Speaker removal Prime 2017
Discussion in 'Prime Audio, Electronics, and Infotainment' started by mveras1972, Jul 14, 2019.
  1. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    How do I go about removing the top of the dash small speakers? I have the JBL system that comes with the Prime Advanced and want to install aftermarket tweeters on top of the speaker grill.
    iPhone ?
  2. rain27
    rain27 Junior Member
    30
    2018 Prius Prime
    Looks like you can just pry off the speaker covers to gain access. If they are like the non-JBL system, the speaker cover is just held there by clips.
  3. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Anyone know if that’s true? What is the best edge to pry open?
    iPhone ?
  4. Elektroingenieur
    2,515
    3,259
    Three Touring
    The Repair Manual (more info) says to remove the front pillar (A-pillar) garnish first, and then to grasp and remove the speaker panel (grille) sub-assembly. No prying should be needed. When removing the garnish, apply protective tape at the specified location, and be prepared to replace the clip.
    Since there is an airbag inside the A pillar, I’d also suggest disconnecting the negative (–) terminal from the auxiliary (12 volt) battery, and then waiting 90 seconds, before starting work. You really don’t want the airbag to deploy while you’re working nearby.
    mveras1972 and frodoz737 like this.
  5. rain27
    30
    2018 Prius Prime
    I didn't bother to remove the A pillar. You can use a hook tool in between the in-place A pillar and the speaker cover and pull upward. Either way will work.
    mveras1972 likes this.
  6. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Cool. Thanks! I will try that. I have removed the pillar cover before so it’s not that hard.
    iPhone ?
  7. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    So here’s how I went about this. I modified one of my tools to remove the tweeter grill. The factory tweeter was not that hard to remove, just two screws. The connector comes off the tweeter rather easily after you find the latch. I soldered my new (additional) tweeters to the same points where the factory tweeter is soldered.
    What I found odd is that there is a capacitor on the factory tweeter that goes to an additional solder point that don’t seem to be used at all. What are these for?
    I decided to connect my new tweeters to the direct connection instead of the connection point that passes through the capacitor. The new tweeters already have one and when I tested the audio, I could not hear the tweeters on that connection with the extra capacitor. I measured 8 Ohms through the factory tweeter capacitor that appears to be unused and 4 Ohms in the points that are used by the factory tweeter.
    So overall, there’s a modest improvement in sound crispness, maybe 15% brighter? I was a bit disappointed there, but any improvement I can get is fine with me.
    iPhone ?
    #7 mveras1972, Aug 5, 2019
    7707Prime likes this.
  8. 7707Prime
    7707Prime Junior Member
    27
    27
    Planet Houston
    Was the capacitor under the foam padding? Yeesh, now I need to go back and double-check my install, as I used the black lead for my replacement speakers. Thanks for the heads-up.
  9. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    No. The capacitor is right by the soldering points. It is just bundled with the wires and dressed up with a black protector wire jacket. The picture I posted you can see the capacitor after I removed the protector. Just be careful with connecting speakers in parallel because that lowers the impedance which will force your radio amplifier more.
  10. 7707Prime
    27
    27
    Planet Houston
    Thanks - I meant to indicate the protector jacket. I did not remove it during my install, so I didn't catch the extra capacitor.
    Will run some more tests with a multimeter on the dash speakers in the near future.
