Prius Tire Reviews
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by AldoON, Jul 14, 2020.
  1. AldoON
    AldoON Member
    108
    Milton, ON
    2018 Prius Prime
    Upgrade
    How about a thread to review tires that you have tried on your prime.
    Should be useful for people looking to replace their tires.
    • Include tire brand, model and size
    • Include tire type (summer / winter / all weather)
    • How long you've driven on the tires
    • Short review with useful comments.
      How do they handle? Effect on fuel economy? Durability, etc.
  2. AldoON
    AldoON Member
    108
    Milton, ON
    2018 Prius Prime
    Upgrade
    To start it off, I just got new tires last weekend. Old ones were in rough shape... I bought the car used so I can't comment on those.
    New Tires:
    • General Evertrek RTX, 195/65/R15 (purchased at Canadian Tire)
    • Summer Tire
    • Driven on them < 300 km
    • I bought these because they are not expensive and perform well in wet/dry conditions. I had the same tires (different size) on my old car for about 70,000 km until I sold the car and was happy with them. On the prime so far they feel a bit soft. Also there seems to be a big hit on fuel economy. I used to be able to regularly drive 53 km on one charge with the old (stock?) tires. With the new ones I can't seem to get to 50 km on one charge. I'm hoping this will improve once the tires break in.
      I'll post an updated review after I've driven on them for a few months.
  3. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    • Blizzak WS80, stock size on 15 inch steel rims
    • Snow tires
    • Wore out after around 9,000 miles total in two seasons (6/32" is the legal minimum for tires in Colorado in the winter, and snow tires don't work well below 6/32" in snow anyway)
    • Noisy. Very soft tread. Slight decrease in EV range (maybe 10% less than with LRR all seasons). When new the front wheels often spin on dry pavement. When broken in it's less of a problem. Winter grip was fine when new, but nothing special. At 6/32" I felt the car starting to lose traction in a straight line at higher speeds a couple times, which is concerning. Maybe I just encountered unusually bad road conditions. 0/10, would never buy again.
    AldoON likes this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Haven't had to buy any new set of summer tires for my PRIME yet.
    OEM on 2017 PRIME was
    • Dunlop Enasave 01 AS 195/65/15
    • all season (mainly summer)
    • during 27 months after purchase, had them on 23 months 31Kmiles total
    • Excellent mpg on PRIME, not very comfortable or quiet especially after tire worn out. Low tread depth of 8/32 when new and after 31K miles they were 4/32 remaining. I had this OEM tire on my first winter, absolutely not the tire you want to keep if you drive on snow.
    For winter
    • Michelin X Ice Xi3 Enasave 01 AS 195/65/15 on separate aftermarket MB ICON alloy wheel
    • dedicated winter
    • during 15 months after purchase, had them on 8.5 months 8.6Kmiles total
    • Excellent mpg on PRIME no noticeable drop in mpg from OEM. Very comfortable and quiet (better than OEM Dunlop AS tires). Excellent traction on deep snow and packed snow. Not as good on ice as studded tires I have had before. Good tread life, 10.5/32 when new and after 8.9K miles they are 8-9/32 remaining. It comes with 6yrs/40,000 Miles tread warranty. AFAIK, XIce are the only dedicated winter tires on market that comes with tread warranty. When the ambient temp get above 50F, the tires are very squishy and make very high pitch noise even at low speed driving.
    OEM on 2020 PRIME was
    • Bridgeston Ecopia EP422 Plus 195/65/15 (4 ribs OEM tires Made in Japan)
    • I only had this for 4 moths and driven only 1.8kmiles total
    • Excellent mpg on PRIME, reasonably quiet when new. Low tread depth of 9/32 when new. I have not driven long enough on this set of tires to comment on tread life. There are at least three different iterations of Ecopia EP422 Plus on market. They have different specs and are made in either in Japan (mostly OEM) or US or Mexico. I have had both US and Mexico ones on my previous gen3. They are all very good for mpg, but not so good on snow. Aftermarket EP422 Plus comes with 70K miles tread warranty, but my previous sets lasted only 30K. I will see how long this Made in Japan OEM version will last.
    #4 Salamander_King, Jul 16, 2020
    Tips and AldoON like this.
  5. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    That is true, but if you read the fine print it would be almost impossible to collect on that warranty (or any tire warranty), unless your tire shop is generous and makes the decision themselves without the manufacturer being involved.
  6. Salamander_King
    11,024
    8,980
    New England
    Yeah, I know the tread warranty on tires are mostly a marketing gimmick. For most part I don't even expect the full warranty miles on any of regular tires. But just the fact Michelin has the tread warranty on this snow tire brand while no other companies are doing it makes me to speculate that this brand of winter tires may in fact outlast many other competitors. But that's only my speculation. I have no proof or data to compare. I maybe just being gullible enough to buy into the gimmick. lol
    Tips likes this.
  7. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    I think a warranty gives a reasonable idea of the expected life. But I almost forgot, the problem with a warranty on snow tires specifically is that you have to wear the tires down to 2/32" (or at least that's my understanding), and you can also only use the tires in winter months (defined by the warranty), but 2/32" tread is clearly inadequate in winter months.
    At the rate you're going, you'll probably hit 6/32 around 20k miles. That's reasonable for winter tires, and it sounds like they are nice enough to run them in the summer past 6/32 if you want.
    Salamander_King likes this.
  8. Salamander_King
    11,024
    8,980
    New England
    With linear tread wear of approximately 1/32 each winter 4-5Kmiles, I expect Xice to last 4 winters down to 6.5/32 or maybe 5 winters if I go down to 5.5/32. That's pretty good for any tire. I doubt even some long tread life all-season tires with 80K or 90K will last longer than 50K (5 years with 10Kmiles/year) on our chipseal road surface.
