Spare Tire for 2022 XLE
Discussion in 'Gen 4 Prius Main Forum' started by kuffs, Jan 10, 2022.
  1. kuffs
    kuffs Now 2 Prius Owner !
    Floriduh
    Can you add a temporary spare tire by cutting some of the styrofoam in the XLEs cargo area? Has this been done? If so how? Can you order a “spare tire” upgrade? I own a 2011 Prius IV and want to get a new one. No spare tire is my problem and the LE … just not enough options. Thanks. Kuffs
    49,694
    if not, you could carry it in the hatch like i do, or behind a front seat
  3. MalachyNG
    MalachyNG Active Member
    300
    222
    Northern NY
    2022 Prius Prime
    The Gen4 2016 Prius Four (similar to a Limited current year I think?) I had did have a wheel well under all that foam. The space saver spare I kept from my 2013 fit in there just needed the tie down. I never got around to cutting up the foam but you can do that. There is also a foam set you can purchase from LE or Prius Two trims that have spares. It's pricy but possible. A few people were able to cut the foam to fit a full size spare. Really any spare from gen 3 or gen 4 will fit and I've heard wheels from corollas do too.
    Unless you're looking at an XLE AWDe. The extra components for the AWD are kept in that space.
  4. kuffs
    Floriduh
    Thank you for your help…..
  5. Mendel Leisk
    38,875
    Simplest/cheapest solution is to stick with level(s) having the spare as standard equipment. If I'm not mistaken that only the base level now?
    Is it just me or is that kinda nuts, btw...
    daisy555 likes this.
  6. Rapher
    Rapher Junior Member
    Cincinnati
    2022 Prius
    See the following post for useful information on a spare tire and rim that will fit and images.
    Can 2019 LE spare fit in the XLE? | PriusChat
    My question for the XLE is what is the best way to remove the foam inserts to expose the wheel well. There are white plastic 'screws' on either side of the foam pieces. Some indicate that it can be screwed out. Other say that it pops out (using a tape covered screwdiver tip). And, what is the part number for the hold down screw to keep wheel in place...
  7. ocean view
    ocean view Junior Member
    30
    Western MA
    2022 Prius
    Spare tire retainer part number is 51931-47030.
    Plenty on ebay.
  8. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
  9. texasdiver
    texasdiver Member
    67
    103
    Vancouver WA
    Four Touring
    Mambo Dave likes this.
