Using the Primes 120v Charger at 240 Volts, Cost $20 !!!
Discussion in 'Prime Plug-in Charging' started by Rob43, Mar 16, 2019.
  1. Richard Merwyn
    Richard Merwyn Junior Member
    napa, ca
  2. Richard Merwyn
    napa, ca
    So that box has both 120 and 240 volts? Presumably, the bottom female plug is 240 and the top is 120? And you have no warning or indications on the outlet? This very very dangerous, even life-threatening. How would anyone but yourself now that one of the two recepticles is 240 volts? From your previous posts, I learned it is supplied by a single UF 12-3 cable, so there will be no equipment ground available at this service as well. Please either consult or hire a qualified electrician!
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Were you going to say something?
  4. Jon Bloom
    Jon Bloom Member
    77
    78
    Connecticut
    From his posts, it's clear he installed one of these outlets, so it should be perfectly clear which outlet is which. And a 12-3 cable includes a ground wire (it's not counted in the "3"), so there is no reason to assume he didn't wire it correctly. Plus, he said he has GFCI breakers, so....
    drash and Rob43 like this.
  5. jerrymildred
    11,517
    14,152
    Tampa, FL
    Ah, there you are! Just waiting for a moderator. :D
    Yeah, that's pretty scary stuff having 120 & 240 in the same box with the same outlets. And it for sure needs to be 12-3 WITH ground to be safe in the grounding department.
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Jerry, please take a Better Closer Look at this Leviton 5842 receptacle, it is Not the "Same Outlets".
    One is NEMA 6-20R
    and
    One is a NEMA 5-20R
    These are Not interchangeable ....
    Rob43
    #206 Rob43, Feb 14, 2020
  7. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Wow! I want one of those for my 240V teakettle in the kitchen. Where do I get an outlet like that, and what's it called?
  8. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Good...
    Then just plug your 240v teakettle in, you'll be happy you did.
    Contact Leviton and they will hook you up because the Leviton 5842 is a Dual 125v/250v UL listed product.
    Here's an Amazon link to your Leviton 5842 receptacle:
    www.amazon.com/Leviton-5842-I-Receptacle-Commercial-Grounding/dp/B000U3BVMI/ref=sr_1_1?keywords=leviton+5842&qid=1581757765&sr=8-1
    Rob43
    drash and RobH like this.
  9. jerrymildred
    11,517
    14,152
    Tampa, FL
    Thank you, Rob. I see what you mean. I wasn't paying enough attention to the right side. I wish it wasn't too late to edit my earlier comment so I could add my retraction.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Jerry,
    You are very welcome.
    Honestly I know you are much Smarter on this subject than I will ever be.... (y)
    Rob43
    jerrymildred likes this.
  11. jerrymildred
    11,517
    14,152
    Tampa, FL
    You're very kind. The ol' brain ain't what it used to be, though, so I sometimes miss obvious stuff. When I went back and looked again I could have slapped myself. LOL!
    Rob43 likes this.
  12. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    My Rob43 adapter works fine with the my Toyota EVSE but I have not yet tried it with my Nissan Leaf EVSE, any reason it would not work also?
    Rob43 likes this.
  13. fuzzy1
    10,452
    Without inside information from the Leaf community, I can think of plenty of reason why it may not work. And could fry the EVSE. Remember that this adapter is for an off-label use of the Toyota EVSE, and it took users here some special investigation to determine that it would safely work. This adapter will destroy many other products, that is why you can't find it in hardware stores.
    So don't simply assume that it will work on the Leaf side, check with the Leaf aficionados first. Hopefully there is a critical mass of them here too.
    #213 fuzzy1, Feb 16, 2020
  14. CharlesH
    2,797
    1,163
    Roseville, CA
    Specifically, it has been determined that the parts in the Toyota EVSE will handle 240V, probably because they use the same design for the 120V US model as they use for the 240V European model, with just a different plug. There have been no reports of failures in the "off -label" use. It just happens to work, but there is no assurance that another manufacturer's 120V EVSE will safely handle 240V. As I recall, the EVSE that came with the 2012-2015 Prius PlugIn was NOT 240V-capable.
  15. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    I'm glad your wining Rob43 adapter works great !
    That exact part number Nissan EVSE unit that I recommended you buy will also work well at 240 volts. If it were me, I would use your Toyota EVSE as your main unit & your Nissan as your secondary unit.
    Rob43
    fuzzy1 likes this.
  16. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    This unfortunately is another internet Myth.
    The Toyota 2012-2015 (Gen 1) EVSE unit works great at 240 volts.
    Rob43
  17. CharlesH
    2,797
    1,163
    Roseville, CA
    The Internet Myths I was referring to were discussions here in PriusChat that claimed that some of the components in the 2012-2015 EVSE, like capacitors, were marginal for 240V. Not that they would necessarily blow up, but that they were pushing the limits.
    Are you saying that the person in PriusChat who did an upgrade of the components in the standard EVSE so it could be used at 240V was, ummm, somewhat less than honest?
    #217 CharlesH, Feb 17, 2020
  18. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Take a minute & look through this. Both the G9060-47130 and G9060-47190 are very stoutly built, 240v forever is no problem.
    Fast Charge Your PiP At L2 Speeds, For CHEAP ! | PriusChat
    Rob43
  19. sjsuguy
    sjsuguy New Member
    Santa Clara
    2020 Prius Prime
    Hey Rob, or anyone else here that has built one of these.. I'm building a 20 ft cord that is going to plug in to a 4 prong dryer outlet. In simple terms, is this the correct setup? If so, the 4 prong plug is going to use only 3 wires? Where would the wires go? On the receptacle side, it's labeled green, white and clearly that leaves black as the last option .
    Thanks
  20. jerrymildred
    11,517
    14,152
    Tampa, FL
    Normally, on a dryer plug like that, the ground (green) wire would go on that top center green terminal. The Neutral (white) would go on the center bottom terminal (closest to the cord). The left and right terminals are for the hot wires (black and red).
    In your case the neutral isn't used. So, put the black and white wires on the left and right terminals. Be sure to put black tape near both ends of the white wire to indicate that it is hot and not neutral!! That leaves the green ground wire for the green ground terminal.
    sjsuguy likes this.
