Question-2025 Prius in EV Mode: Reply quickly!
Discussion in 'Gen 5 Prius Technical Discussion' started by iRun26.2, Jun 13, 2025.
Tags:
  1. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    Question-2025 Prius in EV Mode: Reply quickly! | Page 3 | PriusChat
    Prius drag coefficient cd:
    • 1st Generation: 0.29
    • 2nd Generation: 0.26
    • 3rd Generation: 0.25
    • 4th Generation: 0.24
    • 4th Generation Prime PHEV: 0.25
    • 5th Generation LE/SE (17” wheels with aero covers): 0.27
    • 5th Generation with 19” wheels: 0.29
    The Gen 5 PHEV is heavier, too.
    #81 Gokhan, Jun 25, 2025
    iRun26.2 likes this.
  2. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    OK. I’m sorry if this is an obvious answer to others, but why would the larger wheels have a higher drag coefficient? (It’s kind of disappointing because I love how they look on my car).
    52,855
    perhaps the larger wheel/tyre blocks more air? anyway, toyota chose form over function as a compromise to boost flagging sales.
    a lot of prius people were bummed, but a lot of new users came on board just for the styling, handling and acceleration
  4. iRun26.2
    824
    169
    United States
    I was sold with the 2005 model. In 2012 I got their first plug-in hybrid. This year (2025) I got hit by a deer and had to get what they had (in a plug-in hybrid). I don’t mind the slight lack of efficiency. I love the car! :)
  5. Trollbait
    12,829
    The coefficient of drag is worse than previous, though the shorter roofline leads to a smaller frontal area. Not enough to totally overcome that drag.
    Bigger wheels are bad for efficiency no matter the car. They add weight to the worse spot. The previous Camry hybrid LE got 16 inch steel wheels instead of the 17 inch alloys on the ICE model and hybrids in other markets got because it returned a 50mpg for the window sticker.
    While it has a higher thermal efficiency than the old 1.8L engine, it isn't a large increase in the 2L. The 2L was chosen to increase performance along with favoring aesthetics to improve sales. Despite being more powerful, the gen5 LE is almost as good as the gen4 Eco in fuel economy. The higher trims match the combined rating of the rest of the gen4s.
    Instead of getting the ~10% improvement in ratings seen in past generations, Toyota opted to use advances to keep the ratings where the gen4 was while using any improvements to make a Prius that appeals to more buyers. It disappoints the fans of past models, but the sales of those were heading towards cancellation for the US.
    The wheels don't block more air. The skinny tires block less actually. It is in how the air flows past the wheel with the different spoke designs. It also isn't all in the wheels. The 19 inch tire is taller than the 17 inch. That raises the car 0.4 inches. Doesn't sound like much, but it's enough to have an impact on aerodynamics.
    https://www.toyota.com/content/dam/toyota/brochures/pdf/2024/prius_ebrochure.pdf
  6. Gokhan
    6,714
    2,672
    Paramount CA
    I don’t know for sure, but I think the increased ground clearance increases the drag coefficient cd by creating more turbulence beneath the car. Moreover, larger wheels lack the aero wheel covers.
  7. Trollbait
    12,829
    It also increases the frontal area.
  8. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    You'd need 3 weeks of direct sunlight to charge your battery,
    or you'd need enough solar panels to cover 3 parking spots to deliver a useful charge in a reasonable time.
    No thanks for me, but each their own.
  9. bisco
    52,855
    agree on the fun techie part, but i hate parking in the sun and avoid it if at all possible.
    except in winter
  10. iRun26.2
    824
    169
    United States
    Alas, I have no choice. At my work, there is 0% shade in our lot. I suppose I could park 1/2 mile away and walk but then I couldn’t plug in (my company lets me charge my PHEV at work but… so far I don’t even need to)! The extra couple miles from solar energy then lets me complete my 20.8 mile drive both ways on one charge.
    When it’s raining, I add a little extra charge by plugging in since the driving efficiency goes down in the rain.
    #90 iRun26.2, Jun 29, 2025
    Gokhan and bisco like this.
  11. iRun26.2
    824
    169
    United States
    A little bit each day can add can add up to something appreciable.
  12. iRun26.2
    824
    169
    United States
    My biggest complaints about the solar roof is that the power from the solar roof if apparently not used for anything when the car is plugged in and charging. That seems like a waste.
  13. bisco
    52,855
    it would probably take a more expensive controller, or even a buffer battery to do that
  14. iRun26.2
    824
    169
    United States
    Yes, having two things charging the battery at the same time would probably require two completely different circuits. One is DC and the other is AC, too.
  15. Trollbait
    12,829
    It can put energy into the 12V circuit while the car is running. It should be able to do that while charging.
  16. iRun26.2
    824
    169
    United States
    The manual specifically says the solar roof won’t charge the traction battery while it is charging through the charge port. However, It would be silly to throw that energy away.
  17. Trollbait
    12,829
    Neither will it supply energy to the traction battery while driving, but it can supply to the 12V accessories. Don't see why it won't do the same while the car is plugged in.
  18. iRun26.2
    824
    169
    United States
    Yes, I’d hate to see that energy going to waste.
    I’d like to know if anyone has access to a schematic/wiring diagram for the car. I think I’d pay money to buy one of them. Toyota probably doesn’t let that type of information go to the general public.
  19. bisco
    52,855
    that should be available for download at techinfo.toyota.com with the repair manual. probably around 50 bucks these days, but maybe less, haven't seen anyone mention cost in awhile
  20. Gokhan
    6,714
    2,672
    Paramount CA
    In Gen 5, unlike in Gen 4, when the car is plugged in, the main DC–DC converter is turned on and powers the 12-V system, aggressively charging the 12-V battery. As a result, the solar charger in Gen 5 will not contribute any power to the 12-V system when the car is plugged in.
