Used Gen4 Pre-purchase: TSB's, Caveats, Recommendations
Discussion in 'Gen 4 Prius Main Forum' started by wr69, Aug 9, 2023.
  1. wr69
    wr69 Member
    143
    79
    portland, or
    I'm considering purchase of a Gen4 used Prius - probably not a prime, but possibly an AWD. I looked at the G4 sticky TSB link, but it failed to mention the coolant-leaky exhaust issue, so am wondering if there is a more comprehensive list of G4 TSB's? Or what are the gotchas with G4, and the various years? I read 2016 had some issues but cannot recall them. Anyone have a little summary of Gen4 issues and caveats to lookout for?
    Also, has anyone had luck calling Toyota with a VIN they don't own and asking them for the open recalls or TSB's of if any have been fixed?
    thx in advance! much appreciate everyone's help.
    52,804
    try the vin on toyota.com/owners
    there are a lot of little issues with gen 4, but the heat exchanger leak is the main one. now there is talk of blown head gaskets, but other than overheating from the leak we don't know anything.
    TGrracie and wr69 like this.
  3. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    One thing documentation doesn't show is how the car was driven.
    I rented a 2020 Prius while the Prime was in the shop, and it was hard to digest how the gauges were looking and the mpgs shown. But it was a rental and I figured that it had been driven pretty hard most if it's life and it was rather pointless to try to change the mpgs in a week.
    You could say I was shocked at the pump before turning it in, since I'd been used to the Primes pump averages.
  4. Brandon Luna
    Brandon Luna New Member
    Vjančana, Lào
    Did you replace like for like, or did you do some funky halogen/HID --> LED
  5. wr69
    wr69 Member
    143
    79
    portland, or
    hi vvillov. thx for reply, what significant differences did you notice with the rental car, compared to your normal daily driver?
  6. wr69
    wr69 Member
    143
    79
    portland, or
    I did some research and thought I would post this here for others:
    Buzzing under DASH:
    TSB Issued for Buzzing rattle in dashboard | PriusChat
    NiMH Battery Reduced Power while stopping:
    TSB (NiMH only): Reduced power when accelerating from a stop | PriusChat
    Low Coolant after leaking from exhaust heat Exchanger:
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10166037-9999.pdf
    All Known Gen4 TSBs:
    All Known Gen 4 Prius Recalls/Technical Service Bulletins (TSBs) | PriusChat
  7. vvillovv
    4,336
    1,518
    NY
    It was near imposible to hypermile the car. It ran just as one would expect a regular car to drive. As long as the driver never looked at any gauges besides the speedo and gas gauge once in a while. A driver would never know if they were driving a Prius, Nisson Versa or Hyundai Sonata.
    Just looking at the screens that were showing when I first got in the car and drove if for a day or two. I didn't bother even looking at any of the other screens.
    The car drove just like I'd expect most any other car on the road to drive and refuel. Perhaps better than some, it wasn't what I'm used to hypermiling the Prime,having to deal with only one other driver that drives it like a regular car.
    The TSB's linked above, from what I've read here at Priuschat are all mostly minor issues in the grand scale of Toyota TSBs.. I've seen one post about a dash rattle and one about coolant leaking from the heat exchanger. The middle TSB - Reduced power, I'd think is more of a inexperienced driver expecting more from the car than it's able to provide in specific instances. There are times when the Prius just doesn't seem to have it's normal pep, vim and vigor. But it typically goes away in due course, unless the car somehow gets kept in the compromising situation that makes it feel so sluggish at times. Just try to imagine how it would feel to have all the energy sucked out of you or I and someone else wanted us to preform normally. Do you think we might get some complaints about our performance?
    #7 vvillovv, Aug 11, 2023
  8. bisco
    52,804
    like for like, albeit not toyota oem. idk who makes their bulbs
  9. babiker712
    babiker712 New Member
    Minneapolis
    2015 Chevy Volt
    I was unaware canadian units can't convert temps in C to F. Odd programming choice by Toyota
  10. Mr.Vanvandenburg
    1,359
    651
    2020 Prius Prime
    https://www.nhtsa.gov/recalls
    T
    he only thing I thought about buying a Prime was get the newest year possible for battery warranty length to me, and since 2020 the Prime has a flat back seat for my dog, it had to be 2020 or newer. I think gen 4 had a good record of reliability, sometimes number one of all cars by CR. The Prime was always up near the top too.
  11. wr69
    wr69 Member
    143
    79
    portland, or
    I wish i could just edit my post to include this below link as well. While somewhat minor, this guy mentions the controls on at least the 2016 went to a monitor-driven display configuration - in other words, you're futzing around with the touch-screen, like you would on an iphone/android, to change things like the climate temperature. There is an obvious engineering advantage (real mechanical buttons are much more expensive than software over the long haul); but it comes at an operational/convenience price:
    Generational Problems with Prius (g2/g3/g4) (climate controls are touch-screen):
    This could be a pet-peeve, but it could be significant for those who are more traditional, as futzing around with a touch-screen while driving can be somewhat hazardous. It looks like Toyota may have changed this in later years of the Gen4. Does anyone know when that was?
  12. vvillovv
    4,336
    1,518
    NY
    I haven't read too much about the Prius trims, but the base Gen 4 and 5 Prime trims with the smaller MFD screen always seem to have more knobs to turn HVAC specially, than touches on the MFD screen.
    The traditionalists here at priuschat with Prime upper trims have commented on the touchscreen HVAC controls being less convenient than the knobs.
    I think having the HVAC controls on the big screen is one of those advances (if you wanna call it advanced) those of us that are used to only having knobs to turn in the past can easily complain about. Even is it only takes a few months to learn the switchover. "We are borg, you will be assimilated" kinda thing.
    Technology, these days keeps on keepin on and it's just another one of those questions to be answered by each individual, whenever possible.
    In short, HVAC knobs are still available on the Prime base trims in Gen 4 and I believe Gen 5 too.
    wr69 likes this.
  13. MikeV
    MikeV Junior Member
    95
    philadelphia
    has that been addressed in later gen 4 models
  14. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Go to
    http://Techinfo.toyota.com
    And you can see all the legitimate info.
    having said that, I would suggest you peruse this site with an eye to how many members do the bare minimum when it comes to preventive maintenance and then how many of those same people report “significant issues” occurring with specific generations. Then ask yourself “do I really want to take a chance on buying a used Prius from someone like that?” The Car Care Nut once said that there are no good deals on used Priuses because the people who REALLY take care of them like they should have a tendency to hang on to them. Those that don’t care for them like they should, have problems that they pass on to the next person.
  15. bisco
    52,804
    not that i have read, but since there is a tsb, it is possible they did some upgrading at some point.
    sometimes you can tell by looking at part numbers. when a factory production part changes, the number changes
  16. sylvaing
    sylvaing Senior Member
    1,219
    517
    Luckily for me, my Prius Prime 2017 had a single owner and he always did the services at the dealer so I had access to all the services he did. He followed the service schedule religiously and I'll follow in his footsteps. My next maintenance, beside oil change is transmission and coolant change at 160k km.
    Doug McC likes this.
  17. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    Hopefully you are planning your coolant changes based on testing of the coolant versus mileage or time. FWIW I have already seen a slight change in the ph of the coolants after just 18 months in my ‘22.
  18. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    WHAT!? Bisco SHOULD know full well that Toyota changed the design of the heat exchanger (but then again he does 10K OCI AND wonders why he’s having head gasket problems) .
  19. bisco
    52,804
    i don't do 10k oci, why are you making up your own facts?
    please post the link to the design change, thank you
  20. sylvaing
    1,219
    517
    How do you test the coolant? This is what it looks like right now.
    Is it the same test as for standard radiator fluid (ie. Prestone)?
    I have these that I bought to test the brake fluid in my Modele 3 since the brakes are rarely use. It does test for coolants but not sure of it applies for the coolant used in the Prius
    Phoenix Systems 8006-B Double-Ended Brake Fluid + Coolant Test Strips (15 foil wrapped test strips), 1 Pack https://a.co/d/9JIgGmR
