Prius Prime Plus in my hands
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jan 19, 2017.
  1. Prodigyplace
    12,710
    11,848
    Central Virginia
    True, but parts of the dashboard are shiny black. I believe the decals are shiny too.
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    This small display does not show %SOC but rather % of full charge (software full) there is an upper buffer between 100% full charge and 100%SOC.
    JamesBurke likes this.
  3. bwilson4web
    16,517
    As long as all Prime are using the same scale, I see no problem. The 'head room' SOC is not usable.
    In an ideal world, I would have a 'trip meter' that reports something like kWh used over a given distance. That may exist in the Prime but the BMW i3-REx tripmeter, only one, is built around it with Teutonic precision.
  4. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Did you see this thread from a few months back Bob?
    Prime's Charge Mode - Fast Charge? | Page 3 | PriusChat
    New to me feature "Quote between threads or just partial message text".
    bwilson4web likes this.
  5. bwilson4web
    16,517
    More seat time today, I found the nav option that enables reading speed signs.
    Sad to say the manual describes how to reset the TPS after fully inflating the tires . . . the instructions for my Plus (lowest level) are wrong. This justifies registering the car with 'My Toyota' and opening a case.
    Prodigyplace likes this.
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Bob, how did you make this plot from the certification data? I can't see any data in that spreadsheet from which I could derive the above plot.
  7. bwilson4web
    16,517
    A work in progress, I reduced the spreadsheet to the data table and graph:
    The spreadsheet has one flaw I plan to fix (see columns S and T.) I have the roll down coefficients but only use the single set of coefficients in S5:T13. So all cars get "40%" thermodynamic efficiency and "600W" overhead. All of these parameters need to be put under the vehicle specific, roll-down coefficients and adjusted for the specific models. It is particularly obvious with the Gen-3 graph. But this much we know:
    • Gen-4 and Prime - improved engine efficiency from ~38% to ~40%
    • Gen-4 and Prime - improved transmission efficiency substantially
    • Gen-4 and Prime - I suspect have lower vehicle overhead than the Gen-3
    I suspect that if we can get accurate metrics, we can find the performance curves match the observed benchmarks. Regardless, enjoy the spreadsheet.
  8. Lee Jay
    5,850
    4,036
    Oh...okay, so no bsfc or efficiency maps can be derived from this spreadsheet - you essentially assumed one.
  9. bwilson4web
    16,517
    Actually I used values previously reported by Toyota and my own engineering estimates. The PRIME curve pretty well fits two data points at 28 mph and 60 mph. I have one Gen-4 data point for the Level 3-4 and a more extensive set for the Gen-3. So I'll adjust the coefficients to match the benchmarks.
  10. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Congrats Bob
  11. bwilson4web
    16,517
    Ok, fixed the spreadsheet:
  12. Prodigyplace
    12,710
    11,848
    Central Virginia
    I must not know how to read that. Is it saying the 2 ECO gets over 110 mpg at 20 mph?
  13. bwilson4web
    16,517
    Based on the spreadsheet model:
    • ~122 MPG @21-22 mph - Level 2 ECO
    • ~115 MPG @20 mph - Prius Prime
      • 105.5 MPG @28 mph for 10.5 miles
      • 55.7 MPG @60-65 mph for 1,200 miles
    • ~105 MPG @25 mph - Gen-3 Prius
      • 99 MPG @25 mph, limit of vehicle meter
  14. bwilson4web
    16,517
    After a cold soak to 32F and having filled the tires on Sunday, I tried my local roll-down slope. The car was doing 14 mph when I reached the stop sign. This suggests the Prime has unusually low rolling resistance ... very nice!
  15. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    yes
  16. EV-ish
    602
    278
    SW US
    Engineering magic, pure and simple
  17. Lee Jay
    5,850
    4,036
    Bob, have you seen a thing like this for the 2016+ (4th generation) with all the improvements to get to 40% thermal efficiency?
    giora and EV-ish like this.
  18. EV-ish
    602
    278
    SW US
    Just as impressive, or perhaps more, is the expanded 230 gram/kWh island.
  19. Lee Jay
    5,850
    4,036
    That was for gen 3 (2010).
  20. Lee Jay
    5,850
    4,036
    The only thing I've seen is this:
