Tire Valve Caps, Tiny!
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Russ Bohn, Oct 16, 2017.
  1. Russ Bohn
    Russ Bohn Junior Member
    31
    Overland Park, Kansas
    I checked my air pressure for the first time the other day.
    It is a near art form to get your fingers in the wheel cover slot to screw off the valve caps, and its almost worse putting them back on. The tire valve caps are small and cheaply made. I had three fall into the wheel covers. I took one of the covers off but discovered the caps rolled under the car. I moved the car and found two, the third I did not find, but near the air station, I found another driver's discarded cap, much bigger and it was far easier to manipulate. I suspect the 3rd cap now may be part of the braking system!
  2. ChapmanF
    18,985
    Even though they have holes for the stems to poke through, I just pull my wheel covers off to add air, then put them back. It's quick, and access is easy then.
    I've got one of these thumb-release air chucks that just doesn't always want to seal well if I'm trying to wiggle it on through the wheel cover hole, anyway.
    -Chap
    Andyprius1 likes this.
  3. DavidA
    2,349
    1,825
    Chicago western burbs
    Valve cap access is one of several reasons I have never had the wheel covers on the wheels.
    Andyprius1 and WilDavis like this.
  4. jungleland1972
    73
    65
    Chesapeake Beach, MD
    Glad I am not the only one. I have checked the tires pressure twice and have lost 2 caps already (but found one in the driveway days later after it apparently rolled out from the wheel cover).
  5. Mendel Leisk
    42,299
    Maybe a short piece of vacuum hose, if you can find the right inside diameter, would help: push it over the valve cap and unscrew, lift out?
    jerrymildred and ILuvMyPriusToo like this.
  6. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    There's a socket size that fits the caps perfectly and I use a socket screwdriver. It's tight enough that the caps stay in the socket so you don't lose them and for ease of putting them back. If anyone's interested in the exact size, I'll go out to my car and check.
  7. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    ok, do that:D
    jerrymildred likes this.
  8. priuscatprimeguy
    2,730
    2,640
    please:cry:
  9. Bob Comer
    708
    460
    11/32 is the size and in case I wasn't clear, here's a pic.
  10. priuscatprimeguy
    2,730
    2,640
    thanx:D
  11. Bob Comer
    708
    460
    You're welcome!
    priuscatprimeguy likes this.
  12. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My other problem is that my air compressor will not reach into the hole and provide an air tight fit. One solution is to temporarily attach a valve stem extension (they stick out too far to leave then permanently attached) and then checking the psi and adding air are no longer a problem.
    JeffD
  13. Mark57
    2,945
    2,740
    OK
    Don't put the whole air compressor into the hole . . . . . Kidding, sorry you left that one wide open. ;)
    The extensions work well. This is another reason I removed my wheel covers.
    William Redoubt and Andyprius1 like this.
  14. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Very ingenious
  15. RRxing
    RRxing Senior Member
    2,562
    1,841
    NEPA
    Just think of the weight savings using these tiny caps... :rolleyes:
  16. ChapmanF
    18,985
    Doesn't screwing the valve stem extension on and then off again soak up more time than yanking the wheel cover off and bopping it back on when finished?
    -Chap
  17. Andyprius1
    2,327
    859
    Cool CA
    What surprised me is how easy the wheel covers come off. Grab each side and pull. and done.
  18. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    But:
    • It doesn't cause bruises on the heal of my hand. (getting the wheel covers back on)
    • It doesn't shorten wheel cover life. (My 2004 wheel covers broke about halfway through their life from the stresses of on/off)
    JeffD
    Prodigyplace likes this.
  19. I've already yelled at two of my tire caps... and then at a third cap that vanished even after rolling the car back and forth :mad:
    I seriously am nervous about bending/braking/snapping these pizza covers by "doing it wrong" on my own. So, I'm grabbing two of the five handles, through triangular openings, and then pulling straight out, firm and hard, normal to the plane of the wheel? Would that damage the overall shape of the cover? And there's no twisting involved, just pull? What about putting them back on?
  20. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    As others have mentioned, leave the plastic covers off, filling the center hole of the rim can be done with a Toyota part ($$$) or a 2$ 1 1/2” electric panel plug, you need to check tire pressure monthly, the plastic covers will suffer, save them for trade in time. (I pop them off with a screwdriver)
