Question re: 12-volt battery, please?
Discussion in 'Gen 2 Prius Main Forum' started by Julia2001, Aug 14, 2012.
  1. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Because of this:
    "Whenever a battery is discharged below 12.4 volts and allowed to sit in that state, sulfation will begin to diminish both lifespan and capacity."
    I do not want a battery with diminished lifespan and capacity.
  2. Julia2001
    Julia2001 Member
    290
    32
    Maine
    So I guess maybe the dude who lied to me and told me that he checked and the battery was fully charged did me a favor. Because as you suggest, had he placed it on a charger and topped it off nicely and had he then handed me a fully charged battery, I would never have known that indeed I had purchased a battery of diminished lifespan and capacity a la the Optima representative himself who said...
  3. Patrick Wong
    18,210
    6,526
    If you receive a replacement, how do you know it was not charged by the store before they give it to you?
  4. Julia2001
    Julia2001 Member
    290
    32
    Maine
    I would not know.
    But they did not charge this one, and so I do know.
    Had I known then what I know now, I would walk into a store with my digital multimeter! :cool:
  5. Patrick Wong
    18,210
    6,526
    I'm just impressed that you actually own a DMM.
    OK then, you'll call the store, ask for a replacement, and the manager will argue with you about whether the battery was impaired by being at 12.4V for a period no longer than 2 months. Then he'll give in and say the replacement will be available the next day.
    They'll hook up the battery to a 10A charger, charge it up, then call you and say it is ready. You'll bring your DMM, measure voltage at 12.9V, and be happy. Then you get to install the new battery a second time and will become really good at that process.
    edthefox5 likes this.
  6. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    snopes.com: Do Cement Floors Ruin Car Batteries?
    Apparently way back in the day they used rubber casings for batterys and you could discharge a battery by setting it on a conductive surface. Guaranteed that no modern battery is made that way anymore.
    And converse to your concrete in freezing temps example, here in the extreme south putting a battery on a cool concrete floor (say 75 degrees) might be better for it than putting it on a shelf in a 90+ degree room.
    As to your prior post asking for updated values on my battery after normal use I'll be glad to grab some numbers tomorrow and update the thread afterwards. I'm not going to bother to get out the DMM, I'll just grab some numbers from the MFD since I have my prior readings to compare.
    uart likes this.
  7. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Ok thanks. That will at least give Julia some numbers for comparison. :)
  8. Julia2001
    Julia2001 Member
    290
    32
    Maine
    That would be great...thanks very much. Seeing 11.7-11.9 on the MFD with the new Yellow Top Optima installed is disheartening, especially since my old original battery was prettier on the MFD than that. Have I said that enough times yet? :whistle:
    usnavystgc likes this.
  9. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I would be pi$$$$$ed too, Julia2001. ;) H
  10. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Oh, I am! See? ---> :mad:
    Haha. THANK YOU, HAROLD! (y)
  11. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Ok, I guess I owe a apology or something like that. I have been taught that "old wives tale" by more than one person who was older than I am - currently 56 and counting. I was not aware of the info on snopes.com concerning the difference's in the battery cases. All I can say is I am sorry that my information was not correct. I try very hard to post good information. I do appreciate it when someone can show me a new and better way.
    With all that said, please disregard the information I posted concerning placing 12 volt batteries on concrete. I will leave that one up to the individual who is handling his or her battery.
    Ron
  12. dorunron
    3,318
    1,105
    Houston, TX
    Thank you for posting this, please refer to post #231 for my reply concerning the issue.
    Ron
  13. HaroldW
    716
    95
    Hi dorunron:
    I thought the same thing up to a couple years ago! Still put a block of wood down before I add the old battery when on concrete.. <grin> H
    dorunron likes this.
  14. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Hey...you were trying to be helpful and that is a good thing! I appreciate it very much. We both learned something new!
    And you are a kind and VERY helpful member of PriusChat. I have really appreciated all of your input, Ron.
    Thank you again.
    Julia
  15. dhanson865
    851
    188
    TN, USA
    Hey, I even learned something there :). I've heard that bit about concrete and batteries dozens of times and always wondered why. This thread prompted me to actually do the search and find out why/why not. Since uart already gave you the chiding I just went for the informative response. Honestly given the mood I was in I would have given you the nuetral tone even if uart hadn't chimed in.
  16. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yeah don't worry about it Ron. We all get fooled by those "often repeated yet wrong" stories sometimes. I know that you usually give good information. :)
  17. dhanson865
    851
    188
    TN, USA
    OK so on Mar 12th my results from the MFD were
    12.5 ACC mode
    12.25 IG-ON mode
    Note the above figures are with load, that was literally seconds after reading the battery at 12.94v with a DMM (full charge after 18 hours on a smart charger).
    Typical use of this car is 16 miles each way to/from work but it stopped at the library 2 miles from home so it's last trip before I measured it today was only 2 miles. It also sat a couple of hours before I checked it
    on Aug 24th my results from MFD were
    12.3 ACC mode
    12.0 IG-ON mode
    down .2 to .3 from the full charge but then the last trip was a short one. Not enough of a drop to worry me.
    my factory installed battery didn't cause problems until the display check MFD reading got in to the low 11 / high 10 range. If this battery ever gets that low I'll just put it on the CTEK Multi US 3300 charger that I use by way of the cigarette lighter adapter (no need to open the hatch or hood, I just roll down the drivers window and run the DC cord to the dash and the AC cord to the wall socket)
    Really the Gen II prius doesn't charge the 12v battery fast enough to handle short trips well. If you don't drive long trips just get a convenient setup like mine and charge the battery for a full day or two once every 3 or 6 months depending on how often you need a top up. Myself I haven't topped up this battery since I got it but if I get a closer job I might start doing so again or maybe I will when winter comes around. Either way I'm not worried about the quality of the battery, I'm worried about the anemic charging system in the Prius.
    uart likes this.
  18. Patrick Wong
    18,210
    6,526
    Unless you modified the 12V power outlet wiring to function when the car is IG-OFF, use of a charger via the 12V power outlet will do nothing for the 12V battery.
  19. dhanson865
    851
    188
    TN, USA
    I have to assume the dealer or initial owner of the car modified it as in MY 2005 prius there is a 12V socket between the front seats that is switched and one under the dash that is always on.
    They had satellite radio installed (I'm assuming that wasn't a standard item), and may have had the 12v wiring rerouted when that was done.
    As to testing a cigarette 12v port it's rather easy to test with any 12v device like a cell phone charger (the phone will tell you if it is charging or not) but the CTEK also has enough status lights to let you know when it sees a load or not.
  20. dorunron
    3,318
    1,105
    Houston, TX
    Hmmm. Now that I am at home and had some time to do some research, I really don't know what to believe. There is more than one explanation and opinion concerning concrete floors and batteries. Some say it's a myth, some say it isn't. Some say it is due to temperature differences, other's say no. Some say it simply about the old method of battery construction (wood/rubber enclosure's), other's say something totally different.
    With all that said, I am going to stick to not placing my good batteries on concrete, or at least try to avoid "cold" concrete as those who discuss the temperature differences within the cells do state that the battery will discharge.
    Source of multiple info concerning the myth of "don't put that battery on the concrete floor".
    Google
    It is a interesting topic and I think if those of you who are interested will take the time to read through the links on at least the first page of the google search, you will begin to become perplexed with the myth, old wives tale, or fact too.
    Ron
