Tire Valve Caps, Tiny!
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Russ Bohn, Oct 16, 2017.
  1. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    You are not alone, those valve stem caps are somewhat difficult to R & R with the hubcaps on.
    "Screw" driver tool with "stick'em" goo is a good answer.
    I'd doubt the cap went into the brake system (calipers), yet if it did I'd look closer in, around and behind the rotors.
    Maybe use high pressure compressed air and blow out the area?
    Good hunting!
    Prodigyplace likes this.
  2. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Take a cap to the hardware store and get a 6" length of rubber tubing that will fit over the cap with a little pressure. You can then press the tubing over the cap and twist the hose to easily remove the cap. Using the hose you can also thread the cap back on and tighten it up and then pull the hose off
  3. Mendel Leisk
    42,376
    Is it tricky getting an air hose on too? Seems like cover removal has several advantages.
    At least 4th Gen rims are not ghetto-black.
    Mark57 likes this.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I agree, keeps them preserved upon selling, no longer have to concern yourself, easier to clean wheel AND
    fill tires. Also nothing can hide in back of hubcaps and plot against you. Tomorrow is “ Hubcap Freedom Day”
    If this works out, next project will be to remove wheels!
    Mark57 likes this.
  5. Mendel Leisk
    42,376
    The other day I was checking out the fit of these 15" PIP rims. Why Toyota didn't go with something like this from the get go, ditch the wheel cover nonsense, is beyond me.
    (Our OEM in foreground.)
    #25 Mendel Leisk, Nov 24, 2017
    Andyprius1 likes this.
  6. DavidA
    2,349
    1,825
    Chicago western burbs
    In Europe, and I think the UK, the Prime comes with nice alloy wheels from the get-go. No plastic frisbees.
  7. Andyprius1
    2,327
    859
    Cool CA
    We have to join the EU.
