raytheeagle likes this.
  13. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    PM jeff652 to get current information on his products. His old discharger was just a simple unit with two light bulbs. He has a new automatic discharger which should be available shortly (I thought that it was already available for sale - see Prolong Battery Discharger testing | PriusChat ).
    JeffD
  14. Wilsid
    91
    did the two filiments and got 7.5 on 2 cells,7.3 on 1 and 7.4 on the rest, no load 7.5
  15. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    I think your better off getting a mini vci and driving the Prius looking at real-time live data.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    It's the box I had at the meet up;).
    But @jeff652 can handle the details.
  17. Wilsid
    91
    put battery in car started right up,all lights or off except red triangle
  18. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    What made you pull the HV battery out of the car? Was it the lights? What made you think the lights meant it was the HV Battery that was at fault?
    The new box is a discharger, I don't think it can monitor the voltage drop on each module. Better way is to monitor the HV Battery with Techstream while driving the car observing and/or recording charge and discharge loads.
    #18 dolj, Apr 7, 2017
  19. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes, but it is an automatic "smart" discharger which means that it is unlikely to discharge the HV battery too far (as long as the battery is reasonably balanced). You are correct that to use it for a load test, you need to monitor the 28 module voltages during discharge and Techstream (MiniVCI for low cost) is a good option. Monitoring while the HV Charger/Conditioned is charging is not very useful as the charging current is relatively low to avoid overheating the battery.
    JeffD
  20. dolj
    dolj Senior Member
    8,631
    4,385
    I wasn't meaning to use Techstream to monitor the charging/discharging using the Prolong charger/discharger. You wouldn't be able to do that as the car would be OFF. What I meant was to monitor the battery while driving observing current flows in realtime. I have edited my post to say that.
