Rattle Electric Motor Noise behind Dashboard
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by eman08, Nov 10, 2016.
  1. eman08
    eman08 Active Member
    360
    192
    US
    New Thread continued from my old thread. Seems like my old thread died out. Small motor noise behind steering wheel dash | PriusChat
    Here is the video clip of some electric motor sound moving back and forth somewhere behind the dash board, sounds like someone rattling a door nob. Ignore the brushing sound as its just me moving my phone around. You can hear a rattling back and forth sound behind the dash board more near the shifter. What do you thing? https://drive.google.com/open?id=0B9ZD2aOUG4DaVDJObWRMdzZWOG8
  2. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Does this only happen when the engine is running? It almost sounds like a gurgling noise. Have you checked your engine coolant level? And not just at the reservoir, but at the radiator cap under the black splash shield.
  3. eman08
    360
    192
    US
    That gurgling noise is also my phone making that noise. There is no gurgling sound in person. Just a rattle noise something just moving back and forth behind the dashboard. It does it when the ICE is not running too. Engine coolant level is fine.
    #3 eman08, Nov 10, 2016
    51,932
    not much help, hard to be sure which noise is which.
  5. eman08
    360
    192
    US
    I will. Take the dash apart again over the weekend and take a look. Hopefully I can get a better recording or find what that little guy is causing that noise and it doesn't do it every day which is strange as it's like a few times in a week.
  6. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I've noticed the same, haven't found the answer. My theory is that it is the auto a/c setting and there is a baffling between how much air is being drawn through the condenser coil and how much is being drawn from outside or recirculated and from the cabin. Mine only seems to do it when it is auto cooling the outside air not when heating it. Also only after it has gotten to the set temp, usually 71 F. So I think it is a thermostat controlled servo motor that controls a damper.
    iPhone ?
    eman08 likes this.
  7. eman08
    360
    192
    US
    Seems more likely since it not consistent as does it when ever it wants to. I double checked the engine compartment today and nothing audible in the engine compartment which rules out any pumps. Only audible inside the car behind the dash. It doesn't make the noise in Accessory mode but does in Ready mode. Any Idea where would that servo motor located at? The sound is def on the driver side of the car and not the passenger side.
  8. Paul Schenck
    523
    306
    Fresno, California
    Interesting I'll compare mine to that
    iPhone ?
    eman08 likes this.
  9. eman08
    360
    192
    US
    Found a video that sounds actually the same. very faint rattle sound just like mine, but in a 1st gen Prius. Will be looking for that motor over the weekend and pull it out.
    #9 eman08, Nov 11, 2016
  10. eman08
    360
    192
    US
    Same sound
    Paul Schenck likes this.
