Seeking advice on replacing rear garnish (trunk handle)
Discussion in 'Gen 2 Prius Main Forum' started by acadiaphile, Jul 6, 2017.
  1. acadiaphile
    acadiaphile Junior Member
    44
    A little over a year after I managed to "fix" the broken attachment on our 2005 Prius' rear garnish (trunk handle), it broke again. At this point, I figure I should get a replacement part. I'd initially planned on trying to find a salvaged part but: (a) it seems to be getting even harder to find such an item and (b) I worry that even if I found the part (and my DH insists it must match the red color), that it'd have the same inherent defect as the original part. So, I'm considering purchasing this OEM part from Auto Parts Cheaper. That the part is supposedly better designed than the original one (so it won't break), includes the Toyota logo, and that they use the VIN to assure the right paint color is appealing, but I'm not sure about the $300 price.
    Thanks in advance for sharing your advice about this replacement part and any suggestions for alternative part sources.
    52,689
    iirc, there should be a detailed thread here by patrick wong on his '07.
  3. JC91006
    16,923
    8,634
    Well you have to first learn not to pull on the "garnish". It's not a handle to pull up on. You simply press the button to open the hatch and then lift on the "metal" part of the hatch to open. If you treat this garnish as a handle, it'll keep breaking over and over again.
    $300 sounds really expensive, like the price of a new OEM part from Toyota. You may want to buy a used one that's the "wrong" color and have someone paint it. It might be less expensive.
  4. acadiaphile
    44
    Tell my DH not to pull on the "garnish"o_O. I warned him before the original piece broke. I warned him after my initial repairs not to pull on the garnish. When he told me it broke again I asked if he'd pulled on the part. You may imagine my response when he replied, "That's how you're supposed to open the hatch!"
    Honestly, I think part of the problem is that the original hatch lift supports are shot. As a result, after you release the hatch, you have to push it to get it opened.
    I proposed getting an "off" color part, but he wants the original color.
  5. bisco
    52,689
    maybe get some new struts.
  6. JC91006
    16,923
    8,634
    That's pretty funny
  7. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    You can tell him no, it is NOT how you open this hatch. The correct way is to press up on the rubber piece and lift it by continuing to apply upward pressure. At no point should he grab the garnish and lift on that.
    The switch operates by a timed relay and only activates the lock mechanism for about 700 ms, so you need to perform the "release and lift" in one fluid movement.
    I second bisco's advice above, maybe get the gas lift struts re-gassed or replaced too. It certainly won't help as that hatch is heavy enough with the help of working struts.
  8. JohnnyPrius
    JohnnyPrius Junior Member
    I fixed mine with two carriage bolts.
    SFO and anothergirl like this.
  9. anothergirl
    anothergirl Junior Member
    Albany, NY
  10. Lloyd-ss
    Lloyd-ss Member
    100
    96
    Ivy, VA
    Four Touring
    If you are SURE you want to go this route (two carriage bolts) you will need to remove the interior panel of the lift gate first so that you can see what is inside, and won't drill thru anything important like wires or switches or connectors. This isn't my repair, but it looks like person just drilled thru everything and put some nuts on the inside of the metal framework, after removing the interior panel, I hope. A little silicone caulking at the penetrations to keep water out might not be a bad idea.
    This is one of those repairs that can't be undone, so think about it first. Watch several of the you tube videos about removing the interior panel because that is all about knowing the "tricks". Removing the panel the first time will be difficult, but the second time will be much easier. Good luck.
  11. anothergirl
    Albany, NY
    Thanks. I've removed the panel before to replace the opening mechanism when it got all mushy. I'm thinking now I probably won't do this. I would have to also glue the garnish back together. I'm trying not to buy the garnish with the electrical mechanism built in since I just purchased and replaced the electronic portion 2 years ago. I was hoping to find just the plastic (presumably cheaper) garnish in my color 4S2 but so far have only found the garnish with the elecrtonics attached.
  12. dolj
    dolj Senior Member
    8,631
    4,385
    It is definitely available separately from a Toyota dealer color coded. Try one of the dealers that sell much cheaper online, out of state, if you don't mind a couple of days waiting.
    They are also available from third parties, but not sure of the quality. Haven't heard of any complaints.
    anothergirl and Lloyd-ss like this.
  13. anothergirl
    Albany, NY
    Great. Thanks. Any online dealer recommendations? I can do a Google search but not sure who the most popular ones are.
  14. dolj
    dolj Senior Member
    8,631
    4,385
    anothergirl likes this.
  15. anothergirl
    Albany, NY
    I'm finding some used ones on eBay. I don't need the electronics but it seems like it all comes as one unit. Does anyone know if just the plastic garnish is sold without the electronics? And does anyone know if it matters if my car has a camera? As far as I can tell there is not one model for a car with a camera and another model for no camera. I asked one of the eBay sellers but he/she did not know.
  16. bisco
    52,689
    i don't think the camera affects it, have you tried calling a dealer parts dept. for just the garnish?
  17. dolj
    dolj Senior Member
    8,631
    4,385
    The part numbers are:
    • 76801-47050-xx (without Smart Key)
    • 76801-47060-xx (with Smart Key)
    The "xx" indicates the color. What color is your Prius?
    Hope that helps.
  18. anothergirl
    Albany, NY
    4S2, driftwood pearl
  19. rbdigital
    rbdigital Hybrid Family Father
    24
    St. Petersburg, FL
    See a related post here: Hatchback liftgate struts broken | Page 2 | PriusChat
  20. anothergirl
    Albany, NY
    One of the eBay sellers was able to tell me last night that the part has a plug that snaps out to fit around the camera. I ended up purchasing that one for $134.
