Starting the ICE with bad hybrid batteries
Discussion in 'Gen 2 Prius Main Forum' started by DWJM2513, Apr 26, 2020.
  1. DWJM2513
    DWJM2513 Junior Member
    64
    24
    US
    My 2005 Prius has been parked for the last 6 months due to bad hybrid batteries. Ive got a brand new 12v battery in it but cannot start the engine to get everything flowing in there. Is there something I can do to get that engine fired up and run it for 20 or so minutes with 2 dead cells in my hybrid batteries?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Probably NOT......since the 12 V battery only "enables" the vehicle to start.
    It is the HV hybrid battery that actually turns the engine over to start it.
    52,891
    no, you'll have to repair the battery first. is the car making ready? are you getting the red triangle? the engine is the last thing to worry about.
  4. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    After six months, why the need to turn over the engine at this point?
    Not sure what level of DIY you would be willing to consider, but you could buy a used HV charger and top up the battery. Though even after charging, that failed HV battery might not have enough voltage to turn over or start the ICE.
    #4 SFO, Apr 26, 2020
  5. DWJM2513
    64
    24
    US
    Getting the red triangle, abs, VSC, check engine and a few codes. i think P0A80 and P3013 are the active codes. The ready light was coming up last time i got into it
    Do you have any leads to where i can buy one for a decent price? I dont have a whole lot of time or money to be throwing at the prius right now. Also just to keep things charged up and moving but I supposed I let it go too long
    #5 DWJM2513, Apr 26, 2020
  6. bisco
    52,891
    probably better off to get dr.prius, and just replace the bad cells for now
    SFO likes this.
  7. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    You might find this posting of interest then.
  8. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    Let us know what part of the US you're in and we can point you to someone to help you or loan you equipment to get the battery going again.
  9. DWJM2513
    64
    24
    US
    That would be awesome! I live near Ohio University in Athens, Ohio if anyone is around here. It's like Priusville around here
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    What equipment do you think will "fix" cells that are "dead" ??
  11. DWJM2513
    64
    24
    US
    This is what I'm calling dead cells Screenshot_20191130-163412_Dr%20Prius.jpg
    SFO likes this.
  12. bisco
    52,891
    you would replace the bad cells and rebalance
    Raytheeagle and SFO like this.
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    I agree they look pretty dead.
    AND once in that condition, they typically can NOT be recovered.
  14. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    It looks like you might have 2-4 bad modules, a quick module swap and a top balance could get you into 'ready' mode again.
