Reconditioning Experience with Hybrid Automotive's Prolong System
Discussion in 'Gen 2 Prius Main Forum' started by biglew8, May 16, 2017.
  1. Prodigyplace
    12,564
    11,779
    Central Virginia
    You misspelled "tolerates".;)
    jerrymildred and Raytheeagle like this.
  2. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    The exhaust (or rather the outlet) of the 3 fans comes out on the right side panel just behind the right passenger seat on the 2nd row seats. I checked there too but there was clearly no airflow.
  3. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    Finally got around to checking the 12 volt battery after getting back from work this evening. Showed 12.89 Volts on the voltmeter. I checked the battery right after parking in my garage - does that make any difference?
    12.89 Volts - is that okay or on the lower side?
    Hare Krishna!
  4. dolj
    dolj Senior Member
    8,446
    4,291
    Wellington, New Zealand
    It will read higher than normal in that circumstance.
    Read it again in another 1.5 hrs.
    Or, leave the car off, put your headlights on for 30 seconds. Let it rest for 5 mins then read again. If the voltage is stable (i. e. not rising) let us know what that voltage is. If the voltage is still creeping up, let it rest for 5 mins then read again.
  5. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    Saw this post in the morning :(
    The battery stood at 12.61 Volts this morning after about 13 hrs of being parked. Is that okay? Or should I put it on the charger overnight?
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    If that's without pressing any buttons or switching on, (IMNSHO) that looks good! It should pop up to ~13.8V when the system goes to "Ready" showing that the inverter is working OK! (…anything below 12.0V could be a sign of problems! :eek: ) - hope this helps - Wil ;)
    Raytheeagle likes this.
  7. dolj
    dolj Senior Member
    8,446
    4,291
    That puts it at 62% SoC. The open voltage shows that the battery is reasonably healthy.
    It never hurts to have the battery fully charged at all times, so why not? It won't do any harm.
    WilDavis likes this.
  8. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    How do you infer / calculate the SoC from the Voltage information? Is there a formula?
  9. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    I checked again a few minutes ago after parking at home and leaving it running. Was in Ready and EV mode and the AC was on. Battery tested at 14.15 Volts.
    What does that tell?
  10. Prodigyplace
    12,564
    11,779
    Central Virginia
    That tells you the inverter can charge the 12 volt battery from the larger Hybrid battery. Nothing more, really.
  11. dolj
    dolj Senior Member
    8,446
    4,291
    It tells you more than it can charge the 12 V battery. It tells you that it is charging the 12 V battery. Further it tells you the car thinks the battery is low. Once the car thinks the battery is full, the voltage will drop to trickle charge circa 13.5 – 13.8 V.
    Sanjay Goel and Prodigyplace like this.
  12. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    @dolj - kindly explain how did you deduce the SoC of the battery from its resting voltage.
  13. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    I have a 100+ mile trip today and a 400+ mile trip tomorrow. Hopefully the battery will get fully charged by the time I complete above trips and there won't be a need to charge the battery separately. Will check the Voltage after getting home tomorrow night.
  14. dolj
    dolj Senior Member
    8,446
    4,291
    It is based on the voltage for AGM. I found this graphic on the Battery University (I think) website:
    Pb:A voltage band (SoC).jpg
    The top line is AGM/Calcium/Gel; the lower line is normal flooded lead/acid.
    jerrymildred and Prodigyplace like this.
  15. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    Mine is not an AGM battery - it is, I think the normal kind. But good to know of this chart. Thank you!
  16. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    wondering if it's worth only doing 2 cycles with my battery that has a block .02v lower than the rest. P0A80 code, displayed MPG all over the place, and rapid charging and discharging while sitting parked. Pics and video with more info here: P0A80 but all voltages look normal? | PriusChat
    I am self-employed and have already been stranded for a week, going on a week and a half. this has easily cost me over a grand in missed income and I don't want to sit here any longer than necessary, but if there's even a 10% chance I should do all 3 cycles, then I'll do it.
  17. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Two cycles will be enough to get you back on the road. Each cycle has a diminishing return. Around 80% of the benefit comes from the first cycle, an additional 10% comes from the second cycle, 5% from the third cycle, and so on. For best results we recommend three cycles, but it time is tight (sounds like it is for you) one or two cycles is enough to get you going again.
    Shig, Frank1234, swapper and 6 others like this.
  18. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    thanks, I think I'll suck it up and do the whole thing for peace of mind.
    #638 k1ngn0thing, Mar 18, 2018
    Prodigyplace likes this.
  19. calin.ceascai
    calin.ceascai Junior Member
    RO
    Hi Jeff,
    Recently I bought a Prolong Deluxe pack from you. I have a 2007 Prius with 147k.
    I installed the harness and the test was ok with all the fans working.
    I made filling phase and than I run first discharge to 134V. The discharger was idle, buzzer ringing, voltage at 151 and amp 0. Than I recharge and now on second discharge to 134V he stoped at 178V and amp 0.
    Is this normal? Shouldnt stop at 134V and 84V? What should I do further?
    Please advice!
    Thanks.
    Huawei P10 Leica
    #639 calin.ceascai, Mar 19, 2018
  20. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    As soon as the voltage reached 134V the discharger goes into idle mode. However, almost immediately the voltage starts bouncing back. I was there while discharging when the voltage reached the set value and stopped discharging and I immediately disconnected the discharger and connected the charger. However, in less than 2-3 minutes that took to do this the voltage bounced back almost 20V. This is normal and all batteries in decent shape will do this.
    Hare Krishna!
    SFO, dolj, Raytheeagle and 1 other person like this.
