Rotating Prime tires at home
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by jb in NE, Apr 24, 2019.
  1. fuzzy1
    10,706
    I started noticing it in the manufacturer information, on the tires I have purchased, somewhere around three decades ago.
    Other manufacturers may have started noting it at different times.
  2. padroo
    padroo Senior Member
    2,763
    2,253
    I have two sets of wheels and in June after a trip in May I will install my American Racing wheels for the second time and doing a front to rear rotation on them. At the rate I am going I will never wear out both sets and will change them because of time.
  3. Peng Xiao
    Peng Xiao Junior Member
    84
    New Jersey
    2018 Prius Prime
    Rotation can be done at home, but not balancing, which also need.
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Good point. In my experience, tires rarely need to be balanced if they are properly balanced in the first place. I have gone through the entire life of a set of tires (60K) without balancing. Other tires I have had to have balanced during their lifetime.
  5. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    best jack points ?? i have a nice low profile 3 ton floor jack from costco, if there is a good front center jacking point, where is it? another one for the rear ?
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I only do balancing when the tire is mounted on a rim. Mounting and balancing come as a set at a tire shop. If the tire stays on the wheel mounted but uninstalled from a car, I don't think it needs wheel balancing before they are installed again. That said, the tire shops are now offering new technology on balancing something called "dynamic rotational balancing" or my tire company calls "road force balancing". When I bought my winter tires on rims, they offered me this service for an additional cost. Traditional "static balance" was included free of charge. I did not ask for the new balancing act. To tell the truth, I don't know if I need it or any difference I can feel if I did it.
    See my thread on this exact topic: Please show me where the floor jack suppose to go! | PriusChat
    #26 Salamander_King, Apr 26, 2019
    padroo and Mendel Leisk like this.
  7. padroo
    2,763
    2,253
    Salamander_King likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Never heard of it! Each of my new tires has a red and a yellow dot which is something I hadn't seen before. From what I've gleaned on the web, that has to do with matching the high and low spots of the wheels and tires, which must make it easier to get them dynamically balanced.
  9. Salamander_King
    11,024
    8,978
    New England
    Yeah, I first read about "road force balancing" at the tire web site where I purchased my winter tires and wheels. https://www.discounttiredirect.com/learn/road-force-balancing
    As I said, I did not purchase the service. They charge $10/tire for this service. I am not sure if $40 extra would have made any difference. Even without it, I did not feel any vibration when I put the wheels on my car.
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    True. Back in the day we mounted tires and if they were more than a few oz off balance, we remounted to get them closer to zero. I rarely find a shop that does that anymore. They just read the machine and put on the weights. "Here's your tire and wheel combination with 6 oz of weights..."
    #30 jb in NE, Apr 26, 2019
    jerrymildred likes this.
  11. jerrymildred
    11,517
    14,167
    Tampa, FL
    I worked in a Sears Auto Center in college. We would also remount if they took too much weight. I don't remember the limit. That was a LONG time ago!!
  12. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Red & yellow dots:
    The red dot is the point of maximum radial force variation, i. e., the stiffest point on the side wall. If you know the low point on the wheel, put the red dot here. Ignore the yellow dot. If you don't know the low point on the wheel, ignore the red dot.
    The yellow dot is at the lightest point on the tire. If you didn't use the red dot, put the yellow dot at the heaviest point on the wheel, i. e., at the valve stem.
    Not all tires have the colored dots. Not all tires of the same production run will have the dots. Not all tire makers use the dots or even the same dot code. But, if you have the dots, and know how to use them, your new tires might run more smoothly.
  13. a_gray_prius
    2,927
    783
    IL
    I typically have my tires installed with a road force balance (e.g. they use a Hunter GSP-9000 series). I've never had an issue with balance, but the shops who have and use the machine typically do a better job in general.
    On MotorWeek (I'm always amused how the show has kept the aesthetic of a 80s public access show for nigh on 30 years now).
    Road Force Balancing | MotorWeek
    Only 6oz? That's for amateurs!
    I never knew what the dots were for. This is really interesting.
  14. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Deleted
    #34 MikeDee, Aug 24, 2019
  15. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    I loved how I could jack up a whole side of the car with a miata! I miss that... probably going to pick up a NA/NB for the track again. I miss how fun those cars are and how cheap they are to maintain!
    Also like being able to fill up the gas tank from either side.
    As for tires, not sure why crossing symmetrical, non- directional tires would be an issue...
