prius not starting or going into ready. no ecu codes
Discussion in 'Gen 2 Prius Main Forum' started by rzk, Apr 12, 2020.
  1. rzk
    rzk Junior Member
    49
    washington
    my 09 prius is troubling me. i was driving and i came to a stop. when it time to move, i pressed the accelerator and i heard a grinding noise coming from left side under hood and car will not move. no power to wheel to move it forward. when i heard the noise, i let off the pedal and it move gradually by itself like 2 to 5 mph till i get it to the side of the road and i turned it off. i let it sit for a bit and i tried to start it again . it started just fine and run fine until i put the car in reverse or drive gear it starts making the grinding/rattling noise.
    i towed the car home. next day i went to try to start it . all the light comes on but it will not start or go into ready. i check ecu with code reader and there are no codes
    what could it be. any direction to figure this issue please share your inputs. i hand crank or turn the engine and it turn just fine.
    there is enough coolant in both reservoir and there is good oil level in engine.
    thank you
    52,862
    test the 12v health, check the inverter pump, get tech stream. how many miles on her?
  3. ChapmanF
    19,033
    I wonder if it's possible for PriusChat to add some kind of filter activated by the "post new thread" button, that checks for phrases like "there are no codes" and displays a list of existing threads about the importance of getting a code reader that can retrieve the Prius codes?
    SFO, dolj and Elektroingenieur like this.
  4. dolj
    dolj Senior Member
    8,648
    4,398
    Wellington, New Zealand
  5. rzk
    rzk Junior Member
    49
    washington
    yes it is . a new problem
  6. dolj
    dolj Senior Member
    8,648
    4,398
    oh, ok. I had such a sense of déjà vu reading this new post.
  7. rzk
    rzk Junior Member
    49
    washington
    dolj, sorry for my first answer. yes this post is the same as you referred to. i posted it first and i realized i posted it in the wrong top folder.
  8. rzk
    rzk Junior Member
    49
    washington
    update. Mechanic shop said, the aux battery is charged and has above 12 volts. the scanner doesn't show any code but it says battery low voltage and battery air. now looking to find a way to charge the big hybrid battery but what could be a cause for the hybrid batter not to charge or drain?
  9. bisco
    52,862
    are you reading and following the advice above, or just posting every time something new occurs?
    'above 12 volts' is not a verification of a good battery.
    what scanner are they using?
    do you need a hybrid aware mechanic?
  10. rzk
    rzk Junior Member
    49
    washington
    update. i got some codes
    P0AD0
    C1241
    C1259
    C1310
    P3102
  11. rzk
    rzk Junior Member
    49
    washington
    yes i do need a hybrid aware mechanic
    i live in Elma, Washington
  12. bisco
    52,862
    check your other thread
