Strange Noise
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Jeremy Snow, Apr 15, 2020.
  1. Jeremy Snow
    Jeremy Snow New Member
    Wi
    2018 Prius
    My wifes car is making this noise, does anyone have any ideas?
  2. Jeremy Snow
    Wi
    2018 Prius
    52,888
    when it makes this sound, and how long? is it a prime? under warranty?
    maybe the brake actuator, hvac, or coolant pump
  4. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Does it stop when you turn the HVAC fan off? I'd take the cabin air filter out and have a look.
    jerrymildred likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    My first thought, too. Sounds like a stick got sucked in through the vent openings. They can really pile up there under the hood.
  6. Jeremy Snow
    Wi
    2018 Prius
    35k miles, not prime out of warranty. Makes the noise for about a min after turning the car on,but not every time. Gets louder when accelerating.
  7. bisco
    52,888
    check the 12v health
  8. Jeremy Snow
    Wi
    2018 Prius
    None of the above, im hoping that someone will just recognise the noise. :(
  9. bisco
    52,888
    what did the 12v peg out at
  10. Tips
    Tips Member
    128
    66
    Grand Forks, B.C. Canada
    2020 Prius Prime
  11. Diemaster
    Diemaster Active Member
    302
    265
    so. cal
    To my Untrained ears it sounds like one of the HVAC mode motors is jammed and it's skipping teeth in the small gearbox b/c of the jam. As said above, might be a stick or other foreign matter jammed above the blower motor as thats usually where the recirculate/fresh outside air motor is.
