proper resistance on prius battery cells?
Discussion in 'Gen 2 Prius Technical Discussion' started by mobilefleet, Nov 5, 2014.
  1. mobilefleet
    mobilefleet New Member
    got a couple low voltage cells in my traction battery after triangle came on, so I know those cells need replaced. I tested all 28 cells. But what is the proper resistance value I should be looking for when testing the cells?
  2. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    If you are asking about internal resistance then the best way to measure that is to load test them with a headlight (high and low beams at the same time).
    Here's what the load test looks like and how to spot a bad one:
    Gen II Prius Individual Battery Module Replacement | Page 13 | PriusChat
