Some observations after doing my own oil change on the Prime
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Pdog808, Jul 18, 2017.
  1. douglasjre
    douglasjre Senior Member
    2,180
    718
    Null, NL
    Um....u were kidding?
  2. Skapruisprime
    Skapruisprime Member
    122
    49
    MA
    Huh?
  3. Weasle543
    Weasle543 Member
    55
    38
    Ohio
    Heads up on the oil filter. I went to replace the oil and filter today and to my surprise on my 2017 Prime Plus with a build date of 11/17 has a spin on oil filter.
    Toyota P/N 90915-10003. Denso P/N FC115010-5033
  4. padroo
    padroo Senior Member
    2,763
    2,252
    Wow, I didn't know there was a spin on option.
    Made in China?
    #84 padroo, Feb 25, 2018
  5. Weasle543
    Weasle543 Member
    55
    38
    Ohio
  6. padroo
    2,763
    2,252
    I was surprised to see Toyota go to a cartridge type filter anyway. Ford went to a spin on in about 1957 not I see others are using the cartridge again.
    Just out of curiosity why did you get rid of a 2016 to buy a 2017, did you just want a prime?
  7. Weasle543
    Weasle543 Member
    55
    38
    Ohio
    I'd rather have a cartridge oil filter. Only complaint is they shouldn't cost more than a spin on.
    Yep. Wanted the electric range and electricity costs 5.2¢ kwh. No complaints about my 16 Prius 2.
    #87 Weasle543, Feb 25, 2018
  8. Skapruisprime
    122
    49
    MA
    What the??? Looks like I’ll have to return the oil cap and filter then
  9. Skapruisprime
    122
    49
    MA
    Movie? Is that mobil 1?
  10. Mark57
    2,945
    2,740
    OK
    Wow, that is a shock.
    I just now called the parts department again and they still say the USA 2017 Prius Prime takes a 04152-YZZA6 cartridge. I made them double check that they were looking at the 2017 Prime.
    Also, look at the time stamp 1:09 on this video of a guy doing his 2017 Prius Prime Premium and you can clearly see the cartridge housing.
    I have not been under my 2017 Advanced to actually look, but I certainly will before I do a change.
    Has anyone else been underneath to visually verify what kind of filter they actually have in their Prime?
    I also just found another video that seems to confirm what you have at 32 seconds in.
    #90 Mark57, Feb 26, 2018
  11. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    I just had my first oil change during 10K service at Toyota dealer using free Toyota Care about a month ago. Didn't check to see what kind of filter they installed. I am very curious now, for I still have brand new cartilage filters for Gen3 which I intend to use on Prime in future oil changes after Toyota Care runs out.
    #91 Salamander_King, Feb 26, 2018
    Mark57 likes this.
  12. padroo
    2,763
    2,252
    Just out of curiosity what was the build date of the OP Prius Prime. It would be interesting to see if cars after his build date have a spin on or cartridge filter.
  13. Mark57
    2,945
    2,740
    OK
    Post #83 "my 2017 Prime Plus with a build date of 11/17 has a spin on oil filter."
    Mine was built in August 2017 but I've not visually verified the type.
  14. Pdog808
    Pdog808 Active Member
    431
    287
    Los Angeles
    2018 Prius Prime
    My Prime Premium build date was February 2017.
    Also, I can verify that mine had a cartridge filter housing, although I did not change the filter, only the oil.
    Mark57 likes this.
  15. padroo
    2,763
    2,252
    I didn't catch the build date and it was one of the last ones they built it looks like. It will be interesting to see how many more and what their build date is.
    Mark57 likes this.
  16. Mark57
    2,945
    2,740
    OK
    Please do us a favor. It will be asked by someone else if I don't. Look under your engine hood. There is a white vehicle emission sticker on the hood with TOYOTA in the upper left corner. At the bottom center, it has your engine type designation. Mine is a 2ZR-FXE. Does that match yours? If it matches, and your build date is in November, we may be seeing a mid cycle production change. What a mess, if that's true.
    #96 Mark57, Feb 26, 2018
  17. Mendel Leisk
    41,463
    You guys have got to stop buying your oil filters by the case, lol.
    Why would they have switched to spin-on I wonder? Cost saving, complaints from service departments? Would regular Prius also be making the switch??
  18. Mark57
    2,945
    2,740
    OK
    We need more data and user feedback. This may be hard as most are taking advantage of the free Toyota care oil changes and have had no need to look. If we have the same engine in the same model year with two different types of oil filters, it's going to be a mess.
    kevins007 and Mendel Leisk like this.
  19. Pdog808
    431
    287
    Los Angeles
    2018 Prius Prime
    Does anyone know if the spin-on is backwards compatible to the cartridge filter design?
  20. Skapruisprime
    122
    49
    MA
    Where can I see my built date?
    #100 Skapruisprime, Feb 26, 2018
