Quick Prime 12 volt battery question
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by huskers, Mar 3, 2017.
  1. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    Where is the regular 12 volt battery located on the Prime? Is it easy to get to? Is there anything special if you need a jump?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    underneath the front hood on the drivers side
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If you need a jump:
    amazon.com/gp/product/B013UJ2JCE
  4. hatcher8
    hatcher8 Junior Member
    32
    Lincoln Ne
    Your Toyota Prime comes with a 3-year SOS package so you get free Towing I'm assuming free jumps yoo. And they also come if you run out of gas or have a flat tire. And I believe there's no charge for these services for the first three years. I would really not want to jump start this thing as their are so many computer components to it. It would be a bad deal if one of those computer things got zapped by the jumper cables. :(
    Pearl Prime
  5. hatcher8
    32
    Lincoln Ne
    Wait the SOS feature might only come at the advance package I'm not sure which package you're getting
    Pearl Prime
  6. Mendel Leisk
    42,377
    Under the hood. Yes. No.
  7. hatcher8
    32
    Lincoln Ne
    Yes it's under the hood right in front of the driver
    Pearl Prime
    priuscatprimeguy likes this.
  8. bisco
    52,896
    the gen 4 battery is larger than previous generations, and hopefully more robust.
  9. Mendel Leisk
    42,377
    Looks more conventional, regular post size, you can top up the electrolyte.
  10. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    If you are going to boost from another car, have them shut off their engine. You don't need a lot of power and you absolutely don't need any voltage spikes from alternator arguments between the two cars. You can also boost from a "boost pack" or even an "alarm system battery" (gel cell type).
    DO ensure you get the polarity correct. DO connect the negative terminal -last- and do so on a bare metal chassis part underhood (to avoid a spark near the battery - which -might- ignite the H2-O2 mixture of gasses in the battery). That would ruin your day!
  11. Tom_06
    Tom_06 Active Member
    609
    143
    Newark, Delaware, USA
    So how well does the SOS button work with a dead 12V battery?
    bamike and priuscatprimeguy like this.
  12. huskers
    2,550
    2,489
    Nebraska
    I think I'll just walk.
  13. huskers
    2,550
    2,489
    Nebraska
    So if a tow service came to jump you would they know all this?
  14. bisco
    52,896
    not likely. many reports here over the years of cross pollonized connections from tow drivers, causing inverter failures or blown high voltage fuse at best.
    never let anyone do anything without your supervision.
