Replacement Hybrid Batterys in Iowa
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nicholas, Mar 16, 2016.
  1. HBS
    HBS Member
    74
    56
    MO
    What's wrong with taking someone's word? We do it all the time out here in the midwest! I always do tell people though that I have references available upon request.
    Raytheeagle, strawbrad and m.wynn like this.
  2. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    The problem is what has occurred with battery replacements being advertised by "companies" on Craigslist across the nation, including the Midwest. They have been pieced together battery packs and not complete packs as advertised. Despite their claims of quality and warranties the sellers have been almost impossible to track down and even if you do you can't get them to stand behind their products in any reputable manner. Too many people on this forum have seen too many customers of those shysters come here to complain about their experiences.
  3. HBS
    HBS Member
    74
    56
    MO
    Yes, we have one of those around here, and I've replaced several of his junk batteries because he wouldn't return their calls. I helped one lady who he put off for over a month. She kept driving her car until a couple modules exploded inside the battery. He tells everyone his batteries are from 2009 Prius' with 45,000 miles. I can tell you for a fact they are not. He is out of Owensville, MO.
    strawbrad likes this.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
  5. HBS
    HBS Member
    74
    56
    MO
  6. Nursie27
    Nursie27 New Member
    Boone iowa
    Help! I live in Boone Iowa and need my Prius battery replaced...any recommendations for getting a reconditioned one put in?
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    In case you don't know, a reconditioned one just reuses good, old modules from other battery packs. Since you have an '07, there's pretty good odds you could buy a pack that's loaded with 04-06 modules. I'd suggest you check with the larger, national chain auto parts stores that carry the doorman brand. They have a good warranty that you will most likely use; some folks here have reported 3 failures/returns.
    GOOD LUCK!
    #27 fotomoto, Jun 4, 2017
    Nursie27 likes this.
  8. eman08
    eman08 Active Member
    360
    192
    US
    If you to keep it for another 5 to 10 year's I would get a brand new factory pack as everything else on the car you can especially but used. As a DIYer I recommend investing into the Prolong Grid Charger. Its for battery reconditioning to extend the life of the battery cells. I'm from eastern Iowa.
    Nursie27 and Raytheeagle like this.
  9. HBS
    HBS Member
    74
    56
    MO
    I would be glad to replace your battery for you. Please give me a call or text so we can arrange a time that's best for you. 660-787-0058
  10. mpash
    mpash Junior Member
    How much? And was it Toyota of Des Moines?
  11. bisco
    52,817
    is there another thread with this many one post wonders? iowa, who knew? :rolleyes:
  12. Todd Huffstetler
    Todd Huffstetler New Member
    Iowa
    2002 Prius
    I could use the name
  13. Todd Huffstetler
    Iowa
    2002 Prius
    How much for a 2002 pruis hybrid battery ?
  14. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Where are you located?
  15. Williamsons Repair & Tire
    Bondurant
    I agree with many of the comments. There are a bunch of people who replace a cell or two in your pack. this is a band aid. There are however places that completely test every cell in a pack and replace the problematic copper bus bars with nickel bars. Some so called rebuilders simply use a volt meter or a volt metrr combined with a light load device. We test every cells capacity before being balanced or cycled. we only use cells with 90% or more of original capacity. we then test the charge and discharge performance of each cell and discard any that are not within our rigid specifications. The equipment alone to do this costs over $15,000. I can bet someone who charges $700-900 to drive out and change the battery is not doing this. I am not knocking them however there is s difference for sure. Also cells can be balanced and cycled to regain lost capacity. This is a temporary fix however. A completely remanufactured battery will outlast a rebuilt. And a new battery will outlast a remanufactured battery. It is all a matter of which provides the best value.
    fotomoto likes this.
  16. Williamsons Repair & Tire
    Bondurant
    We offer remanufactured hybrid Batteries for Des Moines and central Iowa. save thousands over new. 3yr 36,000 mile warranty and Free pick up and delivery within 40 miles.
    Williamson's Repair & Tire
    1420 2nd str Ne, Bondurant Iowa
    515 967-0900
  17. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Williamson's, you guys do Gen 1 Prius batteries?
    Do you put Toyota Gen 1 Prius cells in them? (The plastic-sided ones, not the metal sided-ones)
