reset/adjust temperature settings, in/out?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rwernst, Jan 29, 2017.
  1. rwernst
    rwernst Junior Member
    United States
    2005 Prius purchased new.
    Is there a way to adjust the inside and/or outside air temperature settings. Ever since I had a minor accident on right front, the inside temp has to be set WAY higher than it used to for comfort. Used to be 72-74° was fine and pretty much matched the exterior temp. Since car was fixed (several years ago, just now getting around to asking about it), I have to set the interior to around 78 instead.
    This, of course, messes with the automatic part of cabin air temp because of the discrepancy between inside and outside temps.
    Is there a way to calibrate or modify or reset what the car thinks is the temp vs. the actual temps?
    Thanks.
  2. b100
    b100 Member
    145
    75
    Netherlands
    Check your sensor in the front of the radiator.
    There should be a good distance between the sensor and the radiator
  3. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    If there isn’t anything wrong and you just want to adjust temperature offset you can do it with Techstream (Mini-VCI is good and cheap). There is offset adjustment for bought outside and inside temperatures.
  4. rwernst
    United States
    Thanks, I'll double check, but outside temp reporting seems close to accurate.
    b100 likes this.
  5. rwernst
    United States
    Who/what/link/description? of what Techstream and/or Mini-VCI is?
    Thanks.
  6. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    Google is your friend. Search Amazon/eBay, choose a vendor that sells 64-bit drivers (so it works on Win 7 (64-bit), 8.1, 10) and one with good feedback reputation and preferably local to you (or at least in the States).
  7. rwernst
    United States
    I DID google both and they referred to things that weren't clear.
    When asked for what something is that was recommended (get a dinglebot), it would be very helpful to indicate just what a dinglebot is and what it does and how it will help with the problem. Something like get a dinglebot from ebay, it'll come with instructions on how to straighten your framis shaft.
    Is Techstream hardware? software?? I don't want to spend potentially hundreds of dollars for this, hence my asking here, vs. just taking to Toyota. I see the mini-vci (what's vci stand for?) on ebay for $15, is that all I need?
  8. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
  9. rwernst
    United States
  10. rwernst
    United States
  11. dolj
    dolj Senior Member
    8,645
    4,395
    The forum software does that, it sees a colon followed by the letter p and interprets that as a smiley so substitutes the text for the unicode character that represents that smiley. It is annoying and if it was a bit smarter would look for a space either side before doing the substitution. Sadly it makes no difference if the p is capitalised or not. Fortunately, it doesn't change the embedded link, so it still works regardless.
    Fred_H likes this.
  12. Fred_H
    562
    488
    28
    Germany
    I bet a dinglebot could straighten that out. site:priuschat.com
