Turn off Reverse Beep - Mac Instructions
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Frank Perkins, May 18, 2013.
  1. Frank Perkins
    Frank Perkins Member
    129
    66
    Fairfield, Connecticut
    Unfortunately the dealer wouldn't turn off the continuous reverse beeps for me for free at my 5k checkin. They wanted 60 bucks and I wasn't going to let the stealer make an easy 60 bucks for 1 minute's work. I couldn't find a definitive set of instructions on how to do this using a Mac so I pieced together various articles and here you go:
    1. Buy a ELM 327 Diagnostics cable for about 12 bucks
    2. Go here to download the software
      1. Download Driver Pack 1 and install the 2nd package which is for the most current version of Mac OS/X
      2. Download Driver Pack 2 and install. Reboot after the installation
      3. After you are done, this will enable /dev/tty.usbserial
    3. After you reboot, make sure your car is turned on and plug the connector in. It's right under the dash about 6 inches to the right of the parking break. You can't miss it.
    4. Plug in the USB cable into your MAC
    5. Open up the program "Script Editor"
    6. Copy and paste this:
    Code:
    tell application "Terminal"
    do script with command "screen -U /dev/tty.usbserial 38400"
    set number of rows of window 1 to 100
    set number of columns of window 1 to 150
    set background color of window 1 to "white"
    set normal text color of window 1 to "black"
    set custom title of window 1 to "keyspan-1"
    end tell
    1. Press Compile
    2. Press Run
    3. A terminal window will open
    4. Type the commands below. The line under each command is the response. For instance, simply type "AT H1" and then hit enter. you should see OK. you might only see "K" until you do the second command of "AT L1".
    Code:
    >AT H1
    OK
    >AT L1
    OK
    >AT SP 6
    OK
    >AT DP
    ISO 15765-4 (CAN 11/500)
    >AT CAF1
    OK
    >AT SH 7c0
    OK
    >21 ac
    7C8 03 61 AC 00
    >3b ac 40
    7C8 03 7F 3B 78
    7C8 02 7B AC
    >21 ac
    7C8 03 61 AC 40
    Now that is done, what other cool things can I do?
    Update: Turn off the Seat Belt Nag: Turn Off Reverse Beep - Mac Instructions II
    j12piprius, Rainking, mmmodem and 3 others like this.
  2. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    The dealership has to pay the tech 1/2 hour of labor every time he plugs in their Techstream to a customer car. I'm sure you don't work for free either.
  3. Frank Perkins
    129
    66
    If the car is already beng serviced, then I don't think it's too much to ask to change a stupid setting. There is no cost to them and the upside is customer service.
    Not to mention 120hr for a "tech"?
  4. CharlesH
    2,798
    1,166
    Roseville, CA
    My dealer did it for free when I took delivery, and billed it to their internal new car sales make-ready account.
    Rupert B Puppenstein likes this.
  5. bisco
    52,800
    great work frank, thank you. you must be a tech genius.:p i couldn't even follow the instructions, nevermind come up with them! i think you're onto something here. if you can do this, the possibilities are endless. all the best!(y)
    Rebound and Rupert B Puppenstein like this.
  6. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Turning off the beeps is much easier with ScanGuage II but, of course, its much more expensive.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
  8. raimix
    raimix Member
    204
    33
    Long Island NY
    i do say get that reverse done during delivery of the car.
    some dealers are willing to do it for free, but it's rather troublesome when you find your* dealer wouldn't do it for free.
    my dealer told me I was the first one to get that reverse customized during the delivery, and i waited very patiently to get that done.
    anyhow, nice work. nice to find out another way to stop that beep
  9. Drs1954
    Drs1954 New Member
    Upstate New York
    Local dealer programmed mine from constant beep while in reverse to just one beep. They initially wanted $20 but I mentioned that other dealerships were doing it as a courtesy to Prius owners and they agreed to do it at no charge.
  10. Ken Blake
    351
    180
    Portland, Oregon
    Ever hear of "Flat Rate"? That is how "Techs" (aka Mechanics) get paid. A tire rotation or oil change doesn't require connecting the Techstream to the diagnostic port, and is usually performed by an hourly lube rack guy who doesn't have access to the Techstream. (Panasonic Toughbook with proprietary software and connector) So they would have to pull a flat rate mechanic away from whatever job he is working on, and have him connect the Techstream to your car, and make the changes. The Toyota dealership I worked at charged $105/hour for labor. The Lexus dealership I work at gets $120/hour. I know some areas get considerably more for labor, like the Bay Area or L.A.
    I don't know what you do for a living, but again, I doubt you'd be willing to do 10 minutes of work for free, for someone you don't even know.
    OTOH, the Director of Parts and Service at the Toyota dealership would do things like this himself, free, in the interest of customer loyalty. He is by far the exception however. I don't know of another dealership in the Portland Metro area that will not charge you30 minutes labor, just for connecting the Techstream.
    Ken
  11. Boulder27
    Boulder27 New Member
    Silver Spring, MD
    Had mine done for free at 5k also. Don't think that's asking much. Would be cool if the Car Settings from the touchscreen actually had all the settings accessible.
    Frank Perkins likes this.
  12. CharlesH
    2,798
    1,166
    Roseville, CA
    While I would not expect a random dealer to do these Techstream operations for free, it seems to be rather common at least in my area to do these sorts of things as part of new car sales dealer prep. It's figured into the price you negotiate for the car.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Aye. That is why We (PC) recommend having it done during purchase. It's a lot easier to negotiate at that time.
  14. Gruvin2
    Gruvin2 Junior Member
    45
    16
    Baltimore, MD
    I asked my service manager about Techstream & other Nav/Entune updates. I was told I get 1 courtesy update with Techstream and at least the 1st update for Nav/Entune free. Beyond that he could not give me a definitive answer for cost after that.
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    On later 2012 models Entune, or 2012s that already have the first thumb drive update, will update itself via your cell phone and Bluetooth connection. I would verify the Nav update as a separate item. That could prove useful!
  16. rchaput
    rchaput Junior Member
    24
    Is there a safe way to exit the process before finishing I.e., in case of an erroneous entry?
    Another cool thing would be to disable the seatbelt nag.
    Good job. Thanks for the heads up.
  17. Gruvin2
    45
    16
    Baltimore, MD
    I purchased my Pip in November. I was not aware they already have an update for Entune. I do hope it will be lesss buggy then it is now. In regard to Nav update I did speak with the Mgr and was told 1 update is included with my purchase. He did say it would cost after that but did not have a $$$ amount. He has everyone saying how silly it is to try to charge $100+ for a thumb drive update when most consumer gps models now include lifetime map updates or say $70 1 time purchase for lifetime like Garmin offers. I'll take my free updates and just deal after that.
  18. CaliforniaBear
    1,180
    289
    Northern California
    The alternative :)
    Gruvin2 likes this.
  19. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The early 2012 models without the premium system required an update via a thumb drive Toyota sent you. After that update was applied, Entune could update via your cell phone connection. By November all models should have had the update applied.
  20. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    That's totally cool. It reminds me of how we used to talk to modems - ATDT and all that.
