Warming up the car in winter
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mikenancy1, Dec 15, 2012.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    If you need heat, use two eggs full of gas. PiP is efficient with either fuels.
    Andyprius # 1 likes this.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    It's intriguing to hear that when given the option to choose, there are complaints that it's not forced.
  3. Natural outside air would be fine, as in other vehicles.
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I didn't even know it had it until I read about it here.
  5. john1701a
    12,840
    5,312
    58
    The setting of "LO" provides that.
  6. If you compare air flow quantity and velocity, LO position equates to NIL.
  7. Check it out, pin a telltale.
  8. Message quoted out of context, please don't do this.
  9. FULL CONTEXT OF QUOTE: ABOVE
  10. john1701a
    12,840
    5,312
    58
    If you set the temperature to "LO" with auto "OFF" and defrost "OFF" prior to powering off, then any blower speed and any combination of window/foot/mid will circulate air from outside without starting the engine.
    Sorry, but the simplification was due to not being able to follow the context anymore. There are several posts all discussing the same thing all at the same time. Please disregard all previous mentions and only accept the text in bold above.
  11. bisco
    52,785
    i get plenty of air to clear the windshield, but unfortunately, i get too much cold air on my feets!:D
    delrey and lensovet like this.
  12. Bisco , I told you before, you have to wear socks in the North !
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    battery powered wan's:whistle:
  14. bisco
    52,785
    that just seems too simple to work.:rolleyes:
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    of course you'd have to check yer "SOC"k:p
    lensovet likes this.
  16. lensovet
    2,615
    496
    Burlington, NJ
    this thread got derailed quite a bit but i did want to make sure this didn't go unanswered –
    the Gen 3 Prius have an all-electric water pump which does NOT require the ICE to run. Of course, ICE still needs to run at least once to warm up the coolant initially, but after that, as long as coolant stays above a certain temperature (which apparently depends not just on whether you've selected ECO mode but also what your climate control temp is set to), you will continue getting heat without any ICE operation. John does this all the time during his commute.
  17. CarmelPrius
    CarmelPrius At 1 mile.
    49
    Maine
    When it's cold out, I turn on the heater! Why make life so frigging complicated?
    dmaxwellh likes this.
  18. CarmelPrius
    49
    Maine
    In cold weather, just get in the car and turn on the heated seats, and drive it. This car gets great MPG, and I could give one twit about CO2 omissions.
  19. bisco
    52,785
    some of us are concerned about emissions.
  20. I have always been talking about initial warm-up only.
