Replacement tire recommendations for a Gen II (2007) Prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by camner, Sep 11, 2013.
  1. camner
    camner Junior Member
    68
    I own two 2007 Prius vehicles. They are identical except that one is a Touring model and the other not. The Touring car has Yoko Avid Ascend tires, and the other has the OEM Goodyear Integrity tires.
    For whatever reason, the Touring vehicle has always gotten between 5-7 mpg less than the "standard" model. I don't know whether the tires can account for this.
    I was at the dealer for something else and asked about their recommendation about replacement tires, and they said "either the Goodyear Integrity or the Yokohama Avid Ascend"!
    The Yokos are characterized as "Performance-Touring" and the Goodyears as "Broadline Passenger"
    So, 2 questions:
    1. Does anyone have experience with both of these tires and can talk intelligently about the difference one can expect in mpg, handling, ride, etc.?
    2. Are there others that should be on my list to consider.
    Thanks, as always, for everyone's help
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    1. No experience here with your tires except for the Integrity. My opinion on that one is it is not the best for the Prius.
    2. I would recommend you study a list that is provided here on Prius Chat that discusses tires. I think if you will take a couple of minutes and read through what F8L has posted you should have a good idea of which tires to choose from.
    FWIW, the touring model's are well known to get LESS mpg than the standard Prius.
    Here 's the link.
    Low Rolling Resistance replacement tires: Current List | PriusChat
    I myself personally recommend the Michelin Energy A/S. You will find those tires on the list also.
    new energy savers!! | PriusChat
    Best of luck to you.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ^^^what Dorunron said and also check out TireRack.com where many of us order from, and you can see test results and comments from Prius users. One nice tire is the cheaper Continental ProContact EcoPlus but not so long lasting. I am thinking the A/S too.
  4. camner
    68
    Thanks for the quick reply. What is it about the Touring that causes the lower mpg? The suspension?
  5. FreydNot
    FreydNot Member
    216
    37
    Seattle, WA USA
    On my 2008 Prius I replaced the stock Integrities with Bridgestone Ecopia EP422's and couldn't be happier. They seem to go on sale at Costco every 3 or 4 months. I got my set of 4 for just under $400 out the door.
    They preform very well on the wet roads of the Pacific Northwest. If you are in a always dry environment, the EP100 might be a better choice.
    I've heard good things about the Michelin Energy Savers too, but have no direct experience with them.
    I put Continental tires on my old PT Cruiser which I liked, but they were not low rolling resistance.
  6. Patrick Wong
    18,210
    6,522
    1. The tire size has a wider footprint which results in greater friction.
    2. The Yokohama Avid tires are not characterized as low rolling resistance.
    I also have installed Bridgestone Ecopia EP422 and have found them to be an excellent choice.
  7. camner
    68
    I'm also in the PNW, and so wet road performance is important to me. It would be a nice plus to get a tire that can handle the occasional snow we have here. My Prius with the Integrity tires is horrible in snow..the worst car I've had for snow (and I'm from the Midwest and the Northeast...I know snow well and know how to drive in it!)
  8. camner
    68
    I talked to a dealer about whether tires alone could make that kind of difference, and they didn't know. I bought the Touring Prius used and the dealer who sold it had already put on the Yoko Avids. It's hardly worth the $500+ to replace (nearly!) new tires just for a few MPG. But it's good to know, and when it DOES get time to change the tires, I'll go with LRR tires.
    I know the rims on the Touring are different than on the standard, but I presume I can choose narrower tires on the Touring if I wish?
  9. Patrick Wong
    18,210
    6,522
    Well, since the Touring wheels are 16", it may not be easy to obtain narrower 16" tires that will have the same circumference as the original equipment tires. If the tires have a smaller circumference, that will throw off the speedometer and odometer. Smaller tires may have insufficient load carrying capacity.
    xpcman likes this.
  10. camner
    68
    Well, I may be showing my ignorance of tires here (which would be easy to do), but why would rim diameter determine how wide a tire can reasonable be? Unless I don't remember my math well, circumference is only a function of diameter, no?
  11. Patrick Wong
    18,210
    6,522
    Tire size is a function of three variables: tread width, aspect ratio, and wheel rim size. 2G Prius has two original equipment sizes. The non-Touring size is 185/65-15 which can be interpreted as follows:
    185 is the tire width in millimeters
    65 is the aspect ratio which means that the sidewall height is 65% of the tire width
    15 means the wheel size is 15" diameter
    The Touring tire size is 195/55-16. This size was not randomly chosen. The point of that choice is that the Touring tire circumference will be pretty close to the non-Touring tire circumference.
    Your challenge will be to find a tire to fit a 16" wheel which is narrower than 195 mm and has a greater aspect ratio so that the tire circumference remains unchanged.
    Further, the maximum allowable load that a tire can bear is usually correlated to tire width. The greater the width, the more weight a tire of a given wheel size can bear. So your choices will be further constrained by the need to select tires which have a load rating similar to original equipment.
  12. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    Changing tyre size on the touring to 205/55/16 (with the correct choice of tyre) can actually improve the mpg figures. "All gen2 Prius are fitted with 16 in wheels in the UK/EU". This size of tyre also gives a much greater choice of tyres, and if the same applies in the US as in Europe the wider tyre is also at least 25% cheaper.
    There are other benefits to going to wider tyres, better grip, stability, and handling.
    John (Britprius)
  13. KrisTheFrog
    KrisTheFrog New Member
    22
    I find my self a bit baffled by the test results on TireRack for the Bridgestone Ecopia EP422.
    They said that snow traction is wonderful, but
    "What We'd Improve: Dry and wet traction"
    And...
    "Conclusion: An eco-friendly tire for drivers who don’t emphasize wet or dry traction"
    Hmmm.....I like my tires to have both wet and dry traction and plenty of it (usually).
    Any ideas here? I don't drive that much on snow (three/four days a year). But, you know, the rest of the year, it is either wet or dry.....
  14. Patrick Wong
    18,210
    6,522
    As of this writing, TireRack shows 132 respondents to its online survey.
    7.8 rating for wet traction
    8.1 rating for dry traction
    Both ratings fit into the "Excellent" category.
    If you want to improve dry traction, typically you would use a summer tire. If you want to improve wet traction you would purchase an all-season tire with a more aggressive tread which means the rolling resistance will increase.
    I think the Ecopia EP422 provides an excellent blend of characteristics and have never noticed a lack of traction given the driving I do, sometimes in very heavy rain as there are two rain seasons (summer and winter) in my area.
  15. scotrinaf
    scotrinaf Junior Member
    37
    Blountville, TN
    My wife's car has the Michelin Energy Savers and she averages 46mpg
    My car has Michelin (Non-energy savers) and I average 44mpg (but I'm also heavy footed)
  16. Laurel007
    Laurel007 Junior Member
    Fairfax, VA
    I put the Ecopia 422 tires on my 2010 Prius two weeks ago, and they seem very noisy at 50 mph and above. I am returning to the store where I purchased them tomorrow (TiresPlus) to see if the noise is caused by the tires or something else. Has anyone else experienced excessive road noise with the Ecopia 422 tires?
    Another thought: When my tires were replaced - could the mechanic have done something to cause the wheel bearings to go bad?
  17. DaveLadely
    DaveLadely Junior Member
    47
  18. DaveLadely
    47
    I bought the Michelin X tires from Costco, on sale; they were rated about highest, and excellent wet performance and longevity by Consumer Reports, also have a high mileage rating of 90,000. I live in Seattle, so I wanted good wet traction and resistance to hydroplaning. I got 51,000 on the original tires, still had some tread, were about at the recommendation for replacement. I have 48,000 now on the Michelins and there is still lots of tread, look about half worn. I get about 48mpg average, somewhat careful about acceleration. I get about 51 mpg on the highway if I keep it 65 mph or under. I got about 53 mpg on I-5 between Redding and Sacramento (very straight, level). This is slightly better mpg than the original tires. I fill them to 38 pounds. The wet performance is great, no more hydroplaning. I couldn't be happier. I wish the Gen II had progressive springs like the 2010 and later, but that is the performance person in me speaking. I also bought the Optimus 12v battery specially designed for the Prius when the old one quit a month ago. Got it online for $160.00. Much better quality than the original, in every way.
  19. Kory Matthew
    Kory Matthew Junior Member
    37
    North Dakota
    I have to change my tires every year because of how much I drive, thus I have tried a lot of different tires and I am a huge Michelin fan. In my opinion they wear the best and are worth the money. I have taken the energy saver A/S through a ND winter. They are definitely not made for that, but if you are careful it can be done. However, I only got 40k miles out of them and they started to wear uneven at the end. It's probably because the winter here is really hard on tires because I can never get the full mileage from any tire. I currently have the Defenders on and I like them a lot. I'm projecting to get about 70 - 75k out of them. I haven't driven them through a winter yet but their wet traction is exceptional. I know up in the PNW you get more ice storms and icy conditions so I would stay away from LRR unless you use a winter set. I get about 2-3 mpg less with the defenders than the energy savers. It's much more difficult to get this car over 50mpg now. Also, the prius is not that bad on snow, you just have to have the right tires on.
  20. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I had the ecopia 422 on mine for about 2 years, I didn't love them and I didn't hate them either. They were better then the GY Integreties by far however I got better mileage with the Integrities. I live in Ohio and I found that the ecopias were a drastic improvement with snow traction, however they were a bit slippery in light rain. I also found the ecopias to be extremely squirelly at highway speeds especially when they were new. After they were worn out this past summer I was going to go back to GY Assurance Triple Tred tires, but I couldn't pass up a deal I saw at WalMart where I got a set of Goodyear Viva 2's out the door for just over $300 and my mileage is about the same and the tire performs better in every single way compared to the Ecopia 422 except they are a bit on the noisy side. This is the 4th set of tires I've had on my Prius and my favorite set was when I had a set of GY Assurance Triple Tred. If you get the Triple Treds though you have to get 195/60/15 since they don't come in the stock size of the Prius.
