Replacement Battery Pix
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Jan 6, 2014.
  1. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    In my thread about Car not turning off Won't Turn Off -- Master Warning Light on (Red Triangle) | PriusChat
    Patrick asked that I post photos of the new battery ($199.95 USD at the Toyota dealer). I thought it better to make it a new post, since people might be interested in this, but not interested in the title of the other thread.
    There was also an instruction manual inside the box. A little fractured on English, but had some valuable information, nonetheless. I could scan it if people care, but not until this evening, probably. Battery appears to be an October 2013 manufacture date and tested at 12.88 volts at home in 26-degree F temperatures.
    I will start to put it in an another hour or so, hoping temps may soar to 33 degrees F or so.
    Kris
    dorunron and Patrick Wong like this.
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Good choice in my book. Same thing I bought last year. Can't remember the date on it, measured 13.0 volts straight out of the box.
    Good luck on the install.
  3. Patrick Wong
    18,212
    6,529
    Hi Kris,
    Thanks for posting the three photos. In the center of the first photo, there is a six-digit number to the right of the J13 sticker. That six-digit number is the actual manufacture date in DDMMYY format. Can you please look at that number and post it, since there is some glare on the photo?
    Did you see a label on the battery or box which shows country of manufacture?
    Good to see that the battery has the TrueStart label showing an 84 month pro-rated warranty. That is much better than prior practice where the battery had a 24 month warranty.
    Note that the TrueStart label appears to have been added on top of the existing labels, at least on the top of the battery.
    Nice to hear that the battery voltage of 12.88V shows fully-charged. Was the box sealed when you bought it, or had it been opened (perhaps by the dealer's parts dept to charge the battery prior to your purchase)?
  4. cyberpriusII
    1,157
    1,850
    Hyampom
    Brrrr, it's still cold out there. I am used to working in the cold, but I am working, not standing around in one spot.
    Anyway, I peeled the large sticker off the side of the battery and "nothing."
    Peeled the small sticker off the top and it reads underneath (White sticker):
    S46B24R
    GSYUSA
    Made In Japan
    The code to the right of the J13 reads:
    010613W
    I'm going to wiggle into the silk long underwear and go attempt to put this thing in....
    Oh, the box question, the box has "fold down inside type" top. I know you have seen the type, but I don't know the term.
    Anyway, no evidence of any type of sealing tape ever being used on the box, or removed from the box. The fold down lid seemed to hold pretty well. Flaps come from each side, meet in the middle and then each flap has a scored fold-down that tucks down into the center of the box.
    Anyway, looks like it probably comes in a larger shipping carton of ??? could have certainly been opened by dealer, but the way the box is designed, you would never be able to tell.
  5. Patrick Wong
    18,212
    6,529
    Thanks, Kris. You are a very brave woman, to be peeling stickers off a new battery - since at some point in the future you might want to take advantage of the battery warranty. Hope they can be restuck onto the battery.
    Here is my interpretation of the stickers:
    The battery was made by GS Yuasa in Japan, on June 1, 2013. It slowly made its way to the West Coast via freighter and sat around in the Toyota distribution warehouse in southern CA for a while.
    In October 2013, someone charged up the battery and stuck the J13 and TrueStart stickers on, which shows that the battery had some attention paid to it in October 2013 and the battery qualifies for the 84 month pro-rated warranty which is similar to other batteries with the TrueStart label (which generally are produced in Mexico). At that point, the battery was placed in the individual packing box, ready for shipment to a dealer.
    Then the battery made its way up to Oregon and sat in the dealer's stockroom for a month or two prior to its sale to you.
    So the price of $175-$200 which you were quoted by your local dealers isn't bad considering that the battery was produced in a very high-labor cost country, traveled 5,500 miles across the Pacific, got a boost charge in Los Angeles, then traveled another 1,000 miles to be available to you in Oregon.
    The MSRP of the battery in the past had been $139 (during most of the prior decade). I was wondering what justified the substantial increase to $175-$200, and now suppose the main justification would be the 7-year prorated warranty which is now offered.
    Given the PC member reports logged about 12V battery life, it is fair to say that many owners who buy the TrueStart labeled battery will have an opportunity to make a claim under the prorated warranty after 4 years or more. This is basically just a marketing tool to encourage a repeat sale at a somewhat discounted price.
    By the way, when I bought Prius 12V batteries in the past from the dealer, they were packaged in two boxes with a layer of absorbent material in between the two boxes. So it looks like the packaging has evolved to a more tree-friendly method now.
  6. cyberpriusII
    1,157
    1,850
    Hyampom
    No packing or cushioning material at all in the box. Just a snug fitting box.
    BTW, in Oregon trees are considered renewable resources by many, so some of my logger friends do prefer heavy boxes with lots of paper. :)
    Since I took the day off, off to take the lab for a run. Again, if someone cares about the instruction manual that came with the battery I will scan and post, but know that scanning docs is not my FAVE and request only if you really are intrigued, since I owe all of you, I WILL do it.
