Replaced Spiral Cable / Clock Spring Now I Have ABS Lights and Codes. Please Help
Discussion in 'Gen 3 Prius Main Forum' started by Sidewayzgt, Apr 7, 2017.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    It sounds to me like you got the spiral cable out of center when installing it. IIRC, my used one came with tape holding it in place and a strong caution to not let it rotate. I don't know if there's a procedure for realigning it. If not, trial and error might take a long time.
  2. J Johnson
    J Johnson New Member
    Thanks for the response. Mine came with a lock tab, which prevents it from rotating. I waited until after it was installed before pulling the tab, so I don't think that should be an issue.
    jerrymildred likes this.
  3. jerrymildred
    11,517
    14,167
    Tampa, FL
    Well, so much for that theory. Did you see this thread? Perhaps there are clues in it. DTC C1231 Help | PriusChat
  4. ChapmanF
    19,025
    Sometimes after a spiral cable replacement, the explanation for an angle sensor code turns out to be that the angle sensor is still attached to the old spiral cable, sitting on the garage floor or in the trash.
    Not every time, but worth checking.
  5. Chris johnson 2007
    Chris johnson 2007 New Member
    Charles city
    I haven't solved mine yet. My steering angle sensor definitely spun when changing my clock spring. I used the tech stream to preform a l calibration on the steering angle sensor and did not solve my problem. Do I need to take the wheel off and spin the sensor with the tech steam hooked up until the sensor comes in value?
  6. Eddykish
    Eddykish New Member
    Kenya
    How did you solve this problem iam facing it now!!
    How did you solve this problem because iam facing this now.
    #26 Eddykish, Mar 18, 2022
    Bohemian Grove likes this.
  7. J M Bowman
    J M Bowman New Member
    I'm pretty sure you need to techstream / vci cable to reset the steering angle sensor via the EPMS menu. once you do this, that should allow you to clear that code
