Warning lights: check engine, VSC, brake warning light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ChiPrius2005, Mar 20, 2016.
  1. ChiPrius2005
    ChiPrius2005 New Member
    Chicago, IL
    Issue: Today, my 2005 136k Prius had the check engine, VSC (yellow), and brake warning light (yellow, the exclamation mark one) all come on at once, as well as the exclamation mark in the red triangle, and the red car icon with the exclamation mark on the screen (meaning take the car to dealership immediately).
    Driving experience: I've noticed no functional difficulties driving the car (including 20 miles home after the lights came on). However, last night when I started the car for the first time in 2 weeks (it had been outside in a winter climate in an airport parking lot), I noticed that the engine sounded a bit rough and grating at first. It drove and sounded largely normal after that, so I didn't think much of it. Sometimes it doesn't feel as punchy or powerful (like it doesn't accelerate as easily or quickly, and feels a little heavier/more sluggish) as I think it used to, but this feels too subjective, especially since I've been driving some other cars lately. I don't know much about how to read the hybrid battery icon on the fuel economy screen, but the battery went between 6-8 bars and was either blue or green the 20 miles I was driving it back home after the lights came on). I got the 12V replaced within the past 2 years.
    Plan: Basically, I'm taking it to a dealership first thing tomorrow morning, none around where I am now are open for service on Sundays. Because I travel a lot for work, I have no stable or continuous relationship with a dealer , and I'm worried about getting ripped off, especially if this is an HV battery issue. For the first 7-8 years we owned it, it went to one dealer consistently who my family trusts and still has a relationship with (2015 Prius with them), so I can call them for guidance, but that's it. I'm supposed to be leaving town to move for work via car (7.5 hour drive) ASAP, so I would *really* prefer to have a timely repair than to have to wait very long for a part to ship or, worse, buy a new car entirely (but I know one of those could be necessary). I'm just a little anxious about it, and was wondering if anyone has ideas on what's wrong, advice for questions to ask the dealer (and things to look out for), and guidance on my best (but preferably relatively quick, and safe for people who don't know cars well) options if it is an HV battery issue.
    Additional detail: The car displays an "Air Conditioner Off" notification right as I turn it on now which I'm fairly confident it didn't before, if that points to anything. It will let me turn on the A/C (I checked -- didn't use it, just on and off) but showed that notification at start-up).
    Thanks for any guidance!
    #1 ChiPrius2005, Mar 20, 2016
  2. JC91006
    16,925
    8,636
    1. check the oil level in your car and make sure you have oil in the engine
    2. check the voltage in your 12v battery to make sure it's at least 12.5 - 12.9 volts. If not, charge it back up
    3. I would reset the car (by disconnecting the 12v negative for a few seconds). All your warning lights should go away and see if they come back.
    If this ends up to be a hv battery issue, I would recommend buying a new battery from Toyota. You can ask Toyota corporate for financial help....but that will take time and you sound like you don't have much time to spare.
  3. Patrick Wong
    18,210
    6,517
    If the 12V battery is in obviously bad condition then that would be the first item to replace. Otherwise, visit your dealer service dept tomorrow and see what the tech comes up with.
    Since a timely repair is your highest priority, do not disconnect the 12V battery if it is in acceptable condition, as that will cause the loss of whatever DTC had been logged. It is OK to disconnect the battery if you have time to play around with the car and wait for the faults to reappear.
    The issue is likely a serious one since the red icon in the upper left corner of the MFD is on. That shows the hybrid drivetrain is impaired. And the car may have more than one issue since the check engine light is on, as well as the VSC/brake system warning lights.
    Lisa Petersen likes this.
  4. ChiPrius2005
    Chicago, IL
    Thanks for the thoughts and feedback! 12V battery was fine, tested it. Sadly, the dealership pulled diagnostic codes and concluded the HV battery needs to be replaced. Luckily, they had one in their warehouse, and will have it done tomorrow or Wednesday.
  5. Lisa Petersen
    Lisa Petersen Junior Member
    Apple Valley CA
    I just experienced the exact situation, same symbols/lights with my 2005 Prius, 116,700 miles, about 3 hrs ago. Car has been running fine, no issues. Funny thing is, I had just left the dealership after purchasing oil & filters for maintenance. Drove 10 miles and this happened. Pulled over, check engine compartment, all fluids okay, no overheating, etc.. Husband advised to continue home. So, he said he would check the 12 volt battery as discussed above and tomorrow morning take in & have codes pulled. Is there anything else we should do?
  6. Patrick Wong
    18,210
    6,517
    1. Check the inverter coolant reservoir for fluid turbulence when the Prius is READY. If you do not see this, the inverter coolant pump has failed.
    2. Get Mini VCI so that you can be self-sufficient with regards to retrieving DTC on Prius and for that matter, any Toyota vehicle. This provides you with similar capability with regards to retrieving DTC and monitoring many vehicle parameters, as is available to the Toyota dealer techs.
    tommymommy likes this.
  7. Lisa Petersen
    Apple Valley CA
    Well, checked 12v battery, shows 12.48, charger is connected at this time & charging. Checked for fluid turbulence while READY, there is
    zero movement. Taking Prius to friend that has to retrieve DTC, then will see what comes up. Thank you so much Patrick for your assistance & knowledge in this matter.
  8. Lisa Petersen
    Apple Valley CA
    UPDATE: Codes showing are: P0A93 and B2799. So, husband & his friend want to replace inverter coolant pump tomorrow if I can get replacement part. Is anything else you would advise to purchase and/or have performed? What do we need to consider with the code B2799?
  9. Patrick Wong
    18,210
    6,517
    Yes, P0A93 means the inverter coolant pump needs to be replaced. Your husband should also buy a gallon of Toyota Super Long Life Coolant, to replenish the inverter/transaxle coolant. That system will need around 2.5 quarts.
    You may find my 2009 post about how to replace that pump to be of interest. This was written prior to Toyota implementing the limited service campaign to replace the pump at no charge. That program expired in Nov. 2013.
    http://priuschat.com/threads/how-to-replace-the-inverter-coolant-pump.65173/
    LSC A0N - HV (Inverter) Water Pump; Dealer Letter and Technical Instructions | PriusChat
    Regarding B2799, see if that code comes back after you've taken care of the inverter pump. This means a communications failure between the immobilizer ECU and hybrid vehicle ECU. If you are lucky, that is a spurious fault caused by the 12V bus voltage dropping down as the DC/DC converter within the inverter stopped functioning.
    I suggest that the engine coolant pump should also be inspected to see whether the pump bearing is leaking. If so then it would be good to replace that pump at a convenient time. The engine coolant system will need ~6.5 quarts if the system is fully drained including the coolant heat recovery system canister.
    #9 Patrick Wong, Mar 22, 2016
  10. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
  11. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    Good point on checking about the recall first. I had mine replaced last October when it died on a trip. The out of state dealer who I've never dealt with or did any service with diagnosed it and replaced it for free under the recall.
  12. Lisa Petersen
    Apple Valley CA
    Thank you for the input exstudent, I pulled my paperwork from previous owner and the inverter coolant pump was replaced at 62,452 miles back in Oct. 2011. I purchased Prius in Dec. 2011 with 63,500 miles. Dealer charged full price per paperwork.
    So, I called our local Victorville Toyota dealer and he quoted $141 plus tax. So per your suggestion went to their online parts dept. and purchased it for $105 total. Picked it up last night along with a gallon of Super long life coolant.
  13. Lisa Petersen
    Apple Valley CA
    Update: Husband drove car to friends shop to replace inverter coolant pump, NO symbols/lights showing. So Im thinking putting the trickle charge on the 12V battery took care of those for the time being. We will see how it goes after changing out the inverter coolant pump. He is also replacing the serpentine belt while he is working on Prius.
  14. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    If it was a short trip, the inverter may not have gotten hot enough to retrigger the symbols/lights. It will drive and feel normal until it starts getting too hot from the lack of coolant circulation from the inverter coolant pump not working.
    dave
  15. Lisa Petersen
    Apple Valley CA
    New inverter coolant pump & serpentine belt installed. Checked for any signs of leaking from engine coolant pump, none found. Drove over 200 miles today, 88 degrees outside, used A/C, all went well. Still No symbols/lights, :). Husband will see if any codes come up on Monday. Again, thank you all for your assistance.
