Reversing camera angle adjustment
Discussion in 'Gen 4 Prius Main Forum' started by The Professor, Sep 2, 2020.
  1. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    So I upgraded to the latest firmware. I'm not sure if it's related, but the bottom quarter of my reversing camera image is suddenly my number plate. It wasn't like this before. It doesn't feel loose or anything similar. Does anyone know of a way to adjust the reversing camera angle, either physically or via software (e.g. the engineering menu)?
    Mambo Dave likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Perhaps @Elektroingenieur knows of something? If the camera housing isn't loose or hasn't been removed and reattached, then there must be something that happened in the update.
    alanclarkeau likes this.
  3. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Wow. I'll stick around for the answer to this one.
    I've always been curious of Honda's three-view-angles from one camera in their rear cameras. Normal, then about 170-degrees, and then almost straight down to the bumper (I could back the car within less than a centimeter of an object). I wonder if programming / firmware was how they achieved it, now, instead of three different lenses?
  4. Elektroingenieur
    2,515
    3,287
    Three Touring
    Unfortunately, I don’t know of any adjustment for the rear camera on U.S. or European models; see my previous posting.
    alanclarkeau and jerrymildred like this.
  5. The Professor
    598
    809
    UK
    Excel
    So I went into the hidden Engineering menu on the sat nav (turn on car without brake into Accessory mode, hold media button down while switching headlights from side lights to Auto 3 or 4 times), and went to Function / Check Setting, then Camera Setting appeared there but it was greyed out. I pressed the brake and Start to go into Ready mode, hit Back on the screen then back into Function / Check Setting and Camera Setting was then available. Pressed that and one of the options is Back Camera Setting, but it's greyed out. Tried putting it into Reverse, but nothing changed. No idea what to try next. So close...
    alanclarkeau, jerrymildred and krmcg like this.
  6. Elektroingenieur
    2,515
    3,287
    Three Touring
    Thanks for sharing the photos. That button might be a vestige of the head unit software for certain Japanese models, on which the rear view camera is often added as a dealer-installed option, with guide lines that have to be configured.
  7. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    I'm pretty sure the license plate has always been displayed on the bottom 25% of the screen, at least.
    What I would love to see is a panning camera that pans in the direction you are backing up into.
  8. The Professor
    598
    809
    UK
    Excel
    I have the guide lines and steerable lines on my camera (UK model).
    You'd think there'd be some way to calibrate them in software.
  9. The Professor
    598
    809
    UK
    Excel
    I'm certain mine has moved. Not only are the fixed guidelines on the display much further to the left than they were (I'm not hitting the kerb with my tyres before the lines touch it, previously I'd be 4" away), but I've never noticed my number plate before. I'm sure all i could see was the very edge of the bumper.
  10. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
  11. The Professor
    598
    809
    UK
    Excel
    Yeah that's exactly how mine work too.
    I'm not sure if I was clear before, but when I said "I'm certain mine have moved", I meant that I'm sure the alignment of those guidelines, or perhaps the camera, has moved recently. The camera feels solid and it doesn't physically move when I try to move it by hand. I can't see any damage to it or anything that supports it. It feels like a software calibration has been reset during the firmware update... but that's just a feeling.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    You can only select the type of back up lines in the nav setup/vehicle/back up camera setting but no way to adjust them.
    Interestingly, my 2016's engineering menu is slightly different to yours, yours looks like the Gen 3 and the Prius+ ones I had did, are you sure you have the correct update ?
    My camera setting button takes me to the same screen as your last one, unfortunately with the camera option greyed out like yours. :(
  13. The Professor
    598
    809
    UK
    Excel
    Well... I guess it's possible it's the wrong update. However, I'd be surprised if the wrong update worked at all on this head unit, or that it would allow it to install. The Toyota website (UK) only provides updates that are specific to your VIN number, and the version number matches what I expected it to be.
    Ah well... I can get used to it.
    kithmo likes this.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I suspect the camera has a wider angle view than what we see on the screen and it's gone into a different part of that view, so there's got to be some way to adjust it, probably dealer only though. :(
    You never know, the next update may bring it all back in line again, hopefully. ;)
  15. The Professor
    598
    809
    UK
    Excel
    Yeah I'd be surprised if there wasn't some way to do exactly that in software.
    #15 The Professor, Sep 6, 2020
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Bring on the next update. ;)
  17. Robert21PrimeLTD
    88
    42
    Nashville
    2 or 3 days ago, I noticed, first that the Projection-Info-Destination circles appear when I start my Prius (see photo #1). They haven’t appeared on startup since I purchased the car 2 years ago AND the rear view while in reverse has changed too. Now I also see the top of my license plate (see photo #2). I hadn’t before. I inspected the camera and mounting (see photo #3) and nothing appears ajar. Although the hole that surrounds the camera could have been a better fit, the camera lens and housing doesn’t move. Does Toyota download updated without any action from owners? Not sure why the camera view has changed. It’s not like someone/thing bumped into the rear of my vehicle. The camera is mounted away from the bumper and I don’t see any evidence of any rear scuffs or damage. Strange.
      File size:
      77.8 KB
      File size:
      77.9 KB
      File size:
      106.8 KB
