Sudden loss of power, Red Triangle, Won't Start + P3190
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bgustafson, Dec 22, 2017.
  1. Patrick Wong
    18,210
    6,510
    Have you tried to measure fuel line pressure yet? That would show whether the fuel pump is operational. As you may know the fuel pump is part of the fuel tank, hence the tank would have to be replaced if the fuel pump has a problem.
    The fuel line pressure should be 43 psi or more.
    #101 Patrick Wong, Jan 7, 2018
  2. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    I don't have the tools to measure fuel line pressure, unfortunately. I should've had my mechanic do that. Yes - I read the entire fuel bladder will need to be replaced.
  3. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    $90 - Master Fuel Injection Pressure Test Kit
    or maybe this less expensive version: $20 - Fuel Injection Pump Tester
    Have you had a chance to use your newly acquired MVCI cable for DTC retrieval?
    Let us know if you need a hand figuring anything out.
    You might consider towing it to "Best Hybrid Battery" for repair, unless they have a mobile mechanic that can help you.
    edthefox5 and Raytheeagle like this.
  4. Bgustafson
    259
    222
    Chicago
    Thanks! Wish I knew about the pump tester from Harbor Freight sooner! I haven't had a chance to try retrieving the codes yet since the car is currently in Toyota possession. Most likely I will have it towed to Best Hybrid tomorrow. They charge less for labor than my shop or Toyota, and they also have the tools to recharge the HV battery in addition to hopefully repairing the fuel pump or whatever the final diagnosis is.
    I'm going to try setting up Techstream today or tomorrow, so if I run into any questions I will definitely ask!(y)
    SFO and Raytheeagle like this.
  5. Bgustafson
    259
    222
    Chicago
    Well Best Hybrid Batteries is stumped. They've gone through all the troubleshooting steps, and verified it's not the fuel pump as well. They suspect there is something going on with the air / fuel ratio with maybe a small crack in the manifold which is leaking air? They mentioned it (could) be the ECU, but they highly doubt it because they've never run into one of those failing before. They also wondered if the oil was overfilled at one point which could've lead to the damage. (It had not been changed recently prior to the failure, though).
    So they said basically most likely I need an engine replacement, which obviously they don't do. So now the question is... do I try to get a salvage engine and a shop to do the repair, then sell or keep? Sell as is? It has 176k.
  6. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Just a short recap, so we're all on the same page (items have been skipped like, MAF cleaning and manifold..)
    The only code read with a scanner was DTC 3190; and that wasn't retrieved with Techstream.
    Various mechanics claim the engine fires when 'starting fluid' is used. (are we sure its not just the engine spinning or turning over?)
    You obtained a mini-vci cable and have yet to use it, or let a mechanic use it.
    The current mechanic, Best Hybrid Batteries, ran "through all the trouble shooting steps"... Which steps are those? Were they trouble shooting steps related to DTC 3190 or some other code(s)?
    Fuel pressure was checked (near the engine) and was 43 PSI or greater.
    Vehicle still doesn't start, and also refuses to throw any codes?
    Raytheeagle likes this.
  7. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    sounds like they are playing the guessing game at your expense, lets say you do put a new motor in and the ECU was the real problem are they going to give you your money back? hell no.. before playing games with thousands of dollars just take it to the dealer and let them do the diagnostic, you can always get it fixed somewhere else... join AAA Premium (or what ever they call it now) and after 2 days use the free towing. realistically you have a 12 year old car worth maybe $2500,(don't post the KBB value of the car no one has ever paid book value on an older car unless they are stoned) if you sell it not running you might get 1200 for it.. flip a coin
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Wow this thread got ugly it went from the OP scoffing at P3190 to an engine replacement.
  9. JC91006
    16,769
    8,567
    Loss of power issues
    1. Fuel delivery
    2. Bad throttle body
  10. Bgustafson
    259
    222
    Chicago
    To recap: here are the troubleshooting steps which have been preformed by various parties:
    - Cleaned and replaced MAF, cleaned throttle body.
    - Replaced 12v
    - Followed the troubleshooting steps listed here. - however did NOT check fuel pressure near engine (see below).
    - Yes - I have used Techstream to diagnose. It's strangely unhelpful. The only code we get is "Poor engine performance"
    Some other notes:
    With the HV battery charged, the gas engine WILL run for 5-10 seconds before throwing the code and warning lights. If we shut off the engine before it does this, we can restart it again with no issues. Only thing can’t confirm is if there could be a crack in intake manifold or engine case, which could be causing an air leak. I have not tried replacing the throttle body.
    I just signed up for AAA last week, so I'm taking it back to Toyota with a fully charged HV battery. They wanted to replace the battery last time, which I wanted to avoid paying them for.
    SFO likes this.
  11. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    The engine runs without starting fluid now? o_O
  12. Bgustafson
    259
    222
    Chicago
    I specifically asked Best Hybrid if all they were hearing was just the electric engine running, and they said no. They said the gas engine does run without starter fluid. Let's keep my previous mechanic out of this... I don't really trust them any more. They drained my HV battery once already. -_-
  13. JC91006
    16,769
    8,567
    This has been covered before, your engine is NOT running, it's just the HV battery doing the work. After 10 seconds, it quits and throws codes.
  14. padroo
    padroo Senior Member
    2,763
    2,252
    I just got here. Something to avoid. Whoever diagnoses the problem make sure they supply any parts this is why. Worst case situation. You tell a garage to replace the engine and if it still doesn't run you have to pay them because they replaced the engine. They troubleshoot it and tell you it is the engine, they replace the engine they supply the engine and it doesn't fix the car it's their problem now. Just some thoughts.
  15. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Overall it sounds like progress is being made, just slowly.
    If a mechanic used an Ohm meter for (DTC 3190) steps 6 through 11 and everything checked out as 'OK', then I would go back through the (DTC 3190) check list (step by step) one last time (before towing to the dealer) starting with step 1 - reading the code(s) thrown.
    Try checking for intake leak/blockage (step 3), also check for fuel pressure (step 5).
    If you make it through all of the steps again (1 to 11) with a bunch of "OK's", next step is shopping for an ECU (that would be after step 11, under 'OK').. which the dealer may explain ($$$$) once they charge a diagnostic fee to do the above all over again. Of course they could find the actually problem and tell you something else ($$$).
  16. Bgustafson
    259
    222
    Chicago
    Thanks for everyone's patience, I know my troubleshooting skills have been considerably convoluted and backwards. I'm just starting to learn mechanics, so I'm very green. My next question for you would be - what do you advise my spending threshold should be for this repair? How much more do I sink into it?
    I purchased this 2006 a year ago for $6,000. (150k from Atlanta with no salt damage & clean VIN)
    So far, between tows and diagnostic fees, I've put a whopping $1,735.02 into this repair alone. I feel I'm right on the threshold of deciding how much it's worth.
    Advise appreciated.
  17. Beachbummm
    1,160
    392
    you paid twice what it was worth when you bought it so why dump more money into a 12 year old car? sell it
  18. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Without knowing the actual problem and the outside cost of parts and repair (maybe you can DIY), it would be hard to advise.
    Does sound excessive for three or four $200 tows and a handful of diagnostic hours that have left you wondering whether to continue opening a wallet.
    Guessing that $1735 includes the rebuilt/used battery you purchased months ago, or is that strictly coffee clutching / hand warming time?
    Where is the vehicle now, and what is the next plan of action?
  19. Bgustafson
    259
    222
    Chicago
    The $1735 sadly does not include my reconditioned battery, that was another $1,500 back in the spring. Also just had the combo meter done for $400. The 1735 is a combination of tows, hours of diagnosis, Best Hybrid sent a guy out to recharge the HV once, and a new installed 12v.
    At this point, I see two, (maybe) three options:
    A) Use AAA for a tow back to Toyota with a fully charged HV battery and hope they get to the bottom of the problem.
    B) Sell as is.
    C) Repair, then sell.
    I was really hoping this car would get me a lot further. My parents own a 2007 Prius with nearly 300k on it now - but they've just gotten lucky with no major repairs (yet). As soon as a repair comes along, they'll just dump it.
  20. JC91006
    16,769
    8,567
    1500+1750+400? At this point, you should hopefully get it repaired for under $1000 and get some use out of this car. If you sell it (if you can afford to do it), then sell it before the repair and don't look back
