Shuttering at partial throttle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dat Boi, Sep 21, 2016.
  1. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    Get miniVCI w/ Techstream off Amazon/eBay. A laptop will be required; ideally and old XP based one. Many posts on equipment and install help.
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
  3. JC91006
    16,939
    8,647
    Yikes 2009 wreck, sounds like elite scam battery
  4. Dat Boi
    Dat Boi Junior Member
    36
    Alton, Illinois
    I bought the battery from Elite Automotive.
    From what I am reading, everyone seems to have problems with them. I, on the other hand, had no issues with them, and I thought they had great customer service! The pack is still working great, they charged me $919, and kept my core. No other charges were made.
    I am going six months strong and the pack still holds a good charge and my MPGs are still in the lower 50s.
    Maybe I was the lucky one!
  5. exstudent
    2,214
    906
    Torrance, CA
    For $1K more, you could have bought a new OEM HV Battery from a dealer for $2071. Assuming the dealer would match other online prices. The HV ECUs would have to be transfered over, and a few other parts from the dead battery into the new battery.
    The exception (you) does not disprove the rule. The rule still stands: Elite Automotive has scamed/screwed people over.
    2% of attempted suicide jumpers, from the Golden Gate Bridge, SURVIVE.
    98% of the jumpers DIE!
    Do you feel lucky?
    Suicides at the Golden Gate Bridge - Wikipedia, the free encyclopedia
  6. Dat Boi
    36
    Alton, Illinois
    At the time, it was my only option. I guess when this pack finally fails, i'll look into getting a new OEM HV battery!
  7. Dat Boi
    36
    Alton, Illinois
    After watching the guy do the pack, it looks like a job I can tackle :)
  8. Andhebxu183)
    Andhebxu183) New Member
    IndianA
    I now have the same shuddering at low rpm of gas engine.
    Here is what happened.
    My prius had 294k on it when cv axles needed replaced. So, All at one time i replaced these parts:
    Ebay new cv axles and front struts
    Pepboys economy reman maf sensor
    Inner and outer tie rods
    Oem ball joints
    Ebay ignition coils
    Iridium plugs
    Autozone Rear wheel bearings, front ones have 100k on them
    Then drove to goodyear for alignment and new gy assurance tires.
    All rims are true.
    Noticed shudder on way back and a click/pop from both sides of car at initial forward movement. It sounds like strut noise. Struts came with new strut mounts. But these were ebay cheapies and were not identical to oem. Everything on frontend is tight and there is no sense of bad cv while turning or reversing. Rear struts are worn oem replacements. Perhaps on take off the car shifts weight backwards enough to make the fronts produce the click/pop?
    10k miles latter noticed a buldge outward on a tire and had that tire replaced. Other tires have sidewall dimples like i have seen many times on tires.
    I thought shudder disappeared when i had the spare tire on the front because the buldging tire wasnt safe to drive on.
    I put original coils back in but that wasnt the cause.
    I cleaned throttle body
    Ran fuel treatments
    New pcv
    Replace injector orings
    Replaced both motor mounts and dog bone torque mount underneath.
    One thing to point out, the passenger side replacement cv axle off ebay looked differrent but was same length. Like it was missing what i think was a vibration dampener donut located in middle of length of the shaft.
    I have read on net that it could be a misfiring engine.
    I have read it could be the cheap replacement axle inner cv joints.
    Exhaust seems to be clear
    Car runs like new except for shudder
    Still zippy
    Yes, original large battery. Had to replace the 294$ tiny battery once.
    Had to resolder the loose connector inside the display unit.
    New hid bulbs at 280k
    New large battery cooling fan
    Ive maintained it very well, even full brake bleeds.
    However, I have not replaced the air/fuel o2 sensors. That job will probably have to be replacing the exhaust manifold on back to the tailpipe.
    Toyota made odometers stop at 299,999 miles.
    Dealer can set it back for $500.
    I have 310k on the car now, all mine.
    I have to use the trip to keep track of the milage
    If i had breasts they would have blown the doors off by now the shudder is so bad!
    NORMAL POPS likes this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,992
    Texas Hill Country
    Back in 2016 it was not easy but now you can get some.
