Reverse the risk of not having a spare tire.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Three60guy, Sep 23, 2012.
  1. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    16
    Racine, Wisconsin
    I was just looking tonight at a PBS Nova program titled "Making stuff stronger". The program talked about a a substance called Kevlar, the strongest synthetic material in the world. I theorized if this product could be used to make tires, we wouldn't need to be concerned with a lack of a spare tire in the Plug-in Prius.
    I then searched Priuschat and found the following 1 reply thread:
    Kevlar belt LRR tires ?? | PriusChat
    When that thread was created there wasn't a Plug-in. But now there could be a very good reason to purchase tires made with Kevlar.
    Has anyone else thought of this and has anyone made tires from Kevlar? And for that matter the size that a Plug-in could use?
    I'm going to do some more research, but thought I would create this thread to get the subject going.
    Cheers
  2. I am most ecstatic that we have a serious researcher on board wanting to have answers to serious problems. NOT putting you on. Seriously. TY
  3. Three60guy
    918
    16
    Racine, Wisconsin
  4. Three60guy
    918
    16
    Racine, Wisconsin
  5. Three60guy
    918
    16
    Racine, Wisconsin
    Here is a review of Kevlar tires. Looks like there is no consensus yet. But leaning toward a negative sentiment.
    TireRack.com Tire Reviews
  6. John H
    John H Senior Member
    2,208
    558
    I think modern car tires are typically steel belted radials which provide much of the same tread puncture protection as the kevlar bike tires. The unprotected area would be the sidewalls, and they need to flex quite a bit in normal operation. I found one brand mountain bike tire a few years back with kevlar in the sidewalls and it was very rigid. I used to use a kevlar liner as well, "snake skins", between the tube and the tire that worked well, but it focused on the tread area and not the sidewalls again. Now I ride on tubeless with a sealant.
    It seems that statistics have killed the spare tire, along with the convenience of roadside assistance. For the folks that need a spare tire, you can always add one. I think discount tire sells an emergency spare tire on a universal rim but I have not checked if it will fit a PiP, or a Volt.
  7. bisco
    51,678
    any updates?
  8. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Kevlar is unnecessary because tires already use steel. Sure, it would reduce weight, but at huge expense.
    I had a slow leak in the Jeep once. It turns out someone had shot the tread with a 9mm bullet, and it got lodged halfway into the tire.
    Tires are already made very tough, and punctures are rare. When they happen, tire plugs are extremely easy and durable.
    If money is no concern, then sure there are ways to avoid a flat. I could buy a helicopter to avoid flats, too.
  9. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    I have a "new" Prius spare tire from a junk yard (pardon .. an auto dismantler) and put it in the back for any out of town trips. I understand lots of folks have done the same.
  10. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    oem tires on the prius don't have steel belts, the toyos anyway, had a flat with less than 100 miles, toyota really saves pennies, shocks, 12v batteries, tires,,,yuck
    Redpoint5 likes this.
  11. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Yep, all the manufacturers employ the above. The trick is to find where the short cuts were taken on your brand and plan around it. IE: better tires, spare tire, shocks, brakes, etc. Also a BIG plus - get to know your vehicle, start with the basics - check fluids, tires. The owners manual is a good place to start. I have applied the above to all my vehicles and have minimized any "down time" on the road. Plus the more educated you are about your vehicle, you can be proud that you have the knowledge and some ability to correct any issues that come up.
    DBCassidy
  12. bisco
    51,678
    your 12v should be much better than in the past.
