WTB Rear wiper delete plug
Discussion in 'Private Sales' started by 9uns, May 18, 2017.
  1. 9uns
    9uns Junior Member
    62
    16
    CA
    PRIUS REAR WINDSHIELD WIPER MOD REMOVAL | Page 2 | PriusChat
    I'm looking for something like this. Someone in the link mentioned that the plugs are available at Lowe's? If so, does anyone know what the item # is or what I should search or maybe the size of the silicon plug?
    Sarcastic "...weld doors shut...tape off headlights" etc. comments not necessary.
    Thanks!
  2. Imaginex20
    Imaginex20 Active Member
    140
    242
    Bay Area, CA
    2014 Prius Plug-in
    Refer to this thread. I did the same thing this past weekend even before seeing the post, but did the same exact thing on my Gen3 prius.
    Gen 4 Rear Wiper Delete | PriusChat
    Raytheeagle likes this.
  3. WilDavis
    WilDavis Senior Member
    2,489
    2,153
    49
    …sorry to be such a kill-joy, but before you remove the rear-windshield wiper-motor, you might want to check your state's vehicle safety inspection laws. I'm in New Hampshire, and theirs says something about any safety equipment installed as part of the original equipment, must be present and operational for the test. I removed the wiper-arm and blade from my 2009 Gen II as its removal improved the vision to the rear, but I will pop the arm & blade back on when the inspection is due at the end of June, after which the arm/blade will come off once more. Removing the motor assembly is much more of a PIA and really doesn't improve the rearward vision.
    Here's another idea (thanks to the poster from who I nicked this!! :eek::rolleyes:;))
  4. 9uns
    9uns Junior Member
    62
    16
    CA
    thanks for the sarcastic pic, but I'm not looking to remove the whole assembly, just the wiper arm/blade.
    WilDavis likes this.
  5. WilDavis
    2,489
    2,153
    49
    Understood! Simple job which took only 30 secs, only tool needed is 10mm wrench. Only thing I needed to add was 10mm blind nut (Stainless-steel) to protect the threads! ;)
  6. 9uns
    9uns Junior Member
    62
    16
    CA
    thank you both!
