Prius Prime Oil Filter - how come there are two options for the Prime?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Steven Chavez, Dec 6, 2018.
  1. Prodigyplace
    12,562
    11,778
    Central Virginia
    In my personal experience FRAM is junk. Their air filters had noticeably less filter material. When I switched away from FRAM oil filters I noticed the oil looked much cleaner when changing. They may have changed but for me it is not worth the risk.
    Georgina Rudkus likes this.
  2. Laura-Ann
    Laura-Ann Junior Member
    31
    16
    Sacramento, CA
    2019 Prius Prime
    This also works on my 2019 Prius Prime. You have to get your head right down on the ground, as close to opening between the wheel well and the tire as possible. The view is partially obstructed by suspension components, but you can see enough of the filter to determine if it's a spin-on, or the replaceable paper element type. My car has the spin-on type, fortunately.
  3. DOHCtor
    DOHCtor Member
    162
    93
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Personally i went with another filter altogether. 90915-YZZF1. Same thing as a F2 (now labelled N1 mind you..) but a bit longer, holds about 50ml more oil (meh..) but more importantly for me, has more filtering media/capacity. The only difference is length. Same bypass spring tension, same everything but it holds a bit more oil and it has more filtering material..
    EDIT: Fram is junk but their Ultra line is excellent.
    #63 DOHCtor, Oct 6, 2021
