Really interesting noise - anyone heard it before? (w/ video)
Discussion in 'Generation 1 Prius Discussion' started by MDNHW11, Sep 16, 2016.
  1. MDNHW11
    MDNHW11 Junior Member
    2001 Prius
    I heard a disturbing noise from my Prius earlier this week. I have done 300 km since, and the noise has not recurred.
    I didn't bother checking in the parking lot, as I was convinced that something was toast, and it would be easier to confirm at home.
    Here it is (from dashcam):
    It sounds louder in person and seemed to be just as audible outside the car.
    Heater switched off by me midway, drove normally, no check engine light, heard ABS do self test (sounded normal.
    Has anyone heard this noise on theirs, and was it possible to confirm the source?
  2. ChapmanF
    18,959
    You mention switching the heater off midway, why? Did it affect the noise in some way?
    If so, maybe it could be an extra-loud version of this.
    If not, I'm stumped ....
    -Chap
    MDNHW11 likes this.
  3. MDNHW11
    2001 Prius
    I switched off the HVAC midway to see if it had any effect. As far as I could tell, it did not.
    Gen4 comes tomorrow. My wife will be driving this one, so I better get it sorted!
  4. JC91006
    16,933
    8,643
    Do you have coolant in your radiator? I can hear the bad 3 way valve noise in the background. The loud sound might be a water pump turning without coolant or the pulley noise having a hard time turning.
    Check coolant
  5. MDNHW11
    2001 Prius
    Thanks for the replies. Coolant level is good. (in rad, in overflow and also in the inverter circuit.)
    I have heard many a bad water pump in my days, and (fortunately/unfortunately?) this sounds like none of them.
  6. JC91006
    16,933
    8,643
    That pulsing noise you hear in the background is from a failing 3 way valve. Not sure if that's a contributing factor
  7. MDNHW11
    2001 Prius
    When you say 3-way valve, are you referring to the water pump for the heater? This vehicle is a is Gen 1, so no coolant tank on it (unless I am misunderstanding your idea).
    I re-listened to the video, and I think the noise you are referring to is coming from the cassette player. I was given some audiobooks to listen to on my commute, and they are on cassette. Cassette player volume is turned down in the video.
  8. JC91006
    16,933
    8,643
    Oh I thought this was a gen 2. Sorry. I forgot gen1 and gen2 are merged
  9. MDNHW11
    2001 Prius
    Any more takers on this?
    Strangely, it hasn't done this again. Maybe it is aware of the '16 that it is now sharing the driveway with, and has decided to be good.
  10. MDNHW11
    2001 Prius
  11. MDNHW11
    2001 Prius
    Follow-up for any that are interested.
    I hope not to jinx myself, but the problem has not recurred since the original video was taken.
    WHCSC likes this.
  12. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Prius noises are like teeth. If you ignore them long enough they go away.
  13. JC91006
    16,933
    8,643
    interesting
