Recommended 100k Mile Maintenance ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Michael Wood, Jun 26, 2019.
  1. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    I'm looking for recommendations from some of you Prius gurus......not dealership recommendations. On a 2015 gen3 with 100k miles, what would you do for maintenance?
    I've changed the oil and filter every 5000k since new, and kept the air filter clean and tires at proper PSI. I just replaced the 12v battery which died almost 4 years EXACTLY from my date of purchase. But other than that, I haven't done anything else.
    I would appreciate any recommendations.
    51,154
    start with the maintenance schedule that came with the car, then add tranny fluid change
    Michael Wood and Mendel Leisk like this.
  3. Mendel Leisk
    40,583
    I'd second the transaxle fluid change. I'd really recommend to do it about 90K back, but no time like the present.
    Some more:
    1. Do a full brake inspection. Long overdue.
    2. A brake fluid change would be a good idea too.
    3. Throttle body cleaning.
    And then, depending on how long you intend to keep the car, and how deep you want to get into it:
    4. Exhaust gas recirculation system inspection/clean. Start with the pipe, easiest, get some idea of the rest.
    5. Intake manifold inspection/clean.
    6.. Oil Catch Can install on the Positive Crankcase Ventilation circuit.
    Watch @NutzAboutBolts videos, pinned at top of 3rd gen maintenance forum, lots of insights and tips.
    A couple of threads to read:
    EGR & Intake Manifold Clean Results | PriusChat
    Oil Catch Can, Eliminate that knock! | PriusChat
  4. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    Thanks for the detail. I haven't been able to log in for a while, but I appreciate the info. I'll get this done.
    I am a semi-sorta-competent backyard mechanic. I've never had a problem doing brake pads or fluid changes on my other vehicles. I'm wondering if I'd be able to handle the front pads on my prius. My strategy has always been to change the pads early, and leave the rotors alone - that's saved me a lot of money and aggravation over the years, but I don't know if this strategy would work on the Prius.
  5. bisco
    51,154
    pads aren't difficult, but there are some precautions on a prius that other vehicles don't have.
    such as, the brakes are electric, so if you don't disconnect the 12v, and open the drivers door, the pistons will shoot out, and then you'll be changing the brake fluid too.
    best to watch a how to video if you can find one.
    otoh, prius pads can last a long time, so measure the thickness, don't just change them for no reason.
    Merkey likes this.
  6. bisco
    51,154
    it will be interesting to see how clogged your egr is. you have the upgraded pistons and rings, and we don't see many 15's with 100k already.
    RMB likes this.
  7. Toddwilks
    Toddwilks Active Member
    555
    176
    Whitehouse Station, NJ
    My 14 has 95000 so I’m right behind them. Mine only has the newer rings right? Or is it the pistons?
    iPhone ?
  8. bisco
    51,154
    rings, correct. time to take a peek inside :)
    RMB likes this.
  9. sorrywereclosed
    sorrywereclosed Junior Member
    SF
    right behind you at almost 90,000
  10. Mendel Leisk
    40,583
    Your model year being 2014, I believe just the revised pistons. I compiled this list querying replacement pistons and rings (for various years) at McGeorge Toyota Parts:
    One thing puzzles me though: why McGeorge would not suggest the updated parts, regardless of year.
    The technical service bulletin relating to excess oil consumption (attached) instructs to tear down the engine and replace the pistons and rings with the revised (2015 model year) parts. The implication there is that these pistons and rings are better, less prone to causing oil consumption down the road.
    But it's not stated. I would think if you did the engine tear down and replaced piston and rings with the old numbers, it would also likely stop oil consumption, likely for the practical life time of the car.
    Which leaves the question: are the new pistons and rings that much better? Maybe, but who knows. It'd be interesting to see side-by-side comparison pictures of them, measurements, any variations. Maybe the new rings spring out more? The piston oil draining channels are larger or more?
    I started a thread with a poll: what year do you have and how's your oil consumption:
    3rd gen model year and oil consumption | PriusChat
    So far the preponderance of votes have been early years, no 2014, and two 2015's. Not enough of a sample to draw any conclusions I think. Feel free to vote btw, get a 2014 in the poll. (y)
    Greenteapri likes this.
  11. TB1026
    TB1026 New Member
    New York
    Just bought a 2014 with 88k
  12. bisco
    51,154
    congrats and welcome!
    same goes for you ;)
