URGENT to PG&E E-7 Customers - Rate Shaft Coming
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilofsky, Nov 19, 2015.
  1. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Yes, a month in advance. And E-TOU can be opened and E-6 closed on any date beginning January 1. It's likely to be March 1, and has to be by June 1, but there are no guarantees and no requirement for PG&E to give any advance notice.
    Which is why I say the last totally safe day to change is today.
    Nice that people are noticing. But PG&E dictates state legislation and the PUC is in their pocket. And Jerry "Mr. Environment" Brown appoints the PUC.
    At least you're learning about PG&E plans. Most customers just sit back and take it, or do what the contractor recommends.
    Electrical use varies so much from one house to another. The only thing you can do is estimate (or smart meter measure) your actual usage, and run it against the different rate plans.
    Did you mean to say that your house is electrically heated? If so, that's a major power use that will happen mostly during off-peak hours, partly mitigated if you use a night setback thermostat. It might well use more electricity than charging your PiP.
    E-6 will be transitioning away starting in 5 years. So if the PV isn't going in until then, you shouldn't consider it in your current rate choice.
  2. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    At least when I was on the E-1 plan, I could log in to the PG&E web site, click on My Usage, then click on My Rates, and it would use past billing data to estimate the annual cost under different plans. I think it compared 4; E-1 and E-6, and then each of those with the SmartRate option. (Now that I have solar - or maybe now that I have E-6 - it tells me that the My Rates tool is not available for my current rate.) In my case, they estimated that I would save about $20 annually by switching to SmartRate, and another $40 or so by switching to E-6. I ended up going for SmartRate because they would refund you if you didn't save money in the first year, and switched to E-6 when I got solar and it became virtually impossible for my bill to be higher with E-6 than E-1.
    It all depends on when you use electricity, and how willing you are to adjust your habits. With SmartRate, you get 2.4¢/kWh off all your summer usage, except for up to 15 days from 2-7 PM, which PG&E announces the day before they happen (generally, the hottest days of the summer). Those days and times, you instead pay an additional 60¢/kWh. Since the high-usage days are usually weekdays, and we're often at work or commuting until almost 7, it's not very hard for us to avoid usage during those times. E-6 is a little more difficult to avoid higher charges completely; on some summer weekend days, I definitely tried to run the air conditioner more before 5 PM to cool the house down, then turned it off until 8 PM and the rate went back down.
    Since you're already on a Time-of-Use plan, you're probably already adjusting as much as you can and are willing to. Some of the differences I see between the EV-A rate and the E-6 are
    - EV-A has more and later peak hours (on weekends and holidays, and ending at 9 PM instead of 7 PM on weekdays)
    - EV-A is not tiered based off of your total monthly usage, but E-6 is.
    - E-6 pays less during peak and part-peak hours, as long as you're under the baseline usage (Tier 1, plus Tiers 2 and 3 during peak hours only)
    - EV-A pays less during off-peak hours
    Given that your bill is so high, I'm certain that you're well into the higher tiers, so EV-A is probably a better rate for you. If you installed a second meter for the EV, it's conceivable that you might pay less with EV-B for charging (which can be zero during peak hours) and E-6 for the rest of the house (which will never be zero).
    As far as solar, for someone with as much use as you, it probably still makes sense. On your current rate plan, I'd bet that the fastest payoff would be if you could size the system to offset a large portion of your peak usage - so probably about enough power to match your air conditioner or something like that. If you want to feel good about yourself, you can install a bigger system like I did to cover most of your usage. PG&E wants you to spend at least $10/month on electricity from them though, so sizing it to meet 100% of your need won't pay off in money - only in smugness, which you may have enough of from your Prius. ;)
  3. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    @NeilPeart, if your community is served by a Community Choice Aggregator (like Marin Clean Energy), you can buy your power from them and get paid for all your excess generation. You'll still have to pay PG&E the minimum for delivering it though. Total rip-off, since you're paying PG&E the same amount to carry your electronsto your neighbor as they charge to import power from hundreds of miles away.
  4. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    If you can afford a fully off grid system you don't have to pay PG&E anything. If you want to use their system as a big battery then $10/month is a very reasonable price. No maintenance on the "battery pack" and free repairs if it breaks. So why all the complaining?
  5. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    All answered before.
  6. CaliforniaBear
    1,180
    289
    Northern California
    How about a brief review.
  7. hill
    9,037
    A review?
    because their system broke their own rules. The rule was - if you use quantity X of their systems juice, then offset quantity X with quantity X of Solar, PLUS a little extra solar to pay taxes, delivery charge fee, usage fee, whatever you name it fee, etc - and the grid gets to profit 4X - 12X above the teeny price it pays you for your delivering extra.
    NOW? Their system wants more. Their System wants that pittance amount that you may over generate too. Their system may shake you down for an extra ten bucks now. And maybe another $10 more down the road. That's how some define "breach of contract" .
    End of review.
  8. CaliforniaBear
    1,180
    289
    Northern California
    Please supply the signed "contract". And also those for cable or satellite TV and natural gas and phone service, etc, etc. Businesses change their prices based on various factors. That's how some define "capitalism". While folks don't like the way utility prices are regulated imagine what it would be like if there were no regulation at all. "Sorry, we are going to double your rates. If you don't like buy a generator."
  9. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    When I got my solar panels almost 10 years ago, they were awfully expensive, even with the rebates then available. I figured on a 16 year payback with the favorable E-7 rate, which PG&E is now taking away. My panels will probably never pay for themselves. I wanted to do something about global warming, so I'm still glad I did it.
    But you're right - there is no contract. PG&E is aggressive about pursuing their interests, and they do it by exploiting free market capitalism, otherwise known as the golden rule: He who has the gold, rules.
    Any claim of regulation is a myth when it comes to PG&E. The Public Utility Commission is in their pocket. They rubber-stamp whatever PG&E proposes, no matter how loudly the solar advocates howl and what the public policy issues are.
    This is all permitted and even encouraged under free market capitalism. The public interest doesn't figure into it.
    So legally you're right - it's legal. But morally, and for the good of society and the planet - I stand by my statement. It's a rip-off. Legal, but a rip-off.
  10. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Here is one of the threads:
    California's PG&E Minimum Charge Increasing September '15 | PriusChat
    The parallel would be if a group of consumers to those providers lowered the costs for the providers or increased the robustness of their networks, then those same providers turned around and did not raise the prices on everyone but targeted those consumers that helped them instead; and that the utilities knew these consumers were already heavily invested in the equipment that helped them, so an easy demographic to gouge.
    Fixing the CPUC (regulation) makes a lot more sense.
  11. CaliforniaBear
    1,180
    289
    Northern California
    So you want to do something for the good of society and the planet only if it pays for itself. That appears to be the same problem we have with trying to reduce carbon emissions.
  12. greenleaf
    greenleaf Member
    153
    35
    Silicon Valley, CA
    I don't know if anyone read the article on LA times :
    Why rooftop solar advocates are upset about California's clean-energy law - LA Times
    California has enacted regulations to have half of the state's electricity to come from renewable sources by 2030. But, whatever you generate on your home's rooftop is NOT counted (or given very insignificant weight) under the regulations. So PG&E and other utilities do not have any incentive to encourage home owners to install solar. Of the 21 states and D.C. that have mandates for clean energy, California is the only state to act this way with regards to rooftop solar.
    I think the state legislators are partly to blame for these changes.
    roflwaffle likes this.
  13. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Not sure which side you're arguing here.
    As I said, I knew my system would take a long time to pay back, but I put it in anyway, to a large extent because I wanted to do something for society and the planet.
    But that's only one factor. Cost is another.
    If it had cost a million dollars, I wouldn't have done it. If it were free, I and a lot of other people would do it. There was a price for it at the time. PG&E is raising the price retroactively. They are in effect punishing good behavior. This ticks me off personally and is also bad public policy because it disincentivizes other people to do something that benefits the common good.
    iplug likes this.
  14. CaliforniaBear
    1,180
    289
    Northern California
    When you make an investment for any reason you can not be assured the return on that investment will continue at the expected rate unless there is an actual contract guaranteeing that rate. Some investments to guarantee the rate of return such as CDs. If you are going to be upset because market factors change the return on your investment you might want to consider that before making the investment. I'm not arguing a "side" just saying you have to be realistic about making investments whether they are for a good cause or simply to make a profit.
  15. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    OK, let's take me out of it.
    PG&E is solar-hostile. They have fought tooth and nail against environmentally protective programs in the public interest like solar-friendly rates and Community Choice Aggregators. They are scum (IMO of course).
    I am not saying they are acting illegally, just IMO immorally. And it's what I have come to expect of them. But I don't have to like it.
    Now let's put me back into it. Those scum are raising my rates too. :(
    Edit: And because PG&E is a public utility, the public interest should be part of what influences their rates, not just market factors. But because the PUC isn't playing its role properly, that's not working.
  16. CaliforniaBear
    1,180
    289
    Northern California
    Okay! I'm unhappy about a lot of things the government and related organizations do too, especially after yesterday's activity. I have found the PG&E frequent rate changes to be more of an inconvenience for maintaining my monthly electricity parameters spreadsheet than a cost concern. Enough said.
  17. Dion Kraft
    Dion Kraft Member
    305
    92
    Washington, UT
    Almost all elec utilities are worried about excess power now that solar has become cheaper to implement in your home. That and Elon Musks batttery packs to power your home is another dart in the side of the util. Hawaii Electric is not doing so well due to so much payout of cash for electricity generated by their subscribers. In the meanwhile..Texas gives free electricty from 9pm to 6am to shed their excess capacity. Its a changing world out there and the utilities see it to be dire and will fight to keep in control as much as they can.
    PG&E being the biggest will probably be followed by SCE and then SDG&E.
    San_Carlos_Jeff likes this.
  18. hill
    9,037
    you've missed the point. I will explain the contract. The contract, in short states," we supply electricity & you supply electricity - and if one is more than the other, the one with the shortfall settles up with the other up at the end of their yearly period. GOT IT? Pretty simple. Yes it's in writing, and it meets the criteria of a contract - a bargained for exchange. Think of it as one of the many broken contracts with American Indians. The little guy loses unless he has a way to enforce against the big guy. Similarly, if the victim fails to assert their issue, the other party wins.
    In this case, the utility decides, "hey we have a crappy business model, and we can't capture our obscenely large profit center because the law says we gotta pay a fair rate in exchange for solar helping stabilize a grid we fail miserably at maintaining -
    California Home To Three of Ten Highest-Paid Utility Execs | Utilities | Rewire | KCET
    Earnings rise for Edison's top-paid workers - The Orange County Register
    - that ratepayer income we regularly abuse by over paying ourselves, even though we are incompetent".
    Utilities, regulators conspired to make public pay for California nuclear plant closure - World Socialist Web Site
    I have to admit that it's kind of creepy hearing someone so vigilantly sticking up for these bunch of crooks. Any chance you're on the Edison executive compensation committee? Between the utility company's backdoor deals for more pay & failing to properly maintain San Onofre nukes -
    You want to say the utility has an automatic right to change the rules?
    Really?
    #38 hill, Dec 3, 2015
  19. CaliforniaBear
    1,180
    289
    Northern California
    If it says in the "contract" they will not raise rates than you have a point. However it doesn't say that. The utility doesn't have an automatic right to change rates, that's why we have the PUC which no one likes but its marginally better than no control at all. If calling people crooks makes you feel better, have at it.
  20. hill
    9,037
    Google it yourself to see who is calling the cali utility exec's a group void of integrity & dishonest. You'll find it's not me or any one individual. It's numerous consumer interest groups. Do the math. Why do you think nuke waste is sitting near the San Onofre coast just waiting to get washed inland if/when a tsunami hits. It's piss poor management serving its own interests - greed. Must be nice living in a world with no knowledge or complete indifference. Can't help but notice the question was never answered whether you're one of those utility execs - friend or family members. I don't blame you. I wouldn't admit to that shame either. If you think victims of utility company corrupt leadership are waiving their contractual rights - think again. The causes of action are already in the works.
    #40 hill, Dec 3, 2015
