Tire pressure sensor
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by houriganterry, Apr 26, 2021.
  1. houriganterry
    houriganterry Junior Member
    How many pounds below the pressure setting I choose for my tires does the pressure alarm indicate low pressure? Is it preset for factory recommendations? If I were to choose 40 pounds,
    would it indicate low pressure at, let’s say 32, instead of 26? Is it a percentage below current pressures?
  2. Tideland Prius
    16,073
    I don't actually know the exact threshold but typically it's 15% below.
  3. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Welcome. I assume you have a Prime since this is in the Prime forum. (The same would be true for any Gen 4, I think.) It would be really really helpful if you put your car in your profile info. Location also often helps.
    Anyway, I don't know the threshold either, but it's based on the pressure you have when you initialize it in the car's settings.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Every Toyota I've had has been ~5 lb threshold. I sometimes pump them up a few lb higher than I want then reset the TPMS before lowering them down again. That way I wind up with a 2-3 lb threshold.
  5. Salamander_King
    Salamander_King Senior Member
    10,964
    8,840
    New England
    Yeah, I have never checked the exact threshold on mine. But it should be easy to check. Just let the air escape from the tire and check the psi and drive a few miles to see if the TPMS warning light comes on. I would check it for you if I still had the car, but I no longer own a car, so I must wait for someone to check this.
