Suspension/handling mod question
Discussion in 'Prius c Accessories and Modifications' started by col127, Aug 2, 2013.
  1. col127
    col127 Member
    345
    Illinois
    Hey GUys!
    Had a quick question... thinking of what to do next with my car . I want to improve the handling and stability of it in cornering/turns.
    Would lower the car be better? Like with springs? Or getting an antisway rear bar? Those options seem to be in the $200-$300 range which I'm fine with.
    I've added a mid-chasis brace which helped some, but I want to do something more.
    My concern with lowering the car too much is scraping the bottom on like bumps and stuff :)''
    Thoughts? Anything else I should consider too that I havent listed here?
  2. CraigB
    CraigB Member
    205
    96
    SF Bay Area, CA
    I went with Tein H Tech springs using the stock shocks/struts and the ride is pretty comfortable. I have a two finger gap and no issues with speedbumps. Most driveways are no brainer going in but going out just take it slow and no issue. Here's a thread when I was on my stock alloys; there's another thread titled Aftermarket Wheels that shows me on 16's...which actually improved my ride quality. I'm considering a rear sway but undecided. Springs + installation and wheel alignment ran me $550.
    Eibach Springs | PriusChat
  3. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    I would definitely recommend the rear sway bar first.
    Then get some springs or coilovers.
    H-Techs are a good choice if you don't want your car too low and scrape everywhere.
  4. col127
    col127 Member
    345
    Illinois
    Thanks for the feedback. Maybe I'll do that first and see how it feels :)
    Are there any potential "cons" to installing a rear sway bar?
