Total Load Capacity Doesn't Seem to Match Interior Room
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Jan 19, 2013.
  1. BZzap!
    BZzap! Senior Member
    1,607
    878
    Manufacturer load limits are also related to the tire ratings. Probably more that you think. Prius, with it's LRR tires, can surpass the GVW fairly easily. The car itself is relatively heavy for it's size. And with the light weight tires, can be marginal with 4 adults in the car. Safety is the key word, not so much as what the car is capable of carrying.
    OceanEyes likes this.
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The GY Assurance Fuel Max tires on my Gen III are rated for 1279 lb ea or 5116 lb total. That is close to 2,000 lb over the empty vehicle weight.
    WE0H likes this.
  3. BZzap!
    1,607
    878
    The following is from a Prius E-mail group and the author is a gentleman named Mike Bridges. He has obviously done his homework concerning dynamic tire loading.
    I
    take no credit for any of the quoted material.
    "I am considering replacing my 2003 Prius OEM
    I am considering replacing my 2003 Prius OEM Potenza's (pretty worn
    @35K) with:
    Uniroyal Tiger Paw Touring T
    P185/60R14 82T
    908 rev/mile
    1047lbs @44psi load rating
    11/32 inch tread depth
    22.9 in diamter
    "A" Traction
    "B" Temp
    660 Treadwear
    80k warranty
    $66.40/tire
    Any comments on noise or handling etc.?
    I have read all of the posts on load ratings and have the following
    question:
    The Gross Vehicle Front Axle Rating for O3 Prius is 1970lbs. Now
    assume the car is loaded and the weight distributed such that this is
    the ACTUAL STATIC front axle weight. The resulting tire load is 985lbs
    and I am using 94% (= 985/1047 x 100%) of the Tiger Paw tire load
    capacity (6% margin). Similarly I would be using 89% of the Potenza
    load capacity (11% margin).
    When braking and cornering the actual load experienced by the front
    tires can actually exceed the static load. Is the extra 5% margin I
    get from the Potenza absolutely required to handle the dynamc loading?
    The Toyota engineers put that 11% margin in for a reason so I guess I
    am really asking how far would people feel comfortable deviating from
    that margin?"
    Thanks!
    Mike
    (pretty worn
    @35K) with:
    P185/60R14 82T
    908 rev/mile
    22.9 in diamter
    "A" Traction
    "B" Temp
    660 Treadwear
    80k warranty
    $66.40/tire
    question:
    that margin?
    Thanks!
    Mike
  4. WE0H
    WE0H Senior Member
    3,247
    528
    What's the email group address?
    Thanks,
    Mike
  5. BZzap!
    1,607
    878
    WE0H likes this.
  6. WE0H
    WE0H Senior Member
    3,247
    528
    That's a Yahoo Group. I see I was already a member :)
    Mike
  7. fuzzy1
    10,687
    Note that this load rating is likely valid only when the tires are inflated to the rating pressure molded into the sidewall.
    The car maker's recommended pressure on the door placard is lower, requiring that the tire load ratings also be reduced (de-rated).
    Now, many of us ignore the door placard number and use something closer to the tire sidewall pressure number, so the tire load rating is more valid. :D
  8. WE0H
    WE0H Senior Member
    3,247
    528
    I run 'em at the sidewall psi ;) Down 2 psi for the rears.
    Mike
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Nope, max load rating marked on passenger car tires in the US is usually at 35 PSI.
    Tire Tech Information - North American Load and Pressure Markings
    fuzzy1 likes this.
  10. fuzzy1
    10,687
    I hadn't seen that, but this is my first car with a 35 psi door placard. Previous cars in this household have (or had) lower ratings, two as low as 26. The wording on one particular set of replacement tires was far more clear than others that the load rating was not valid at the lower placard pressure on the car.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    True.
    I wasn't able to find much on the topic, but this paper talks about different variations on determining load ratings for tires inflated to less than their max load pressure.
    http://www.dawsengineering.com/linked_files/tirepressureatreducedloads.pdf
  12. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yep.
    It's not necessarily a Japanese thing. See Exterior & Cargo - Consumer Reports.
    Yep on the defunct Element. I even brought it up at 810 Pounds Maximum Weight | PriusChat.
    hlunde likes this.
  13. hlunde
    hlunde Member
    419
    75
