TOYOTA PRIUS READY SIGNAL BUT HAS NO POWER ON DRIVE OR REVERSE!,HELP
Discussion in 'Generation 1 Prius Discussion' started by Faisal, Apr 13, 2013.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    Transaxle is the proper name for the Prius transmission. Same thing. People use the terms interchangeably,
    Did the engine run for more than 8-9 seconds? Time it. This is really important. If engine won't run for more than 8 seconds it never started and you have a problem with gas engine.
    Also did your buy the gen1 hv battery from someone who knows a lot about these cars?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The Prius has a transmission that is integrated into the front axle - hence the term "trans-axle". There is a new posting that shows how to replace the transmission on a Gen II. It might be of some help. But, your Gen I car has a number of differences.
    Good Luck
  3. Faisal
    Faisal Junior Member
    58
    2002 Prius
    I
    i removed the axle and im following a gen 2 post. do you think id be able to figure out the number of differences on the bottom end? or would it be really different? thanks
  4. Faisal
    58
    2002 Prius
    I
    removed axle,will take pictures *tired*
  5. Faisal
    58
    2002 Prius
    I
    HI i have codes p0100,p0110, p3100,p3125 can anyone help and tell me what this means?
    i have a 2002 toyota prius showing these codes.bujt my inverter is out and my airbox is out. im working on removing transmission since i think thats the problem. so can anyone please let me know if these codes indicate a bad transmission?
  6. Faisal
    58
    2002 Prius
    I
    i got codes P0100 ,P0110,P3100,P3125
    can anyone indicate what this means? does any of them indicate i need to replace transmission?(remember my inverter,airbox, and both front axles are already taken off.
  7. Faisal
    58
    2002 Prius
    I
    @3pongpaul yes i got it from someone who knows about batteries because he fixed the other prius we have but this one doesnt even run. only the engine runs for more than 8 seconds. on and off. and i dont think theres fuel in my car it shows 1 bar of fuel.. and my codes show misfire, 02 heater, 02 sensor, and misfire. i dont know if its because of the inverter and airbox being off?. anyway problem is the car wont move back and forth. i know when a car moves slow like 2 mph but this one dont move at all.
  8. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Googling the DTC's reveals the following
    P0100 MAF (Mass Air Flow)
    P0110 Intake Air Circuit Malfunction
    P3100 High Voltage ECU Malfunction
    P3125 Inverter Failure
    Also, I would suggest you take a look at the following link. It has information that may or may not pertain to your situation.
    Toyota Prius: Hybrid Inverter caused Transmission to fail?
    That's all I can say about it. I am very sorry that I cannot help you any more than I did. Patrick Wong is very knowledgeable and hopefully he or another well versed PC'er can give you more and better advice.
    Good luck to you and please post again once you find out exactly what is the problem. That will help other's in the future when they run into the situation you are in.
  9. Faisal
    58
    2002 Prius
    I
    3125 is because my inverter is out. we already tried replacing inverter and the car still wouldnt move back and forth. so im guessing its a transmission problem? and p0100 and p0110 might be because air shaft is out and airbox is out.
    p3100 might be ecu dead, might have to replaced. so you think 3125 might be because of transmission failure?
  10. dorunron
    3,318
    1,105
    Houston, TX
    FYI, I simply gave you an idea of what the codes represent. I cannot pinpoint the exact problem.
    I am grasping at straws at this point, however I did just read on another page that MG2 may have gone bad in the transaxle. Take a look at this thread.
    Again, Patrick Wong is the one that can really help you. Bob Wilson is another one.
    Here's the link.
    2002 prius transmission failure ? | PriusChat
  11. Faisal
    58
    2002 Prius
    I
    Yup so either way id have to remove the transaxle. me and my dad were thinking that the MG2 or MG1 might have gone bad. so when we take it out tomorrow. we might send it in for Rebuild(the MG2 that is how can i contact patrick wong?
  12. dorunron
    3,318
    1,105
    Houston, TX
    Patrick is another individual who regularly reads and post's here on PC. He is well known for his ability. That is why I recommend him. I suspect he will reply to this post. I wish I could give you more and better information. Like yourself, I am still learning about the Prius.
  13. Faisal
    58
    2002 Prius
    I
    also the code u gave me is bad ECU and in his post that u just referred it said that since ecu contacts with transmission it can probably be because of ECU. but i think transmission and ECU need to be replaced.
  14. dorunron
    3,318
    1,105
    Houston, TX
    That makes sense to me also. There are a lot of components that work together to make the Prius function. It is a wonderful machine, but can be a headache when it breaks.
    Patrick Wong | PriusChat is the man. He is well respected here in this forum and is very knowledgeable.
  15. bwilson4web
    16,224
    • P0100 - Mass Air Flow Circuit Malfunction
    • P0110 - Intake Air Temp. Circuit Malfunction
    • P3100 - HV ECU Malfunction, need the info code to fault isolate
    • P3125 - generic inverter error, need the info code (i.e., sub-code) to fault isolate.
    When working on a possible transaxle problem, the first step is to drain the oil and keep a one cup sample in a clean, dry container for possible oil analysis. Then drop the pan and look for additional evidence of failure, debris or evidence of 'burnt' oil. These are the indicators that the transaxle is bad.
    Without the mass air flow, the engine is not going to run. The failed intake air temperature sensor is another problem that should keep the engine from running. For grins, open the engine air box, remove the air filter and look through the throat. See if the throttle plate moves as one common problem has been a sticky throttle plate. This can be associated with a lot of problems (search for 'throttle cleaning'.)
    GOOD LUCK!
  16. Faisal
    58
    2002 Prius
    I
    thank you very much Bob, i will check for these symptoms on the air box first thing in the morning as well as drain the oil and check for Burnt oil or if not, a possible oil analysis. then i will re:
    goodnight and lets see what goes on in the morning.
  17. Faisal
    58
    2002 Prius
    I
    where would i get info code by the way? i only have a reader that reads Codes from autozone. it is the most basic one. for $60 that just reads the code , Thanks.
  18. bwilson4web
    16,224
    The "info codes" or sometimes called 'sub-codes' are found by Prius-aware scanners:
    • Scangauge II - the XGAUGE definitions are in the sticky area
    • AutoEnginuity - reads them
    • miniVCI - a hacked TechStream, it should work
    • Graham Miniscanner - does not read the "Info codes"
    If you do go with the miniVCI, be sure and order the one from the Xhorse reseller as their unit has the updated firmware. However, it took almost two weeks to show up. The Scangauge II can be gotten faster but you'll need either the pig-tail described in the sticky or get the ISO-9141/KWP2000 cable from the manufacturer. AutoEnginuity can be gotten quickly but at ~$500, the most expensive.
    Keep the receipt for the cheap scanner and see if you can return it when the better one arrives.
  19. bwilson4web
    16,224
    Some late thoughts and suggestions:
    When I bought our first Prius, a 2003 model, I also ordered the two shop manuals and electrical diagram, nearly $300, from Toyota:
    • Volume 1 - Diagnostics (I see a used one for ~$35 on Ebay)
    • Volume 2 - Repairs (how to do things)
    • Electrical diagram - what wires and signals are found on which connectors and pins and color codes
    Source: DI-23 to DI-26
    Source: DI-28 to DI-31
    Source: DI-234 to DI-241
    P3125 - Converter & Inverter Assembly Malfunction
    Source: DI-271 to DI-306
    The TIS service will allow you to buy access by the day or longer to get online access to this information. An old guy, I prefer a paper manual. Avoid the Ebay CDs as they are poorly digitized, non-indexed, pirate copies of the manuals . . . a lot of unhappy buyers reported.
    GOOD LUCK!
  20. Faisal
    58
    2002 Prius
    I
    i have a repair manual from auto zone by haynes i think. and ill be checking the burnt oil today.
