Toyota prius gen4 plug in 2016-2022 heat exchanger bypass?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Tony1988, May 17, 2024.
  1. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    407
    2013 Prius Plug-in
  2. Mendel Leisk
    41,479
    Get a caliper of some sort and measure?
  3. giarcpnw
    giarcpnw Junior Member
    Jan 6th 2025, I did this today. Took 20 minutes once the car was up on blocks. All you need is a channel lock or large pliers to pinch the hose clamps and shallow pan bucket to catch about a half gallon of coolant which you can reuse once the hose bypass is installed. Let the car cool off before doing this obviously.
    This is the correct part.
    Gates 18777 Premium Molded Heater Hose
    on amazon for 12.71
    Dealer said the new part catalytic converter is backordered till June. I can't wait that long. This is your temporary or permanent solution as you choose.
    Cheers!
    bisco and Brian1954 like this.
  4. Tony1988
    Tony1988 Junior Member
    27
    Sweden
    2020 Prius PHV
    Did you also weld the pipes from the catalytic converter back together so they were tight? If fluid leaks in, then exhaust gases will obviously leak out after the bypass? What year model do you have?
  5. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    check out that inflation!
    you don't say... Dealer part back ordered 5-6 months.
