Professional EGR Cleaning Resources
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Oct 5, 2022.
  1. Mendel Leisk
    42,343
    N.J.PRIUS likes this.
  2. ukulelegeek
    ukulelegeek Active Member
    159
    112
    We spoke with Todd at Tampa Hybrids, and he told us of the importance of keeping the EGR system maintained in order to save the head gasket. He does them at 100,000 miles. My Prius had 120,000 miles on it, and this hadn't been done.
    Since we don't live in Tampa, I asked our mechanic if he does this, and he said yes, but he doesn't clean the old parts, he buys new from Toyota. This is how he guarantees his work. I spent just a little over $1800 to have it all done. He saved my old parts and I will clean them. They are totally clogged up with carbon.
    His name is Prim, he works at Dube's Auto in Clearwater, but he doesn't service the hybrid system itself. He worked on our ICE cars for over 10 years.
    There is a shop in Clearwater that does hybrid work, but I've never been there. It's called Green Tech Auto, the manager is Scott. 800-773-6614.
    U Tube has some very good videos on this, I would never consider trying it myself.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,093
    6,960
    Texas Hill Country
    My dealer will do it for $800 with a new cooler. A know a guy who will do it for much less but only if you are an existing customer with a previous repair of some significance. He has a permeant backlog of more important work than just fixing something difficult that is not broke. Dealers will fix it if its not broken if you pay enough.
  4. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    $1800! WOW! Well, as long as he did a good job.
    You should learn to do it yourself. For the money you WON'T spend paying someone else,
    you can buy all the tools and parts you'll need.
  5. Mendel Leisk
    42,343
    I don't want to talk about it... :cry:
    Anyway, next time around, he shouldn't charge you more than about $400~500. Say in 50k miles.
    Tell me he didn't get a new one of these:
    #25 Mendel Leisk, Oct 13, 2022
  6. bisco
    52,847
    if you're making if you're making 400k/year, it's not worth taking time off to diy
  7. ukulelegeek
    159
    112
    Dube's is never cheap. But they are one of the most honest and most thorough shops I've ever used. He does give me a dollar or two off labor sometimes, and there is a discount for not using your bank card.
    N.J.PRIUS and mikey_t like this.
  8. ASRDogman
    8,063
    4,086
    As long are you are happy with him, that's what is important.
    N.J.PRIUS and ukulelegeek like this.
  9. ukulelegeek
    159
    112
    No, he used the old one. Todd at Tampa Hybrids charges a little bit less -$200, and uses all the old parts, takes the time to clean them, but he's almost an hour drive, and I can't hang around in Tampa all day without my wheels.
    Frankly, 1800 was steep, but i don't know how anyone can do this for 500. A shop around here charging that much would probably go broke.
    And I won't attempt it myself, don't have a place to work on my car, and I have a short temper with inanimate objects. One busted open knuckle, and I miss gigs with my band.
    #29 ukulelegeek, Oct 13, 2022
  10. Mendel Leisk
    42,343
    I hear you; we didn’t expect nonsense like this, cleaning up after Toyo…
  11. bisco
    52,847
    most report around a thousand bucks
  12. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I'm at 160,000+ miles with no problems.
  13. Tombukt2
    Tombukt2 Senior Member
    13,857
    2,516
    Durham NC
    Well it's nice to know what people are paying and all that sort of thing I guess. It's a couple hour job if you already got the parts pre-cleaned and sitting in your storage and pretty much have it all straightened out pretty quick but yeah 1800 cool.
  14. Tombukt2
    13,857
    2,516
    Durham NC
    My 13 persona is close to that mileage now . It's on its second engine . The first failed with me driving . Right after I bought the car when I bought the car it started and ran like a brand new Prius and was pretty clean two owners and the two owners live next door to each other in Virginia It was driven down a dirt driveway everyday until I got it. I would have probably not been able to save the first engine. Now that I have the second engine in I should be able to carry this thing to close to 500,000 maybe a tad over if someone doesn't plow into it before The two Z's and Corollas and other cars that are newer say 2010 up all have a similar EGR cooler now I don't know if the Corolla has the clogging EGR passage problem because it's not an Atkinson cycle engine. I don't think anyway. So the Corolla regular 2Z car not the hybrid isn't regurgitating its own puke. Or something along those lines or is it only the two ZFXE hybrid that gets the EGR cooler. The other day when I was looking in a Corolla I don't think it was a hybrid it has the two z engine the EGR cooler and a valve that looks very much like the Prius but the cooler shorter and smaller but I did not go behind the car or look at anything close enough I don't believe it was a hybrid but correct me if I'm wrong about the Atkinson cycle.
  15. Wes_33073
    Wes_33073 Junior Member
    To anyone changing/cleaning the EGR cooler... do NOT take that bottom stud/bolt off the engine block! I was following the official Toyota process for EGR cooler removal/installation. They say to take all 4 stud/bolts off and then when re-assembling, get the EGR cooler back in place before putting the studs/bolts back on. It's damn near impossible to get that one back on with the EGR cooler in the way. They must have pulled the engine from the car before executing this ridiculous procedure. When in doubt, follow the "nuts and volts" video procedure.
    N.J.PRIUS, ColoradoCrow and bisco like this.
  16. ASRDogman
    8,063
    4,086
    That nut and stud are easy to remove and reinstall.
    You need SnapOn 1/4 inch wrenches and sockets.
    Some people do not reinstall the stud or nut.
    aperry1971 likes this.
  17. Mendel Leisk
    42,343
    Why reinstall it? I took it off preemptively, about a year back, left it off.
    see second link in my signature.
  18. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
  19. Mendel Leisk
    42,343
    After a while you don’t miss it…:oops:
  20. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    What the stud!
    Gonna need to wait another 20 years give or take to reach 100k mi, and have to deal with this….
    iPhone ?
