System Not installed Error!
Discussion in 'Prius v Audio and Electronics' started by vw4motion, Sep 12, 2017.
  1. vw4motion
    vw4motion New Member
    Washington DC
    2013 Prius v wagon
    Just last week, I get "System not installed error" when I press the "Apps" button on my 2013 Prius V three. I also noticed sometime ago that USB port is not charging phones any longer (no power). Moreover, radio would randomly restart during driving. USB/Radio restart issues were there for longer, but system not installed error is new major issue (there may be bluetooth issue too but need to test it out).
    Any thoughts? Head unit went bad or I can somehow fix this on my own? Wonder what dealer would say as I did not take the car in yet.
    Many thanks - please offer any advise you may have.
  2. Air_Boss
    Air_Boss Senior Member
    4,245
    1,195
    New Yawk
    Did you recently do an Entune firmware update? If not, how about trying one.
  3. vw4motion
    Washington DC
    2013 Prius v wagon
    I have not performed any updates since I bought the car. How do I make an update for Entune firmware? USB port is not charging phones any longer - not sure of a mechanism to update Entune. Please advise.
  4. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
  5. Air_Boss
    4,245
    1,195
    New Yawk
    If the USB is not powered, chances are it won't pass data either. Anyone know whether the USB port is fused to the AUX power? You would need USB connectivity to do the Entune update, and I suspect that also means a need for power connectivity.
  6. Ogre Prius
    Ogre Prius New Member
    @vw4motion - did you ever find a resolution to your issue. Mine is doing the same thing. “System not installed” error and USB port not working.
  7. Air_Boss
    4,245
    1,195
    New Yawk
    Did it brick on an Entune update?
  8. Ogre Prius
    No, just randomly started with the error. Tried to do an update but USB port not working.
  9. Ogre Prius
    Update, it seems my entune box was malfunctioning so I pulled out the radio and unplugged it from the main unit. Also moved the main power cord over from the entune Nav box to the main unit empty port. Now Bluetooth and USB port are back active. Only down side is I don’t have nav and the apps but didn’t use them anyway. Hope that helps someone.
  10. zlajac
    zlajac Junior Member
    FL
    Where is this entune nav box? How do I disconnect it from the radio?
  11. Air_Boss
    4,245
    1,195
    New Yawk
    Seems as if the power pass through to USB port from the Entune box failed, along with the ‘System’. Software or hardware, I wonder?
  12. Lantern11226
    Lantern11226 New Member
    brooklyn
    can anyone help me out with this hack of removing the entune box? my mechanic wont do it, nor will a toyota dealership....
