Prius Prime oil change frequency?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by scm2000, Aug 12, 2017.
  1. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    In your case, you still have fewer cold starts than with a non plug-in Prius. But not drastically fewer, like some people who average only one or two cold starts per week. What would be your impromptu estimate of cold starts per year?
    For simplicity's sake, I am making the same assumption that most manufacturers make when prescribing X months or X miles: That the "cold" cold starts in winter roughly balance out the "warm" cold starts in summer, plus a margin of safety.
    Admittedly, counting cold starts is a crude and imprecise rule of thumb, but I think it is more accurate and sensible than just counting months for plug-in hybrids which can have tremendously different duty cycles within the same time period.
    Salamander_King and Rob43 like this.
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Right now with the Covid-19 situation, I have no daily commute. But in the past, I did one cold start a day during warmer months when I drove mostly on EV but the engine aways came on after I depleted EV range on my way home from work. During colder months, the engine was forced to come on both ways due to the inability of the heat pump to generate heat or use of the defroster. I would say on the average 5 months of warm and 7 months of cold, and 5 days/week x 52weeks plus 1 cold start on weekend x 52 weeks. That makes 362 cold starts/yr compared to your 600 cold starts/yr, making it possible to stretch the oil change interval to ~16kmiles or every 19monts.
    But lately, I have been doing most of my drives EV mixed with HV intentionally to make the EV range longer. This makes the cold start number very close to regular hybrid. Thus I will stick with the Toyota recommended 10K or 1-year interval for my oil change.
    #62 Salamander_King, Jun 22, 2020
    Fred_H likes this.
  3. JoePriusPrime
    JoePriusPrime Member
    46
    35
    Denver, CO
    Hi All,
    I agree with Salamander that we should stick with Toyota recommended 10k or 1 year because when it's time to sell, having a consistent maintenance Carfax record will only help your resell value. Now we can argue for days about at what mileage does the oil break down.
    Motor oil does not actually break down, its main function is to pick up dirty particles and carries it to the oil filter where it becomes trapped. Once the oil filter is full of particles, the oil looses its ability to clean the engine. You splurge for that full synthetic Mobil 1 Annual Protection 0w20 guaranteed up to 20k miles but dealer probably put the cheapest oil filter along with it.
    What I want to know is how dirty the oil filter is at 20k miles. A really good resource is a youtube channel called "project farm" this guy did independent analysis and held an oil championship on 16 different types of full synthetic motor oil. Fun video to watch and Mobile 1 was not the winner, not even close.
    #63 JoePriusPrime, Jun 29, 2020
    Fred_H likes this.
  4. JoePriusPrime
    46
    35
    Denver, CO
  5. Fred_H
    562
    488
    28
    Germany
    For many people, that's a perfectly good reason to to follow the manufacturer's maintenance schedule. For a few people like me, who keep their cars much longer, it doesn't make much difference.
    Yes, a good base oil itself hardly breaks down, but the vital anti-wear and anti-corrosion additives become depleted as a direct result of how they function. Generally, the anti-corrosion additives tend to be used up more as a result of cold starts, and the anti-wear additives tend to be used up more from running under load.
  6. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    Quick update.
    I finally decided to replace my 2017prime oil yesterday at 30k myself. My last oil change was done by dealer at~20k. My commute is about 12 miles each way so my prime runs >90% in electric. Also I purposely run the gas tank to empty in summer with AC on 100% before putting a fresh tank. Total 2 full tanks were used.
    Before replacing my oil, I have checked my oil level and oil color on my dip stick. It is like new. However, after I drained my old oil, it looks very dark like after 10k miles. See photo.
    My take is Dip stick only showing the oil level and don’t use it to judge oil life. My oil already showing some wear and I’m glad I replaced it. Just one less thing to think about. :)
    iPhone ?
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I'm confused - did you have the oil tested to show it was showing "wear"?
  8. Red Ruby
    Red Ruby Junior Member
    Washington DC
    2020 Prius Prime
    I just went to my 12 month maintenance, and the dealer told me "we didn't change your oil because it's fully synthetic and needs to be changed only every 10k miles". So all they did was topping fluids and rotating tires.
    I'm feeling that they were just being lazy? Anyone else ever run into something like this? It doesn't really bother me, for all the reasons discussed in this thread and since I'll wave their paperwork at them if there's ever a warranty issue ... but still ...
  9. Mendel Leisk
    42,273
    Toyota USA says 10K miles or 12 months, whichever comes first. Seems your dealership "knows better"?
    FWIW, Toyota Canada, with our 3rd gen, says change the oil every 6 months or 8K kms (roughly 5K miles), again: whichever comes first. We're only putting on 4~5K kms yearly, and I'm still adhering to that.
    m.wynn likes this.
  10. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Does anyone else think the dealers are unhappy about having to do the 2 years free?
    I mean how much was a 2012 Prius 4 and what did it's service schedule look like cost wise over a year on average.
    But wait, I see that a new study is saying the hybrids are doing more damage to the environment than regular gassers. SUV's and Trucks !
    Gotta wonder how much they charged for that study.
  11. alanclarkeau
    7,045
    7,593
    The "new study" is only talking about Plug-In Hybrids - which aren't ever plugged in, but bought for the "perks" only.
  12. vvillovv
    4,336
    1,518
    NY
    I met one of those at a chargepoint. Couldn't care less about the pack since it was gonna get traded in after 2 years. Sad. Is it the same down your ways? throw away society.
  13. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    I’m guessing Toyota reimburses the dealer for the free maintenance.
  14. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    It's still a used PHEV on the market in two years that wouldn't otherwise be available. They probably can't do much damage in two years.
  15. Red Ruby
    Washington DC
    2020 Prius Prime
    Thanks. Can't argue with anything you wrote! They texted me to ask if I was satisfied with service, and I wrote back asking about this. Silence ...
  16. Mendel Leisk
    42,273
    Those emails/texts maybe are automated, virtually bot driven?
    Maybe nothing nefarious, just too hard for them to track miles AND months? The car's maintenance reminder is a dumb counter too, doesn't help.
    vvillovv likes this.
  17. RJC
    RJC Junior Member
    Mishawaka IN
    For warranty are the oil changes the main thing to worry about? The schedule has services every 5K where they just check floor mats, fluids and "visually" check the brakes. With my 13 Prius C, I did Toyota Care for the first 2 years and then one of the dealer service guys told me i didn't need to bring it back until 10K miles as long as you use the synthetic oil. That is all I have been doing. Am I correct in thinking that the 6 month checks in between the oil changes are a rip off as long as you check the fluids yourself? I just bought a 21 Prime and am rethinking my maintenance strategy.
    Out of curiosity anybody know how much the 30K/60K service is?
  18. Salamander_King
    11,024
    8,977
    New England
    Yap, it is basically a rip-off. The 30K service does have a few other things like engine filter and cabin filter, but the dealer will charge a lot more than the cost of the parts. Typical 30K service in my dealer if I just let them do everything would be anywhere from $300 to $500.
  19. Wills Prime
    Wills Prime New Member
    What do you guys think about checking the oil/filter every 5000 miles? Or is it a waste of money?
  20. vvillovv
    4,336
    1,518
    NY
    @Wills Prime it depends. If you drive mostly EV than yes it probably a waste of money. If you drive a 50 50 mix of EV/ HV than every 10k oil change is like every 5k oil change in a regular gasser.
    But if you drive mostly HV, than yes every 5k is a good idea, in my opinion.
